Some Porsche 911 Love
by zloveraz
2 seconds ago
How much are you paying for TC-W3?
by BrewCityR
Yesterday at 10:51 PM
Long term use of Honda OEM oil filters
by gregk24
Yesterday at 10:35 PM
MMO, again
by CourierDriver
Yesterday at 09:56 PM
Discount Tire Direct pre 4th of July sale
by stephen9666
Yesterday at 09:36 PM
Lense recommendation for a Canon 60D body?
by Kruse
Yesterday at 09:32 PM
Questions about Toyota Celica GT/GTS
by Lillikai
Yesterday at 09:21 PM
Is Royal Purple API-licensed dexos1-licensed?
by barlowc
Yesterday at 09:06 PM
Supertech High Mileage ATF
by TechnoLoGs
Yesterday at 08:46 PM
WTB: 1 or 2 quarts of Honda Z1 atf
by vinu_neuro
Yesterday at 08:40 PM
12' Ford Super Crew 3.5 Ecoboost - what oil ??
by Boost00
Yesterday at 08:31 PM
2000 lincoln conti floorboards flooding ?????
by OtisBlkR1
Yesterday at 07:59 PM
Snowball, jin1234, BigDuke6, gl10, ufomorme
45904 Registered Users
22 registered (ARB1977, 901Memphis, cak446, gfh77665, Art_Vandelay, 1 invisible), 496 Guests and 228 Spiders online.
45904 Members
64 Forums
195331 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
Page 1 of 2 1 2 >
#2384894 - 09/22/11 01:48 PM Motortrend article: GDiesel
NateDN10 Offline
Loc: Rochester, NY
Article link.
Reads like an advertisement. Couldn't find any papers on it on Google Scholar.
This alternative fuel at least has a bit of science and testing behind it. As with many of these alternative fuels, it sounds great. Time will tell if there's anything to it.
2005 Chevrolet Cobalt (74K mi.) - Motorcraft Syn Blend 5W-20
2007 Subaru Outback (96K mi.) - QSUD 5W-30
#2384905 - 09/22/11 01:56 PM Re: Motortrend article: GDiesel [Re: NateDN10]
sasilverbullet Offline
Loc: San Antonio, Tx
Interesting...I'll wait for you guys to chime in with expert opinions...
70 Lincoln Mk III - Delo 15W-40
03 VW Jetta TDI - Rotella T6 5W-30
04 Nissan Titan - Amsoil 5W-30 XL
#2384912 - 09/22/11 02:06 PM Re: Motortrend article: GDiesel [Re: NateDN10]
Astro14 Offline
Loc: Virginia Beach
Sorry...the [censored] detector is blinking...the science doesn't make sense to me from a pure physics (BTU/Gallon) perspective...at 20% improvement based on what? "gas molecules to chemically bond with the liquid?"
Huh?
You added methane (one more carbon) to diesel (typically 14, but anywhere from 8-20 carbons) and you get 20% more energy and all the wonderful benefits, because you end up with a more uniform distribution of hydrocarbons? I'm not even convinced that the 250 temps would enable the reaction...much less result in more uniform hydrocarbons...
Snake oil.
Edited by Astro14 (09/22/11 02:07 PM)
32 Packard 15W40
90 4Runner 10W30 Edge
92 300E 5W40 Syntec
02 Volvo V70 T5 5W40 M1
02 Volvo V70 XC 5W30 PU
05 MB S600 M1 0W40
06 Corolla 5W30 Edge
#2385010 - 09/22/11 04:25 PM Re: Motortrend article: GDiesel [Re: NateDN10]
danthaman1980 Offline
Loc: SE Wisconsin
The article appears to give a rather crude explanation for the process... clearly, the assertion that they are "causing gas molecules to chemically bond with the liquid" implies something entirely different than what is actually going on.
In actuality, the process they are describing seems to be similar to hydroisomerization (although not quite the same, since the GDiesel article claims they are using natural gas rather than hydrogen). My guess is that they found a way, using metal catalysts plus a slight amount of heat and pressure, to achieve a similar result using natural gas instead.
My guess is they end up turning ULSD into something more similar to Isopar M.
And since technically they would be 'rearranging' the molecular structure, they could now call it 'synthetic diesel' when they are done. They could thank Castrol for that.
2003 Chevy Silverado 1500 5.3 LS Quadrasteer ~205,000 miles
2014 Mazda6 Sport 2.5 Skyactiv ~1005 miles
#2388135 - 09/26/11 08:13 AM Re: Motortrend article: GDiesel [Re: NateDN10]
Cujet Offline
Loc: Jupiter, Florida
Ahh, Number 2 diesel "soda". If you shake it, does it foam? smile
The energy content of a fuel is directly related to it's specific gravity. Gasoline and diesel have remarkably similar energy content by weight. However, when measured by the gallon, Diesel wins.
I suspect that this addition of natural gas is simply offsetting some of the energy content lost during the production of ULSD. I'd love to see some objective data. Some reports claim ULSD is down 7% in energy content. I suppose it varies by refinery, but it is universally agreed to be down on energy content.
Turbo's rule.
#2390346 - 09/28/11 01:36 PM Re: Motortrend article: GDiesel [Re: NateDN10]
edhackett Offline
Loc: Reno, Nevada
I can do a controlled, precision fuel consumption test. I have access to the CDC/EPA research diesel. I can measure fuel consumption to 0.1 gram/time interval. It'll need to be a one shot, rather quick test, as I need to work it in between projects at the end of next week.
