Car&Driver opinion on Toyota weird styling
by HTSS_TR
06/29/16 06:01 PM
Old house woes
by OVERKILL
06/29/16 05:55 PM
Toyota Factory Fill???
by Doog
06/29/16 05:43 PM
Time to Replace?
by GMFan
06/29/16 05:20 PM
typical "life" of differential oil?
by TexasTea
06/29/16 04:22 PM
MaxLife Semi Syn 5w-20 vs Castrol HM
by dpaldino
06/29/16 04:10 PM
Vehicles with American contends are shrinking !
by HTSS_TR
06/29/16 04:03 PM
Anybody use Shell Rotella T1 SAE 40 in boats?
by Bgallagher
06/29/16 03:00 PM
"Scrub Radius"
by George Bynum
06/29/16 02:36 PM
Any Subaru gurus here? EJ25 DOHC vague knock
by Why_Anything
06/29/16 02:31 PM
Erdogan apologizes to Russia
by Jetronic
06/29/16 02:28 PM
Terrible accident in So Cal last night.
by HTSS_TR
06/29/16 01:30 PM
jameson223, graywolf001, Likeapogi, 40fordcoupe, stickrpg23
58319 Registered Users
86 registered (2002 Maxima SE, 01rangerxl, AirgunSavant, 2004tdigls, 13Tacoma, 4 invisible), 1891 Guests and 12 Spiders online.
58319 Members
66 Forums
250995 Topics
#2409748 - 10/18/11 10:44 PM Hyundai Power Steering Fluid PSF-3
gw105 Offline
Loc: BC, Canada
The manual for my 2006 Hyundai Elantra calls for "PSF-3 Type fluid". I have never heard of this before, likely dealer specific. Is there any other equivilent or better fluid available for this application?
#2409946 - 10/19/11 09:26 AM Re: Hyundai Power Steering Fluid PSF-3 [Re: gw105]
Tempest Offline
Loc: Las Vegas NV
I had Amsoil ATF in the power steering of my Dad's Elantra for years. No problems.
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
#2411537 - 10/20/11 06:44 PM Re: Hyundai Power Steering Fluid PSF-3 [Re: gw105]
gw105 Offline
Loc: BC, Canada
Will plain old Valvoline power steering fluid work?
#2412047 - 10/21/11 12:09 PM Re: Hyundai Power Steering Fluid PSF-3 [Re: gw105]
JTK Offline
Loc: Buffalo, NY
You think PSF-3 is painful to find, 2007+ use PSF-4! I never got around to changing PSF on my Santa Fe, but from what I've read, owners have swapped out factory PSF-3 and 4 with various name-branded "synthetic PSF" with no negative effects what so ever.
Joel
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#2412058 - 10/21/11 12:20 PM Re: Hyundai Power Steering Fluid PSF-3 [Re: gw105]
Wilhelm_D Offline
Loc: Tacoma, WA
PSF-3 was originally specified as "PSF-3 or Dexron ATF".
Most dealers don't carry it - they use Hyundai ATF or another ATF.
Any quality highly friction modified ATF should work - SP-III Hyundai, Mercon V, etc.
#2412305 - 10/21/11 05:25 PM Re: Hyundai Power Steering Fluid PSF-3 [Re: gw105]
RPMster Offline
Loc: Southern California
Yep, I can confirm this as well. Straight from a veteran technician at my local Hyundai dealer: the PSF-3 cars from a few years ago could use ATF without a problem, but the newer cars with PSF-4 can only use PSF-4 (or a similarly-performing synthetic PSF).
#2412729 - 10/22/11 10:19 AM Re: Hyundai Power Steering Fluid PSF-3 [Re: gw105]
gw105 Offline
Loc: BC, Canada
Wow I'm glad they keep it simple and avoid confusion LOL. So I can use an ATF such as maxlife, or the new PSF-4. I wonder which would be a better choice? Plain old PSF is a no go then?
Can't wait until I swap out the manual tranny oil LOL
#2414563 - 10/24/11 11:04 AM Re: Hyundai Power Steering Fluid PSF-3 [Re: gw105]
mrdctaylor Offline
Loc: McGregor TX
I did some research on this and it seems that plain old PSF is fine--and what is even used/recommended at some dealerships. I drained/swapped using Super Tech PSF from Walmart and have had no issues.
12 Highlander 3.5L, 50K mi, TGMO 0W20
02 Tacoma 3.4L, 190K mi, QSUD 5W30
03 Santa Fe 2.7L, 195K mi, QSUD 5W30
02 Trailblazer 4.2L, 160K mi, QSAD 5W30
#2455684 - 12/07/11 10:56 AM Re: Hyundai Power Steering Fluid PSF-3 [Re: gw105]
blmqzjc Offline
Loc: Ormond by the Sea, FL
I've found with both my cars (Mitsu and Hyundai) there can be confusing specs for fluids (coolant, ATF, PS, etc.). I decided to just purchase them from the dealer's parts dept. It costs more than the stuff at AA or Autozone, but it's also stuff I only buy once every few years.
Try finding a coolant that is spec'd correctly for a Hyundai at an auto parts store. They probably would have to order it. I found it easier just to get the "Genuine Hyundai coolant" at the dealer for $20/gal., since it will last me 3 or 4 years anyway and the formulation is correct.
#2455694 - 12/07/11 11:09 AM Re: Hyundai Power Steering Fluid PSF-3 [Re: gw105]
JTK Offline
Loc: Buffalo, NY
We've had a few threads going on this topic over the years. Hyundai PSF-4 is supposedly a synthetic fluid, devised to reduce extreme cold start PS system noise. It's not that adding PSF-3 to your PSF-4 system will spell certain disaster, it's just that it will reduce the synthetic properties. Here's some info:
http://www.amdmaddness.com/sonata/tsb/power%20steering%20fluid.pdf
http://dcs.hyundaidealer.com/files/resources/msds/ch67.pdf
Joel
