Fram Ultra Bypass Valve Spring Life
by Digital2k2
05/29/16 11:32 AM
CARQUEST Filters are now made by Purolator (pics)
by sir1900
05/29/16 11:03 AM
Small 4 Cycle Engines, longevity tips
by henni
05/29/16 10:05 AM
Car won't star after new serpentine belt
by AlaninPA
05/29/16 09:06 AM
Was this sold by Costco?
by Vikas
05/29/16 09:03 AM
Gas or lithium-ion powered string trimmer?
by skyactiv
05/29/16 08:41 AM
Tire pressure question
by Tlhfirelion
05/29/16 07:18 AM
So I did an oil change but didn't change the filte
by Tlhfirelion
05/29/16 07:05 AM
Mixing Mobil 1 0w20 with 5w30
by doublebase
05/29/16 06:49 AM
Max Life @ Menards
by scusemez28
05/29/16 06:24 AM
Cut Super Tech ST3980 2500miles
by jhellwig
05/29/16 12:25 AM
Smoked my first brisket today
by MrHorspwer
05/28/16 11:00 PM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
76 registered (2015_PSD, aquariuscsm, AirgunSavant, AlaninPA, Al, AandPDan, 8 invisible), 1742 Guests and 120 Spiders online.
58013 Members
66 Forums
249555 Topics
Page 1 of 2 1 2 >
#2382727 - 09/20/11 11:53 AM New truck...0w20 or 5w20??
Johnny248 Offline
Loc: Detroit, MI
Just bought a 2011 Ram 1500 5.7 Hemi 4x4. Calls for 5w20, Amsoil's look up says 5w20. Should I run 0w20 or just stay with the 5w20? Winter will be coming soon....
'11 Ram 1500 5.7L
'08 Beetle 2.5L
'06 Eclipse GT 3.8L
'95 Four Winns Sundowner 5.0FI
'94 Honda Dio 72cc Big Bore
#2382741 - 09/20/11 12:00 PM Re: New truck...0w20 or 5w20?? [Re: Johnny248]
demarpaint Offline
Loc: NY
If you plan on using synthetic oil then use the 0W20. People will tell you the differences are slight between 0w20 and 5W20, it doesn't matter, etc., but with the winter coming why not?
Nice ride, drive it in good health!
God Bless Our Troops
#2382744 - 09/20/11 12:06 PM Re: New truck...0w20 or 5w20?? [Re: demarpaint]
tig1 Offline
Loc: Illinois
+1 I agree. 0-20 is excellant for engines that spec 20 wt. oils.
2007 Ford Fusion 181,000 miles
M1 0-20 AFE
2007 Ford Focus 154,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#2382747 - 09/20/11 12:10 PM Re: New truck...0w20 or 5w20?? [Re: Johnny248]
rg200amp Offline
Loc: Phila,PA
Use whatever oil that meets the spec your engine calls for.
// 2013 Subaru WRX //
SOLD:
-11 Volkswagen Jetta
-04 Lincoln LS
-01 Ford F250
-04 Mazda Rx-8
-97 Jeep Wrangler
-97 BMW M3
-97 Nissan Maxima
#2382749 - 09/20/11 12:11 PM Re: New truck...0w20 or 5w20?? [Re: tig1]
NHHEMI Offline
Loc: NH
I agree with the above that 0W-20 would be fine in the winter only let me add that Chrysler( Ram ) does not allow for 0W-20 in the owner's manual. It is 5W-20 only. Possible warranty snag for you if you ever had any internal engine issues.
I live in NH so I see bad winters like you do out there in MI. Had a couple Ram's w/ 5.7L( previous version = 04 and 08 ). Used RP synthetic 5W oils in both( 04 = 30 and 08 = 20 )and NO problems even on the coldest AM starts. As long as you are using a synthetic 5W-20 you will be fine for cold start protection and that is the only difference with the 0W vs 5W.
Edited by NHHEMI (09/20/11 12:12 PM)
Proud user of Royal Purple products thumbsup
#2382774 - 09/20/11 12:43 PM Re: New truck...0w20 or 5w20?? [Re: Johnny248]
Chris Meutsch Offline
Loc: Cincinnati
Run Penn Platinum 5w20 and sleep easy.
"If the truck starts like butt its probably not your battery."
----cptbarkey, 5/24/16
#2382782 - 09/20/11 12:50 PM Re: New truck...0w20 or 5w20?? [Re: Johnny248]
Radman Offline
Loc: Detroit, Michigan
It's your truck use whatever you want. If it were my truck I would use 5W30. The energy savings 30 weights are only slightly thicker than 20 weights. Check the CST between your prospective oils and make your decision.
2006 Maxima 120K M1-105, M1 0W40
2006 Sentra 90K M1-105, GTX 5W30
2010 Altima 20K M1-105, GTX 5W30
2013 Yamaha FZ1 1K PL1410, SRT5 15W40
#2382784 - 09/20/11 12:55 PM Re: New truck...0w20 or 5w20?? [Re: Johnny248]
2oldtommy Offline
Loc: Ohio
Nice truck. I learned to drive on a Dodge, excuse me, your Dodge is a RAM. Enjoy!--Oldtommy
#2382790 - 09/20/11 01:01 PM Re: New truck...0w20 or 5w20?? [Re: Radman]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
Since a 20wt is spec'd for your truck it makes zero sense to use anything heavier. The difference in start-up viscosity can be dramatic at colder temp's.
