I got a new to me 2011 Impala, advice?
by gfh77665
1 minute 54 seconds ago
Guy drinks STP OIL TREATMENT
by FordCapriDriver
7 minutes 43 seconds ago
2006 Hyundai Tucson - plastic in the pan
by OVERKILL
23 minutes 4 seconds ago
AC = bad
by gman2304
26 minutes 5 seconds ago
Refrigerator top light not working
by PandaBear
29 minutes 51 seconds ago
EGR and braking
by otis24
31 minutes 28 seconds ago
Replaced 109S with 114T; pressure recommendations
by George Bynum
36 minutes 50 seconds ago
Old oil for edger oil change
by brian_06328
59 minutes 22 seconds ago
Best Concealed Holster
by alanwayne1908
Today at 12:57 PM
Peak Global Life for 2010 Toyota Highlander V6
by mctmatt
Today at 11:58 AM
Michelin X Ice xi3 vs General Altimax Arctic
by Drew99GT
Today at 09:29 AM
Coat battery terminals with something or leave dry
by callbay
Today at 09:11 AM
SonofJoe, Axle_Needle, discobob, KHump, Zounds
58573 Registered Users
75 registered (02s4audi, Al, 01_celica_gt, AirgunSavant, 4WD, 2015_PSD, 6 invisible), 2064 Guests and 12 Spiders online.
58573 Members
66 Forums
252152 Topics
Page 1 of 3 1 2 3 >
#2383875 - 09/21/11 02:00 PM Turn off power to central A/C for winter?
Quattro Pete Offline
Loc: Great Lakes
I get these occasional home reminder/advice tips from Manage My Life. Half of the time it doesn't make any sense to me. Today they recommend turning off power to central A/C for winter:
http://www.managemylife.com/mmh/articles/authored/off-the-power-to-your-ac
It says:
Quote:
Do one of the following:
- On your main electrical panel, locate the fuse or breaker marked "air conditioner." Remove the fuse or flip the breaker to Off.
- Flip the handle on the outdoor shutoff near the compressor to the Off position.
In my house, the A/C and heater is part of the same system and therefore I don't have a separate circuit breaker just for A/C. There is also no handle of any sort to be found on the outdoor units.
I've been in this house over 2 years now and never did anything to the heat/AC units apart from flipping the thermostats from COOL to HEAT and back and replacing air and humidifier filters. Is there something I need to be doing in addition to this?
Thanks.
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#2383887 - 09/21/11 02:09 PM Re: Turn off power to central A/C for winter? [Re: Quattro Pete]
Al Online   content
Loc: Elizabethtown, Pa
While it might make sense to turn it off bc of say a lightening strike. Probably almost no-one turns if off.
Note..just an uneducated opinion.
#2383893 - 09/21/11 02:14 PM Re: Turn off power to central A/C for winter? [Re: Quattro Pete]
brandini Offline
Loc: Richmond, VA
It may save a few cents, or the equipment from an electrical storm during non-use. Though we always get a few freak days that make the inside humid so it's nice to have ac to dry the air.
07 Mazda3s Hatch - ZoomZoom - Using EAO-ALM-BF3-MTG-ANT-ATF
#2383911 - 09/21/11 02:30 PM Re: Turn off power to central A/C for winter? [Re: brandini]
hemitom Offline
Loc: canada
Some central air units come with a heater built into the compressor to keep the oil warm in low temp usage. These do consume a fair amount of electricity over time.
Edited by hemitom (09/21/11 02:31 PM)
2006 kia spectra
2009 hyundai santa fe
2012 mustang coupe.
#2383935 - 09/21/11 02:49 PM Re: Turn off power to central A/C for winter? [Re: Quattro Pete]
Schmoe Offline
Loc: Oklahoma
Hmmmmmm, never even thought of that. We get occassional thunder snow and ice, even here. With that question, I wonder if the AC unit even "pulls" a little juice when it's still connected.
01 Supercrew Lariat 4X4
06 Accord EX V6
10 CRV EX-L
(traded 02 Accord EX V6 @ 208K miles for)
14 CRV EX-L
(traded 10 CRV for)
#2383936 - 09/21/11 02:52 PM Re: Turn off power to central A/C for winter? [Re: Quattro Pete]
Greggy_D Offline
Loc: Near Ann Arbor, Michigan
Yep....I flip over my outdoor fuse to OFF every Oct.
