Tacoma Extended OCI
by 13Tacoma
06/29/16 01:07 PM
Gear oil mixed in with Diesel Engine Oil ...
by Miller88
06/29/16 12:07 PM
DELO ELC Antifreeze/Coolant??
by Griz95
06/29/16 12:06 PM
Higher oil pressure. Oil? Filter? Jeep 4.0
by RegDunlop
06/29/16 11:16 AM
NJ's gas tax increase
by Whimsey
06/29/16 11:11 AM
PAO in Mobil 1 0w-40
by loneryder
06/29/16 10:33 AM
2010 Porsche Boxster S, Mobil 1 5w50, 4,700 miles
by Croc
06/29/16 10:18 AM
Amsoil announces 6% price hike
by Kuato
06/29/16 09:28 AM
737 NG
by SEMI_287
06/29/16 09:10 AM
ACDelco vs Valvoline oil filter
by mbar1
06/29/16 08:21 AM
Valvoline Premium Blue RestoreTM
by Rat407
06/29/16 08:16 AM
Dealer says 07 Highlander has strainer. Nope!
by CapitalTruck
06/29/16 08:04 AM
dpaldino, T_Bortz, rebelx, dougsangster, CrazyCalvinW
58314 Registered Users
97 registered (alphadog, 13Tacoma, Al, ARCOgraphite, aquariuscsm, 9 invisible), 1983 Guests and 10 Spiders online.
58314 Members
66 Forums
250982 Topics
Page 1 of 2 1 2 >
#2400697 - 10/09/11 09:16 AM Kia rio transmission oil change or flush ?
Baveux Offline
Loc: Québec
We reached the point where we have to service the automatic transmission on my son,s Kia rio 2007.
The oil pan have a nice drain plug at the bottom, however I wonder if just draining and refilling the tranny a few times will be good enough ?
If so how many times should I drain and refill ? Should I run the tranny through all the lever position prior all the drain and refill sequence ? How long should I let it run ? Or better should I go for a ride? and for how long before draining and refilling ?
The garage charge $150.00 fro the drain flush and refill. I think its a lots of money for that.
BTW the tranny required a special oil that you can find only at the kia hyundai dealer ,it is true ? cant remember the name but I think its something like sp3 ....
Millions of thanks for your help guys
Edited by Baveux (10/09/11 09:17 AM)
#2400703 - 10/09/11 09:21 AM Re: Kia rio transmission oil change or flush ? [Re: Baveux]
Barkleymut Offline
Loc: Richmond, VA
I would definetely drive it so that you get the fluid through the torque converter. Get it up to 60 MPH and keep it there for a few minutes. Drain and fill again and then wait a few years and repeat.
09 Vue(95K) 2.4 4spd AT -PU 5w30 / 09 Flex(52K)3.5L PU / Moms car 04 Pilot(105K) 5w20 PP + Puro
#2400704 - 10/09/11 09:22 AM Re: Kia rio transmission oil change or flush ? [Re: Baveux]
4x4chevydude Offline
Loc: Northern IL
KIA and Hyundai do take SPIII and its not really special oil persay its just spec rated....you can find Castrol Multi Import ROyal Purple and many others that can replace it, just look at the back of the bottle and it should say what the fluid is speced for and if SP III is on there you will be good. As far as drain and fills you can drain it and drive it until the next Oil change and then do it again. I think 2 dain and fills should be sufficient for it especially if its well taken care of.
2000 Chevrolet K2500 5.7 Old Body Style 6" Lift and 33" Tires 149k Miles
1998 Buick Century Limited 3.1 91k Miles
#2400716 - 10/09/11 09:40 AM Re: Kia rio transmission oil change or flush ? [Re: Baveux]
fdcg27 Offline
Loc: OH
How many miles?
The weakness of drain/fill or a flush is that the pan is not removed, meaning that you aren't cleaning wear debris out of the pan nor are you replacing the filter.
I think I'd drop the pan, clean it and replace the filter for the first drain, and then maybe do another short, oil change length drain/refill.
