17 yo deutsch filter?
by robo339
1 second ago
Ford Focus wrecked
by tig1
54 minutes 39 seconds ago
Valvoline Maxlife vs Supertech Synthetic vs QSED
by mazdamonky
Today at 09:56 PM
Lexus seats in a Camry
by Nick1994
Today at 09:52 PM
shop rechecking work after front end parts replace
by motor_oil_madman
Today at 09:50 PM
M1-EP vs vanilla M1
by Atomic
Today at 09:29 PM
Supertech Synthetic and Citgo
by RRLJR
Today at 09:28 PM
Gun Belt Wanted
by FirstNissan
Today at 08:24 PM
car wash soap for pressure washer
by Donald
Today at 08:16 PM
Deep tranny pan worth it?
by rsylvstr
Today at 07:20 PM
Which oil for my old BMW and why?
by fdcg27
Today at 06:20 PM
Synthetic blend for a Elantra
by car51
Today at 05:48 PM
Josh_Westwood, Brogan, Superlatives, Ruturaj, derfderfgoose
58280 Registered Users
67 registered (barkingspider, Bandito440, aquariuscsm, anonobomber, 2010Civic, 7 invisible), 1367 Guests and 10 Spiders online.
58280 Members
66 Forums
250853 Topics
Page 1 of 2 1 2 >
#2404420 - 10/12/11 08:59 PM Nissan Versa 2011 Oil suggestions - I'm perplexed
luv2rod Offline
Loc: Wisconsin, USA
Hi All, newbie to this forum. I'm an engineer/car buff and I must say that I'm perplexed by what I've been reading in some of the threads here, especially as it concerns synthetic verses conventional motor oil.
I've been a die hard Valvoline guy since I was a teenager and I am now 47. I've been through many repairs and have always been impressed by the cleanliness of a valvoline conventional oil motor. I can also say that I've never had a spun bearing or anything else related to poor oil or oil pressure happen to any cars I've owned. I always relpaced the oil every 3000-3500 miles, typically with fram or napa oil filter.
We have just purchased our first new car, a Nissan Versa with the variable auto trans. I need this to be a 200,000 mile car for us so I thought I would go to synthetic think it was better. The owners manual says that the oil requirements are SAE 5W-30 API or ILSAC with a 7500 mile oil change interval.
My wife drives this car where the shortest trip averages at least 25 miles, 25,000 a year. We live in southern Wisconsin, hot summers and cold winters. I hadn't switched to syn oil but did on this car for the first two oil changes which I did at 3500 miles each. I used Valvoline 5W-30 full synthetic. My thoughts were to switch to syn oil and change at the 7500 mile mark after the first two changes but some of the reading I've done perplexes me. What is right for this application? I need to keep the 100,000 warranty intact as well.
Thanks to all in advance. Gene
#2404429 - 10/12/11 09:10 PM Re: Nissan Versa 2011 Oil suggestions - I'm perplexed [Re: luv2rod]
FirstNissan Offline
Loc: KY
Welcome to BITOG!!!
Ive got a 2009 Versa sedan, 6MT, 1.8L. Its now got 27K on the odo, been trouble free thankfully. I drained factory fill at 1500 miles, then again at 3000 miles, after that ive been doing 5K oil changes with valvoline syn or pennzoil platinum. The syn oil has been a lot nicer in the Northeast winters, very cold starts, short trips.
Its hard to go wrong with a good quality syn, and since you arent stretching the miles inbetween very far, any good syn will be good.
I chose 5K oil changes since its between severe and normal "duty cycles" to keep in the warranty, just in case theres an issue. In your case, since you got the automatic, keep up on those transmission fluid changes, since the versa auto-boxes tend to give trouble down the line if not given a little bit of love!
Check out the versa forums, theres 2 of them, good maintenance stuff there.
Once again, welcome to the oil forum!
2015 Honda Accord LX 6MT
2012 Corolla LE
#2404430 - 10/12/11 09:11 PM Re: Nissan Versa 2011 Oil suggestions - I'm perplexed [Re: luv2rod]
kevinf Offline
Loc: Virginia
welcome
Over the past year there has been improved motor oil specifications and the vendors changed their formulas. GF-5, and API SN are the new standards. GM added a new certification called DEXOS1. The Valvoline White Bottle (VWB) you buy now meets GF-5 and SN. Your oil change interval is very conservative, your engine is not turbocharged or otherwise complex and you aren't towing or doing anything extraordinarily abusive. You can follow the manufacturer's recommendations. If your happy with VWB I'd stick with it.
Welcome to BITOG!
'07 Toyota Sienna - Castrol GTX 5W30
'01 Toyota Sienna - PP 5W30
'98 Acura CL 3.0 - G-Oil 5W30
#2404433 - 10/12/11 09:14 PM Re: Nissan Versa 2011 Oil suggestions - I'm perplexed [Re: luv2rod]
Blkstanger Offline
Loc: Lakeside, CA
My Daughter has a Versa. I have been using PP 5/30 in it since she picked it up. No problems at all with it @55k. Doing 6k OCIs on it.
Edited by Blkstanger (10/12/11 09:16 PM)
99 Jeep GC 4.7 156,000 PYB 10w30, Fram Ultra.
#2404434 - 10/12/11 09:15 PM Re: Nissan Versa 2011 Oil suggestions - I'm perplexed [Re: luv2rod]
Durango Offline
Loc: Los Angeles, California
luv2rod,
I'd keep using the Valvoline synthetic in the 5W-30 weight as you choose and be happy to drive it to 7500K OCI's. The synthetic will last that long easy but wouldn't go farther than that myself unless you decide to use an extended version.
