Gumout Cleaning Deposits from GDI Q&A
Click here to participate in the Gumout Cleaning Deposits From GDI Q&A
12 quarts Redline 5w30 $96.00 York pa area
by spiderbypass
05/24/16 03:00 AM
Trying to prevent high mileage leaks
by twincam00
05/24/16 02:04 AM
food depot
by urrlord
05/24/16 12:13 AM
Re-surfacing original GM wheels
by HM12460
05/23/16 10:28 PM
Valve guide seals? - This much smoke?
by Nick1994
05/23/16 10:12 PM
Opinions on goodyear Viva 3's
by Toaster_Jer
05/23/16 09:37 PM
Suggestions for used suv/cuv
by dohnuts
05/23/16 09:26 PM
60's GM S/W With Speedometer That Changed Color ??
by crazyoildude
05/23/16 08:55 PM
old oil
by OkieHick
05/23/16 08:48 PM
Good lubricant for door hinges that last?
by wolf_06
05/23/16 08:47 PM
Mini Cooper OEM Purflux 5153 miles [cut open]
by nicrfe1370
05/23/16 08:11 PM
Mag 1 and SuperTech knockoffs not looking so good
by AP9
05/23/16 08:02 PM
showstopr30, any_user, NibbanaBanana, h22rider, Troyselby
57963 Registered Users
21 registered (DemoFly, alcyon, Atesz792, bobbob, 2 invisible), 527 Guests and 110 Spiders online.
57963 Members
66 Forums
249324 Topics
#2419509 - 10/29/11 09:53 AM 05 Grand Caravan, transmission capacity?
otis24 Offline
Loc: South Dakota
How many quarts of transmission fluid (total capacity) does a 2005 Grand Caravan hold? Not listed in my owner's manual. Also, 250 miles into a trip, I checked the tranny fluid. It was barely warm to touch. I do have a tranny cooler that I added on and the outside temp was in the 30's. Would this keep the tranny fluid from getting warm?
1991 Chevrolet K1500 (4.3, 4x4, 86k miles)
2009 Chrysler T&C (85k, 3.8)
#2419515 - 10/29/11 10:02 AM Re: 05 Grand Caravan, transmission capacity? [Re: otis24]
JHZR2 Offline
Loc: New Jersey
I dont know that you can base ATF fluid temp by checking the dipstick.
And Id kind of be happy if it was cooler. A cooler without a thermostat sure could make it much slower to warm the fluid, especially when its cold out.
#2419549 - 10/29/11 10:39 AM Re: 05 Grand Caravan, transmission capacity? [Re: otis24]
dparm Offline
Loc: Chicago, IL
Amsoil's website can give you the exact amount. There were several motors offered so I can't tell you right away.
2011 BMW M3 sedan ZCP
#2419575 - 10/29/11 11:00 AM Re: 05 Grand Caravan, transmission capacity? [Re: otis24]
doitmyself Offline
Loc: MI
I checked my '05 factory service manual and they list capacities as:
DESCRIPTION SPECIFICATION
Fuel Tank (Gas) 75 L (20 gal.)
Fuel Tank (Diesel) 75 L (20 gal.)
Engine Oil* - 2.4 L 4.7 L (5.0 qts.)
Engine Oil* - 3.3/3.8 L 4.7 L (5.0 qts.)
Engine Oil* - 2.5 L(Diesel)6.0 L (6.3 qts.)
Cooling System** - 2.4 L 10.7 L (11.4 qts.)
Cooling System** - 2.5 L Turbo Diesel with
Auxiliary Heater 13.8 L (14.6 qts.)
Cooling System** - 3.3/3.8 L without Auxiliary Heater
12.6 L (13.4 qts.)
Cooling System** -3.3/3.8 L with Auxiliary
Heater 15.4 L (16.3 qts.)
Automatic Transaxle -Service Fill 3.8 L (4.0 qts.)
Automatic Transaxle -4XTE Overhaul Fill 9.2 L (9.7 qts.)
Manual Transaxle (T8505-Speed)2.4-2.7 L (2.5-2.9 qts.)
AWD Power Transfer Unit 1.15 L (2.4 pts.)
Power Steering 1.2 L (2.5 pts.)
AWD Bi-directional Overrunning Clutch 0.575 L (1.22 pts.)
AWD Rear Carrier 0.7 L (1.48 pts.)
* (includes oil filter)
** (includes heater and recovery/reserve bottle)
This is from chapter 1, Lubrication and Maintenance- Fluid Capacities.
I could find no other capacities in the transaxle service section, nor did I see any reference to engine types (capacity differences).
Your system should hold more if you have an add-on cooler. I always recommend confirming any information on your own.
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