Since you're considering using synthetic oil I'd recommend going with a 0W-20 for it's higher VI.
Amsoil unfortunately doesn't make a light 20wt oil that's spec'd for your truck but if you are sold on it, go with their XLM 5W-20, it's actually lighter than the 0W-20 and is cheaper to boot.
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#2382828 - 09/20/11 01:50 PM Re: New truck...0w20 or 5w20?? [Re: Johnny248]
OldCowboy Offline
Loc: SW Missouri
Hi CATERHAM,
I'm trying to understand how the XLM 5W20 is lighter than XLZ 0W20 or ASM 0W20?
Code:
Oil        100C     VI     HTHS
XLM 5W20    8.8     151     2.8
XLZ 0W20    8.3     167     2.7
ASM 0W20    8.7     166     2.8
It looks to me like the XLZ 0W20 is the lightest.
Edited by OldCowboy (09/20/11 01:51 PM)
#2382886 - 09/20/11 03:09 PM Re: New truck...0w20 or 5w20?? [Re: Johnny248]
Johnny248 Offline
Loc: Detroit, MI
Thanks for the ideas. I would normally just use the 0w20 Amsoil, but I thought I'd ask since neither "RAM" or Amsoil lists it as an oil to use. I think I'll prob use the 0w20 ASM for the winter, and then the 5w20 ALM come summer time. I also would consider AZO, but the manual says use only 5w20 for the MDS. I'm sure in all reality, a high quality oil like AZO will work fine with the MDS, but I'll use what they want. Also,not as if it matters too much, but I have a Napa Platinum 41372 which is the Ford filter. Little bit longer than the specd Hemi filter, and Napa only offers a gold version of the Hemi filter.
'11 Ram 1500 5.7L
'08 Beetle 2.5L
'06 Eclipse GT 3.8L
#2382902 - 09/20/11 03:29 PM Re: New truck...0w20 or 5w20?? [Re: Johnny248]
broncobullitt Offline
Loc: Arkansas
Really you're not like an older truck owner looking at the difference between 10-30 and 10-40. 5w20 runs just fine in the winter. I know my tag says Arkansas but I am in the military and from Idaho. I know what cold can do to an oil. Just run what Ram tells you to. They have done more extensive testing than any of us have.
#2382917 - 09/20/11 03:44 PM Re: New truck...0w20 or 5w20?? [Re: OldCowboy]
CATERHAM Offline
Originally Posted By: OldCowboy
Hi CATERHAM,
Code:
Oil        100C     VI     HTHS
You're right.
The SN version of XLM is heavier than the SM version which had a HTHS of 2.7cP and a 168 VI; that's quite a surprising drop in it's VI, no better than most 5W-20 dino's.
The XLZ 0W-20 is a heavy 0W-20, heavier than M1 0W-20 due to it's lower 167 VI and nothing is lighter than M1 at extremely cold temp's but that is academic for most of us.
#2382949 - 09/20/11 04:28 PM Re: New truck...0w20 or 5w20?? [Re: Johnny248]
NHHEMI Offline
Loc: NH
If you are going to follow the manual recommendations and have any warrantry concerns the Amsoil lines you talk of do not meet your warranty requirements. If you want to run Amsoil you need to run the XL or OE lines as they are API certified as required by Chrysler( Ram ). The other oils you talk of are not.
No offense but I am confused. On one hand you talk about what the manual says as if it matters to you and then you are talking about using the wrong weight and uncertified oils and such? Either follow the manual to preserve warranty or run what you want and don't worry about it. Seems like you are doing 50/50 and to me that makes no sense as it doesn't benefit you in any way.
You need...
5W-20
Meets/Exceeds Chrysler MS6395
API Certified w/ Starburst
Change by OLM or 6 months/8000 miles maximum
IMO if Amsoil is what you want to run( and that is fine = good stuff )run their XL 5W-20. It meets all of your warranty requirements, it will perform just fine in the winter and summer, and it is reasonably priced for what you get. It makes no sense to run their other oils( OE is ok but lowest grade they offer )as they do not meet warranty requirements and you are limited to 6 months or 8000 miles for your OC's max so the cheaper XL/OE oils will do the job just fine.
Use the XL 5W-20 and you will be fine warranty wise and mechanically.
Edited by NHHEMI (09/20/11 04:30 PM)
#2383005 - 09/20/11 05:23 PM Re: New truck...0w20 or 5w20?? [Re: Johnny248]
tig1 Offline
Loc: Illinois
Why use 5-20 in the summer and 0-20 in the winter. Just use 0-20 year round. No advantage to switching wts. That's what we did in the 60s. Old School.
M1 0-20 AFE
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
Page 1 of 2 1 2 >