Durango
#2404465 - 10/12/11 10:02 PM Re: Nissan Versa 2011 Oil suggestions - I'm perplexed [Re: luv2rod]
david_ES2 Offline
Loc: Fresno, CA
If i were keeping a vehicle long term i would keep using synthetic oil and viscosity grade that it calls for. you can't wrong with nearly any of them.
i think reading enough bitog makes most people wanna try different oil and filters to experiment or because they found it cheap or both.
Edited by david_ES2 (10/12/11 10:03 PM)
2004 Honda Civic EX K20Z1 5w30 PP WIX XP
#2404481 - 10/12/11 10:14 PM Re: Nissan Versa 2011 Oil suggestions - I'm perplexed [Re: david_ES2]
Donald Offline
Loc: Upstate NY
I agree, quite a few BITOG'es accumulate a stash of sale oil and mix & match as the stash wears down. My "stash" of oil is on the Walmart shelves.
There is a lot more to life than just car oil & filters. There is for example hydraulic oil and hydraulic oil filters!!
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#2404499 - 10/12/11 10:36 PM Re: Nissan Versa 2011 Oil suggestions - I'm perplexed [Re: luv2rod]
jorton Offline
Loc: San Antonio, TX
On such a high mileage vehicle, 25,000 miles per year, you should opt for 7500 mile oil changes, but not running Valvoline conventional. Go for the Synpower.
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
#2404511 - 10/12/11 10:58 PM Re: Nissan Versa 2011 Oil suggestions - I'm perplexed [Re: luv2rod]
vssjim Offline
Loc: McLean, Va.
I think you should stick with your life long Valvoline and I suggest staying with Napa GOLD filters. The Valvoline will be a fine choice and I would stay with a 5000 change cycle only because timing chains love good quality clean oil and I just don't want timing chain or guide wear. It maybe to often of oil changes but if something was to fail I would always wonder if I should have changed it more often. If you do all the service work and something fails there is nothing you could have done to stop it.
One thing to check out is the CVT Trans oil and it's service. If it is like the older CVT's they want 30,000 miles NISSAN only fluid changes and they want you to take off a cooler line and flush it with 15 to 18 quarts and the stuff was fifty dollars a quart. I would like to know what you find out about these 2011 models with CVT's.
#2404536 - 10/12/11 11:45 PM Re: Nissan Versa 2011 Oil suggestions - I'm perplexed [Re: luv2rod]
OldCowboy Offline
Loc: SW Missouri
Your wife's driving pattern is extremely easy on oil. There's no reason you can't use conventional SN 5W-30 with 7500 mile OCIs with this driving pattern.
#2404793 - 10/13/11 10:26 AM Re: Nissan Versa 2011 Oil suggestions - I'm perplexed [Re: luv2rod]
4x4chevydude Offline
Loc: Northern IL
I always say 3k on dino and 5k on a synthetic. It may be too early but i would rather have a well running car than to try and get all the life I can out of the oil.
2000 Chevrolet K2500 5.7 Old Body Style 6" Lift and 33" Tires 149k Miles
1998 Buick Century Limited 3.1 91k Miles
#2404822 - 10/13/11 10:47 AM Re: Nissan Versa 2011 Oil suggestions - I'm perplexed [Re: luv2rod]
someguy Offline
Loc: Austin, TX
I have also noticed lately that many people seem to recommend conventional oil and I suspect the economy and oil price increases have a lot to do with this. The reality is that you will spend about $30-40 more per year on synthetic if you DIY your oil changes. I also got a new car this year that I will likely keep for 10 years so its worth it to me to run full syn. If you want to keep the warranty intact then follow the manual, sounds like you are on the right track so far with oil. You might want to check out the oil filter section for recommendations on those.
#2404893 - 10/13/11 12:31 PM Re: Nissan Versa 2011 Oil suggestions - I'm perplexed [Re: someguy]
JOD Offline
Loc: PNW/WA
I'm not sure that's the reason. The new SN/GF-5-rated oils have more stringent requirements for robustness and deposit control, which matches up with the longer OCI's recommended by most major car manufacturers. So, the 'conventional' oil you buy now is simply a lot better than it used to be, and more suitable for a longer interval. There are a ton of conventional SN/GF-5 UOA's on here to support that position.
For the car in question, a 7.5K OCI with those driving habits? I'd use any SN rated 5-30 and call it day--and change it at 7.5K just to avoid potential warranty hassles.
#2404897 - 10/13/11 12:35 PM Re: Nissan Versa 2011 Oil suggestions - I'm perplexed [Re: luv2rod]
luv2rod Offline
Loc: Wisconsin, USA
Thanks to all for the many suggestions. Although I'm a bit surprised by the number of different opinions.
Is Synpower the same as the Valvoline 5w-30 full synthetic? I need to stay with 5w-30 for warranty purposes.
I know syn oil costs more. But I figured that if I can go to 7500 mile oil changes it will be a wash. I do use the Napa Gold Filter. Does this long term plan with Valvoline 5w-30 full synthetic sound good? For me, long engine life is the most important thing.
Thanks again!!
#2405322 - 10/13/11 08:28 PM Re: Nissan Versa 2011 Oil suggestions - I'm perplexed [Re: luv2rod]
chainblu Offline
Loc: Florida
Even at 7500 miles, you're still looking at only 3 to 4 month OCI. While I agree with the others that the standard Valvoline (white bottle) would certainly be up to the task, I think for YOUR peace of mind you should stick with the full synthetic.
So yes, your thinking is sound. smile
Page 1 of 2 1 2 >
