5.4 3V under valve cover pics & solenoid failure
by 04SE
05/28/16 03:50 PM
New safety spec for 2017 F1 cars...
by mcrn
05/28/16 03:35 PM
M1-101 after 10k on a 95 Sunfire 2.2 OHV pushrod
by slacktide_bitog
05/28/16 03:18 PM
Base Oil Content and Marketing
by MolaKule
05/28/16 03:08 PM
Best OTC fuel injector cleaner
by 007
05/28/16 03:06 PM
A brief BMW R1100RT story
by Finn
05/28/16 02:29 PM
2015 6.7L Powerstroke Fuel Filter Change
by 2015_PSD
05/28/16 12:51 PM
Caliper question
by supton
05/28/16 12:48 PM
Impressed with Yokohama Geolander A/T G015
by K20FA5
05/28/16 12:13 PM
Need a good tire pressure guage that read over 60
by MetalSlug
05/28/16 11:55 AM
Castrol 0w40 vs M1 0w40 FS ?
by Ndx
05/28/16 11:14 AM
what old Snapper parts to save
by edwardh1
05/28/16 10:56 AM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
79 registered (04SE, A310, 2015_PSD, AIRJAC3, Al, 87sammy, 6 invisible), 1593 Guests and 339 Spiders online.
58001 Members
66 Forums
249530 Topics
#2388923 - 09/26/11 09:25 PM 2000 Jeep Cherokee What To Use In Differential
crazyoildude Offline
Loc: New Jersey
what do i use in the front and real differential on a 2000 Jeep cherokee and do i need a friction modifier in the rear?
What weight do i use? How can i tell if it is a limited slip differential??
#2388927 - 09/26/11 09:33 PM Re: 2000 Jeep Cherokee What To Use In Differential [Re: crazyoildude]
mopar_monkey Offline
Loc: oregon
lsd will have a metal tag held on by one of the diff cover bolts if dana, if chysler axle they often have a tag wrapped around the axle tube on the right side directly behind the brake cover. 80w90 should be just fine maybe 75w140 if you wheel it or put a lot of load on it.
Edited by mopar_monkey (09/26/11 09:35 PM)
#2388953 - 09/26/11 09:58 PM Re: 2000 Jeep Cherokee What To Use In Differential [Re: crazyoildude]
Kuato Offline
Loc: In transit...
Have a look here:
http://www.amsoil.com/mygarage/vehiclelookup.aspx
Diff fluid to use depends on your engine and 4wd system. I've found that the Amsoil spec charts are very accurate.
You can tell if it's limited slip by using the following test:
1. Jack up vehicle by rear differential (front wheels chocked)
2. Put transmission in neutral
3. Turn one rear wheel forward. If the other turns backward, you have an open differential. If the other side turns forward, it's a limited slip.
Your oil's condition is pure speculation until you get a UOA.
13 F150 5.0, 48k mi
04 Wrangler 2.4, 197k mi
Current fills Amsoil/Amsoil
#2388988 - 09/26/11 10:25 PM Re: 2000 Jeep Cherokee What To Use In Differential [Re: crazyoildude]
jeepman3071 Offline
Loc: Storrs, Connecticut
An open differential is on the left hand side. Limited slip is shaped more like a cylinder and is on the right. thumbsup
2000 Jeep Cherokee Sport 4.0L (163k) - Pennzoil HM 10w30, Napa Gold 1516, Magnefine trans filter
#2391379 - 09/29/11 01:05 PM Re: 2000 Jeep Cherokee What To Use In Differential [Re: jeepman3071]
Kira Offline
Loc: Champlain/Hudson Valley
Hello, Thanks for the illustrative pics. Is the reason the LSD is "squarer" because that's where the stacks of cluch discs are? When I changed the fluid in my sister's 1999 Cherokee's differentials at 150K I couldn't believe the amount of grit in each. When you do this job schedule time for cleaning. I used Amsoil synthetic Gear Lube 75-90. So far, so good. Kira
#2392006 - 09/30/11 05:56 AM Re: 2000 Jeep Cherokee What To Use In Differential [Re: crazyoildude]
Donald Offline
Loc: Upstate NY
Stop at the dealer with your VIN and ask for a copy of the vehicle off their Star Network. Its free and takes only a minute. It will tell you everything that went into your vehicle at the factory.
+1 on the Amsoil Severe Gear.
Have you changed the transfer case?
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- 4-sale
1999 Dodge Ram 2500 w/Cummins- 4-sale
#2392046 - 09/30/11 07:15 AM Re: 2000 Jeep Cherokee What To Use In Differential [Re: Donald]
Kira Offline
Hello, To Donald: If you're asking me, it wasn't Severe Gear. It was the most basic Amsoil Gear Lube and yes, I changed out the transfer case using jug DexMerc from the auto parts store. My sister uses her 4WD so infrequently I figured I'd let the cheap stuff rinse the transfer case for a while before considering any synthetic fluid. Kira