12 Accord LX 45K TGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 155K Defy 10W-40
#2400761 - 10/09/11 10:31 AM Re: Kia rio transmission oil change or flush ? [Re: Baveux]
jcwit Offline
Loc: no. indiana
There used to be a chart that gave how many drain and fills left how much of the old oil in the tranny. Can not find it any more, but in my KIA Rio IIRC 4 drain and fills replaced 98% with new fluid.
Not sure about an 06 KIA but mine hase no filter to replace, yours may be different.
I now do a drain and fill every other oil change, may not be needed that often but its they way I do it.
#2400770 - 10/09/11 10:41 AM Re: Kia rio transmission oil change or flush ? [Re: fdcg27]
HyundaiGuy Offline
Loc: Orlando, FL
Originally Posted By: fdcg27
How many miles?
+1
'15 Fiat 500 Abarth Black 9K PU Euro 5W40 OEM Filter (Mine)
'13 Fiat 500 Sport Pearl White 16K PP 5W30 OEM Filter (Hers)
#2400771 - 10/09/11 10:41 AM Re: Kia rio transmission oil change or flush ? [Re: Baveux]
Dan55 Offline
Loc: jersey
Are you still under warranty?
2016 Lexus NX200T 07 Fit Sport 05 Mazda 3S
#2400822 - 10/09/11 11:27 AM Re: Kia rio transmission oil change or flush ? [Re: Baveux]
Loc: Northern IL
Kia Rio has no filter to change and I believe the pan on those is very hard to access which is why there is a convenient drain plug.
#2400874 - 10/09/11 12:29 PM Re: Kia rio transmission oil change or flush ? [Re: 4x4chevydude]
HyundaiGuy Offline
Loc: Orlando, FL
I was wondering about this. The way I understood it, the Rio and the Accent are mechanically identical.
My Accent has a pan, a filter, and no drain plug. The transaxle is sourced from Mitsubishi if I recall correctly.
I wonder if the Rio has a different transaxle.
#2400893 - 10/09/11 01:05 PM Re: Kia rio transmission oil change or flush ? [Re: Baveux]
Donald Online   content
Loc: Upstate NY
Sounds like a transmission in need of a Magnefine inline filter. I would do 2 preferably 3 drain & fills. If you have the coin, your transmission will thank you if you use a high end synthetic ATF.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#2401266 - 10/09/11 08:22 PM Re: Kia rio transmission oil change or flush ? [Re: Baveux]
jcwit Offline
Loc: no. indiana
http://www.rockauto.com/catalog/raframecatalog.php?a=NewsletterLink
Check here! Rock auto lists a filter and gasket for the 07 Kia Rio with an auto tranny.
#2401539 - 10/10/11 07:22 AM Re: Kia rio transmission oil change or flush ? [Re: Baveux]
Baveux Offline
Loc: Québec
Thanks fo ther link JCWIT !!
Thanks to all for your information guys !!
We will not spend 150.00 for the flush despite the fact that we are probablty not changing all the oil 4 new liter is not going to hurt ,too many tranny flush horror story are steering me away from that procedure
#2401574 - 10/10/11 08:26 AM Re: Kia rio transmission oil change or flush ? [Re: Baveux]
Loc: Upstate NY
There are no tranny flush horror stories where the transmission had its filter changed and flushed if the transmission was in good shape to start. Now some places will say that the cleaner they use along with a flush will clean the filter, it may clean it of some liquidy sludge but cannot clean the filter of the particles of crud it trapped.
#2412015 - 10/21/11 11:22 AM Re: Kia rio transmission oil change or flush ? [Re: Donald]
Rand Offline
Loc: NE,Ohio
both of my gf's 2001 and 2010 accents have drain plugs.
I thought that the filter was only accessible by removing the trans and splitting the case?
2015 Forester I-Premium 6MT
#2425351 - 11/04/11 07:43 PM Re: Kia rio transmission oil change or flush ? [Re: Rand]
sittingduck57 Offline
Loc: tenn
Thats pretty handy,two girlfriend's with Accents!
Page 1 of 2 1 2 >
