2004 4Runner Sport Edition 4.0L V6 (1GR-FE)
Factory Toyota 5w-30(Japan)....Castrol GTX 5w-30.... Mobil 1 0w-40
Mi/Hr on oil - 542....3,660....3,996
Mi/Hr on unit - 542....4,202....7,656
Sample date - 6/12/04....08/15/04....10/03/04
Aluminum - 9....6....3
Chromium - 1....1....0
Iron - 16....11....8
Copper - 46....10....2
Lead - 3....1....1
Tin - 3....3....0
Molybdenum - 6....35....60
Nickel - 0....0....0
Manganese - 2....1....0
Silver - 0....0....0
Titanium - 0....0....0
Potassium - 1....1....0
Boron - 4....0....97
Silicon - 228....56....22
Sodium - 3....2....4
Calcium - 2158....1919....3127
Magnesium - 4....3....8
Phosphorus - 840....778....743
Zinc - 1029....891....923
Barium - 6....1....0
Sus Vis@210 - 55.9....?....64.5
Flashpoint - 410....?....395
Fuel % - Antifreeze % - 0%....0%....0%
Water % - 0%....0%....0%
Insolubles % - 0.1....0.4....0.3
TBN - 5.7....?....5.8
6/12/2004
First change from factory fill, OCI 542 miles. Stock Toyota 90915-20004 filter as delivered from factory. Stock air filter assembly. Started using FC at 62 miles and have used at every fill up.
8/15/2004
Second oil change. Castrol GTX 5w-30 oil and Toyota 90915-YZZD1 filter. No Lube Control yet. Still using Fuel Power on every fill. No make-up oil.
10/03/2004
Third oil change. Mobil 1 0w-40 oil and Toyota 90915-YZZD1 filter. Started Lube Control with 5 oz. at initial fill and 3 oz./1,000 miles.
I used the same Toyota oil filter but switched to Royal Purple Racing 21 this time around. I will go to 7,500 miles on the RP and continue with Fuel Power every fill-up and Lube Control at 5 oz. in initial fill and 3 oz./1000 miles.
All comments welcome, see you next OCI!
Lead - 3....1....1
Tin - 3....3....0
6/12/2004
8/15/2004
10/03/2004