Greggy D.
#2383937 - 09/21/11 02:53 PM Re: Turn off power to central A/C for winter? [Re: Greggy_D]
Loc: Great Lakes
That's the thing. I don't see any such switch/fuse anywhere.
#2383947 - 09/21/11 03:01 PM Re: Turn off power to central A/C for winter? [Re: Quattro Pete]
Jeepster_nut Offline
Loc: East Coast
There should be an outdoor disconnect near the compressor. Look for a grey metal box. It isn't a fuse, rather a disconnect device that you pull out and flip over, then re-insert. The disconnect doesn't have an amperage rating so it shouldn't be called a fuse.
My Trane XL-14i outdoor compressor has an onboard warmer (or so says the literature than came with it). It states that if the power is disconnected over the winter, that in the spring I should apply power and give it a 24 hour period to warm the refrigerant/oil.
I just shut the breaker off inside over the winter months and don't mess with the disconnect, only when I am doing the spring checkup do I open the disconnect box and pull the plug out and check for cobwebs.
For every complex problem there is a simple solution...and it is wrong. - H.L. Mencken
#2383954 - 09/21/11 03:05 PM Re: Turn off power to central A/C for winter? [Re: Quattro Pete]
Jim 5 Offline
Loc: Calgary Canada
I was told that you can damage it if you switch it on under around 70 degrees. A good reason to disconnect the AC unit would be to prevent inadvertant damage over the cold months if someone decided to turn it on for some reason.
Jim A
07.5 GMC Sierra 2500HD LMM Rotella 15w-40
09 Odyssey EX-L CT 5w-20
66 Bronco QS 10w-30
08 BMW K1200S Rt 15w-40
08 Pitster Pro X4 Rt 15w-40
#2383971 - 09/21/11 03:20 PM Re: Turn off power to central A/C for winter? [Re: hemitom]
Bluestream Offline
Loc: Waterloo, ON
exactly... happy
2000 Cavalier 2.2 A4
2000 VW Beetle 1.8T M5
2000 Ford Explorer 4.0 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
#2383972 - 09/21/11 03:21 PM Re: Turn off power to central A/C for winter? [Re: Jim 5]
KrisZ Offline
Loc: Toronto, Canada
BINGO!!!
That's the main concern, plus as other mentioned, some units have oil warmers and they will consume some electricity even when not used.
2015 Dodge//Grand Caravan-FF dumped
2006 Mazda 3-135k miles
#2383977 - 09/21/11 03:26 PM Re: Turn off power to central A/C for winter? [Re: Quattro Pete]
Loc: Great Lakes
OK, I think I've found it. Didn't initially notice there was an ON/OFF position on it. Is this it?
#2383991 - 09/21/11 03:42 PM Re: Turn off power to central A/C for winter? [Re: Quattro Pete]
Schmoe Offline
Loc: Oklahoma
Haven't seen that kind before. Definently has 240 going into it, the black and the red lines, and 240 going out. There's no actual switch on that unit. Looks like I can see "on" on the bottom right of that red box, but don't get me to lying here. I say it's a fuse because you probably got the 240 lines coming from your circuit breaker from inside the house. I'd trip that breaker before even touching that thing.
06 Accord EX V6
10 CRV EX-L
14 CRV EX-L
(traded 10 CRV for)
#2383995 - 09/21/11 03:46 PM Re: Turn off power to central A/C for winter? [Re: Schmoe]
Loc: Great Lakes
Yup. The red piece with the handle pulls out. It has 4 metal tabs on the back end. When I flip it 180 degrees, it'll be in OFF position - the tabs will be in different places.
So, is the consensus to switch it off for winter?
#2384000 - 09/21/11 03:50 PM Re: Turn off power to central A/C for winter? [Re: Quattro Pete]
Schmoe Offline
Loc: Oklahoma
You got enough wire to rotate it 180 degrees from current position? But yeah, turn it off for the winter. You just never know when someone might "accidentally" turn it on during the dead of winter and then you worry all the way up to spring. That's what I'm going to do when winter finally nails us, which is usually right after Halloween.
06 Accord EX V6
10 CRV EX-L
14 CRV EX-L
(traded 10 CRV for)
Page 1 of 3 1 2 3 >
