Help with iphone on the home network
by buck91
05/06/16 06:45 AM
2003 lesabre battery change back seat type
by snake123
05/06/16 05:43 AM
Penrite 0w-16
by toyota62
05/06/16 03:31 AM
Land Cruiser stuck in mud, rescued by hemi Jeep
by Shannow
05/06/16 02:53 AM
GM to test self-driving taxis
by xfactor9
05/06/16 01:09 AM
Resurfacing Brake Rotors
by The Critic
05/06/16 12:02 AM
Largest M1 filter for Jeep 4.0
by ARMY_Guy
05/05/16 10:50 PM
Mobil 1 or Castrol edge?
by sky06
05/05/16 09:48 PM
1 piece lug nut recommendations?
by dlundblad
05/05/16 09:07 PM
1996 Chrysler Coolant
by outoforder
05/05/16 09:02 PM
Hat Tip to RMEuropean
by sleddriver
05/05/16 08:54 PM
Toro OHV considered flat tappet type...
by Duffyjr
05/05/16 08:48 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
76 registered (askani79705, AirgunSavant, aquariuscsm, 97f150, Asterix, 2015_PSD, 9 invisible), 0 Guests and 1 Spider online.
57814 Members
66 Forums
248539 Topics
Page 1 of 3 1 2 3 >
#2388782 - 09/26/11 07:15 PM How Safe Are Tire Plugs?
CROWNVIC4LIFE Offline
Loc: Miami-Dade County
I am constantly picking up nails..Right now I have a plug in every tire..Two of the tires are new as they are less then a month old..Tonight I found 2 nails in one of my front tires..I feel like I spend half of my life getting tires repaired..I have severe blowouts every couple of months..I was wondering if the plugs contribute to the blowouts..A couple of times the tires that blew had zero plugs in them but most of the time they already have plugs in them..I have no idea what caused the blowouts cause by the time on get over on the shoulder half of my tire is shredded on I-95.
On my last set of tires I had about 16 plugs between all 4 tires..Going down I-95 I always see cars on the side of the road with flat tires.
Thanks in advance.
05 Ford Crown Vic
5W20 Motorcraft Full Synthetic
Bosh D3410 Filter
07 Merc Grand Marquis
Motorcraft Filter.
#2388787 - 09/26/11 07:19 PM Re: How Safe Are Tire Plugs? [Re: CROWNVIC4LIFE]
FordFocus Offline
Loc: Michigan, USA
Do not use plugs, they can cause separations, they can fall out or dry out and leak slowly. If possible have a patch and plug installed.
2001 Ford Taurus
215/60R16 Michelin X-ice xi3
#2388788 - 09/26/11 07:19 PM Re: How Safe Are Tire Plugs? [Re: CROWNVIC4LIFE]
JHZR2 Offline
Loc: New Jersey
Are you a roofer?
Amazing how many nails youve gotten. Seems a bit much.
Would I use the tires for around-town duty? I guess. For sustained high-speed driving? Probably not after theyve had multiple plugs.
Id only have plugged tires on the rear axle.
What kind of tires do you usually run? My father was getting a lot of nails for a while, and he went to some tires that had less siping, and no more issues. In FL, I wonder if you need siping, given lack of ice. Perhaps you could do better with a blockier tread?
#2388799 - 09/26/11 07:29 PM Re: How Safe Are Tire Plugs? [Re: CROWNVIC4LIFE]
2cool Offline
Loc: Delaware
It depends on the plug. The Rubber Manufacturers Association (tire makers) says if you demount the tire and use a mushroom style plug from the inside out, the mileage warranty on your tires will be maintained.
The usual ribbon plug most of us mean is strictly in the skill of the plugger. In any event, a plugged tire should NOT be relied upon for the full amount of weight and performance as an uninjured tire.
For example, if you normally drove 75-80 on the tire when new; after the plug I'd do no more than 65-70. I'd put the plug on a non-driven wheel if possible, and my guess is no more than 75%of the rated load. Remember, this information is worth the price you've paid for it; and should not be regarded as an expert opinion.
#2388800 - 09/26/11 07:29 PM Re: How Safe Are Tire Plugs? [Re: CROWNVIC4LIFE]
eljefino Offline
Loc: ME
I had one that lasted five plus years and one that lasted two weeks. I have to look at the installer in the mirror every morning.
I hit a nail with a borrowed tractor. Air started coming out six holes! That side, someone gave up on the tire and put a tube in, so when I poked the tube, it went nuts leaking air. The opposide side was tubeless, I checked.
#2388802 - 09/26/11 07:31 PM Re: How Safe Are Tire Plugs? [Re: JHZR2]
Originally Posted By: JHZR2
Are you a roofer?
What kind of tires do you usually run? In FL, I wonder if you need siping, given lack of ice. Perhaps you could do better with a blockier tread?
Right now I have Michelin Symmetry..No roofer but there is alot of construction going on everywhere here..A blockier tread might work but for right now these tires are mostly new.
05 Ford Crown Vic
Bosh D3410 Filter
Motorcraft Filter.