Here's what I propose:
The diesel is a 1.5L Isuzu powering a 12.5Kw generator. It is connected to a load bank that we can control the load from 250w-15Kw. The control diesel will be Shell ULSD. I'll run at 50% of rated sea level load, 6250 watts, which is a bit under 60% load at this altitude.
Measure density of both fuels at test temperature.
Warm up generator under no load, then operate for 20 minutes at load to stabilize temperatures. Switch to weighed fuel container and run for 1 hour at 6250 watts. Purge fuel lines. Switch to GDiesel and run for 20 minutes at 6250 watts to fully flush lines and stabilize temperatures. Switch to weighed fuel container and run for 1 hour.
There will be ~3L of fuel burned per hour. At 0.1 gram resolution that's 0.0033% resolution.
Anybody think that this test isn't robust enough to discern 0.1% differences in fuel consumption? Suggestions? Remember, I'm only going to have an afternoon to do this.
Ed
Never attribute to engineers that into which politicians, lawyers, accountants, and marketeers have poked their fingers.
#2390390 - 09/28/11 02:11 PM Re: Motortrend article: GDiesel [Re: NateDN10]
Skid Offline
Loc: USA
The article says "Without getting overly detailed about the patented ClearRefining catalytic process, it facilitates the attachment of hydrogen in natural gas to the carbon chain of diesel molecules."
Here's a link to some text files of patents bearing Gunnerman's name. You can use Google to view patents with the drawings.
http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO2&Sect2=HITOFF&u=%2Fnetahtml%2FPTO%2Fsearch-adv.htm&r=0&p=1&f=S&l=50&Query=in%2Fgunnerman%0D%0A&d=PTXT
#2390406 - 09/28/11 02:22 PM Re: Motortrend article: GDiesel [Re: NateDN10]
Skid Offline
Loc: USA
Here is a link to pre-grant patent application publications bearing Gunnerman's name:
http://appft1.uspto.gov/netacgi/nph-Parser?Sect1=PTO2&Sect2=HITOFF&u=%2Fnetahtml%2FPTO%2Fsearch-adv.html&r=0&p=1&f=S&l=50&Query=in%2Fgunnerman&d=PG01
The first one might be it: No. 20110163007
It's titled "NON-FRACTIONATION PROCESS FOR PRODUCTION OF LOW-BOILING FUEL FROM CRUDE OIL"
Goto:
http://www.google.com/patents
paste 20110163007 in the field, and it will pop up.
Definitely out of my area of expertise, if I have one at all...
#2390422 - 09/28/11 02:36 PM Re: Motortrend article: GDiesel [Re: edhackett]
NateDN10 Offline
Loc: Rochester, NY
Ed
I'd really like to see this. In the linked article they reported 20-50% reduction in fuel consumption. I think your 0.1% resolution will be fine, and better in any case than the highly variable road vehicle figures they give.
#2391032 - 09/29/11 04:07 AM Re: Motortrend article: GDiesel [Re: NateDN10]
Shannow Online   content
Loc: a prison island
Ed, I would really appreciate the test.
Different scenario, but there are diesel/propane conversions down here that offer 25% savings in diesel consumption, basically offing that the propane is free...the claim that this makes diesel last longer is prolly right, only if the NG is negated.
Not everything is a conspiracy...
Only the important stuff ontome
#2392789 - 09/30/11 09:19 PM Re: Motortrend article: GDiesel [Re: NateDN10]
edhackett Offline
Loc: Reno, Nevada
5 gallons of GDiesel procured at lunch. I'm hoping to get this done on Friday. It also turns out there is going to be a window in the GC-MS schedule on Wednesday. Fun, fun.
Shannow, we had a guy come through here with the answer to diesel emissions. It was a diesel powered afterburner. The claim was that it lowered emissions without effecting mpg. It worked after a fashion at reducing NOx, but for some reason the fellow just didn't grasp that the fuel burned by the afterburner had to be included in the mpg figures. In the case of the 1.5L Isuzu, the afterburner burned more fuel than the engine.
Ed
#2396271 - 10/04/11 05:25 PM Re: Motortrend article: GDiesel [Re: edhackett]
2cool Offline
Loc: Delaware
Thanks for the test, Ed. I'm wondering if this stuff will become widely available.
#2399720 - 10/08/11 06:50 AM Re: Motortrend article: GDiesel [Re: NateDN10]
Cujet Offline
Ed,
Of course we'd like to see "actual" results!
Also specific gravity specs.
Turbo's rule.
#2400094 - 10/08/11 03:57 PM Re: Motortrend article: GDiesel [Re: NateDN10]
edhackett Offline
Loc: Reno, Nevada
Coming up soon. The control sample is running as I type. I have specific gravity and calorimetry done. I'll have the consumption data later today. The GC-MS was being a bit cranky about being switched from thermal desorbtion to liquid mode. Hopefully I'll have that on Monday.
I'll post the results in a new thread in this section.
Ed
#2403052 - 10/11/11 02:19 PM Re: Motortrend article: GDiesel [Re: NateDN10]
edhackett Offline
Loc: Reno, Nevada
A quick update: I got the GC-MS data on Saturday. It was "interesting" to be sure. I re-ran the consumption test on Sunday to get an idea of the repeatability of the system. A new control from a different source and two new GDiesel samples from two different GDiesel branded stations was obtained on Monday. Testing of those samples is in progress.
Ed
Page 1 of 2 1 2 >