#2388804 - 09/26/11 07:32 PM Re: How Safe Are Tire Plugs? [Re: CROWNVIC4LIFE]
qdeezie Offline
Loc: Charlotte, NC
I've never had problems with tire plugs. Whenever I've had a plug that leaks because the hole is larger than usual, I just double up the plugs on the installer tool and it seals it up perfectly.
'90 F150 XLT Lariat | PU 5w-30 & RP Filter
'13 Hyundai Elantra Coupe SE | PU 5w-20 & OEM Filter
'03 Ford Focus ZX3 | Conv. Shell 5w-20 & OEM Filter
#2388805 - 09/26/11 07:33 PM Re: How Safe Are Tire Plugs? [Re: CROWNVIC4LIFE]
tig1 Offline
Loc: Illinois
Crownvic,
Lots of flats, yikes! I rarely have a flat, but the tire shop I go to marks where the balance weights are on the rim, removes the tire, and patches the hole from the inside. I've never had a problem when it was fixed this way.
2007 Ford Fusion 179,000 miles
M1 0-20 AFE
2007 Ford Focus 153,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#2388812 - 09/26/11 07:37 PM Re: How Safe Are Tire Plugs? [Re: CROWNVIC4LIFE]
bullwinkle Offline
Loc: Cincinnati, OH, USA
I've personally never had a problem with mushroom plugs, rope plugs are hit or miss-if I had as much trouble as you have had I would carry a mushroom plug kit with me along with a small air compressor and fix them whenever i had a problem. Or be sure I had a good road hazard warranty to get them fixed.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(CQ Blue)
#2388813 - 09/26/11 07:39 PM Re: How Safe Are Tire Plugs? [Re: CROWNVIC4LIFE]
HTSS_TR Offline
Loc: Lake Forest, CA
Tire place I go to marks where the valve stem is on the tire, patch inside then remount without re-balance. Never had problem after repaired, cost was $5 per repair for regular wheel and $10 for expensive wheel/car.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#2388822 - 09/26/11 07:48 PM Re: How Safe Are Tire Plugs? [Re: CROWNVIC4LIFE]
JHZR2 Offline
Loc: New Jersey
Are you a roofer?
Those are highly siped.
My father always mentioned that Michelins, though good tires were more prone to picking up nails. It is highly UN-scientific, just his experience and noted pattern.
Theyre running primacies on his 300D and symmetry on her breeze right now though...
#2388824 - 09/26/11 07:49 PM Re: How Safe Are Tire Plugs? [Re: HTSS_TR]
JRed Offline
Loc: Virginia
Hey - that's a great idea! I should ask my local tire shop if they can do that. I've got a slow leak and I'm debating between having it plugged a third time or just replacing the tire.
Hm... Good excuse to buy winter tires!
06 Subaru Impreza WRX - Sold. The only mechanical thing I'll ever love.
07 Toyota Prius - Cheap synthetic and PureOne filters.
#2388838 - 09/26/11 07:56 PM Re: How Safe Are Tire Plugs? [Re: CROWNVIC4LIFE]
AlienBug Offline
Loc: Connecticut
I used to run a brake and muffler shop next door to a busy gas station. I had a little cottage industry going on the side, plugging tires for a couple bucks cash. I bought shoestring plugs in boxes of 50 and probably plugged more than 100 tires (including my own once). Never heard of anyone having a problem. Not to say no one ever did, but I never heard about it. It was a good little gig, 5 minutes and I had lunch money.
Don
2005 Ford Freestyle SEL, 151k, Motorcraft 5w20 synblend, Motorcraft filter
2007 Ford Fusion SE 2.3l, 118k, Mobil 1 EP 0w20, Motorcraft filter
#2388864 - 09/26/11 08:12 PM Re: How Safe Are Tire Plugs? [Re: CROWNVIC4LIFE]
Colt45ws Offline
Loc: Central Washington
I would only run a rope plug in an emergency. Prefer to use plugand patch from tje inside of the tire.
-Colton
2002 Ford Crown Vic PI, 180k "Highwayman"
Ex-Kootenai County, ID Unit #42
Maxlife 5W20
Lubegard Bio/Tech oil treatment
Ultra XG2
#2388866 - 09/26/11 08:14 PM Re: How Safe Are Tire Plugs? [Re: CROWNVIC4LIFE]
Chris142 Offline
Loc: apple valley, ca
I've used string plugs all my life. Never had a problem with any of them but I drive slow cars and not Corvetts.
Plugs are a godsend for the jeepers and quad riders. Jeepers often slash a tire off road and a bunch of plugs will hold air well enough to get off the trail.
Quad tires are a terrible Job to break down and they flex so much that an inside patch won't stay put very long so a plug is a no brainer.
Of course I wouldn't use a plug on a motorcycle tire or a fast car thats driven fast. But they are great for my Jeep and quad.
The problem with plugs and flats is that often a tire gets run flat and has internal damage. Putting in a plug and driving on the damaged tire is very dangerous. This is why tire stores break the tire down......To see if theres internal damage.
But if you come out from work and see a nail and you know the tire wasn't ran flat a plug is ok unless your going racing.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
Page 1 of 3 1 2 3 >
