45560 Members
64 Forums
193944 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#2381094 - 09/18/11 08:15 PM
1994 Geo Prizm, 1.6L
Loc: MN
Just made a deal for a really nice Upper Midwest Prizm, with 158k.
Going to change oil, plugs, pcv valve tomorrow....
2 questions.
a. can you point me in the direction of where the PCV valve might be on this engine?
b. Engine is spec'd for 10/30 which surprises me, as I had a 95, and I believe I ran 5/30. I am assuming 5/30 would be acceptable??? First oil change is going to be an orphan bottle of 10/30 PYB SN, and 2.5 quarts of Formula Shell SN.
Thanks for the help.
#2381109 - 09/18/11 08:31 PM
Re: 1994 Geo Prizm, 1.6L
[Re: mjk]
Loc: Virginia
It's probably going to be attached to the valve cover somewhere. It's either a push-fit or screwed in with a hose attached to it.
5w-30 will work fine in that motor. It's a Toyota motor, isn't it? Today's 5w-30 is better than 10w-30 was in 1995.
06 Subaru Impreza WRX - Sold. The only mechanical thing I'll ever love. 07 Toyota Prius - Cheap synthetic and PureOne filters.
#2381445 - 09/19/11 08:20 AM
[Re: JRed]
Loc: MN
Yes, it is a Toyota motor.
#2381450 - 09/19/11 08:27 AM
[Re: mjk]
Loc: Arlington
Yes, it is a Toyota motor. It's a Corolla. It has a Delco radio and might have a Delco alternator, but it's a Toyota. I'm certain 5W30 will do well in this application.
2005 Mazda 6S hatchback - Mobil Super High Mileage 5W20 2005 Chrysler PT Cruiser GT - QSUD 5W30
#2381607 - 09/19/11 11:59 AM
[Re: mjk]
Loc: Chicago Area
5-30 would be my choice. Esp in MN winter. Better for start up. It's good you are going over the car before winter. If it moves, lube it. If it is loose, tighten it. If it is broke, fix it. Get new wiper blades, too.
#2381619 - 09/19/11 12:11 PM
[Re: mjk]
Loc: Colorado Springs
PCV valve is smack dab in the middle of the valve cover towards the firewall side.
#2381698 - 09/19/11 01:45 PM
[Re: mjk]
Loc: Silicon Valley
You can't miss the PCV, it is right on top of the valve cover and you can pull it off with your hand.
It originally spec 10w30 because back in that era 5w30 shear down too fast. I think recently they back spec it to use 5w30 as the newer oil gets better.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#2381974 - 09/19/11 06:23 PM
[Re: mjk]
Loc: Franklin,TN
how old is the timing belt?!
09 Pontiac Vibe, 68k miles, Maxlife syn 10w-30 09 Chevy Cobalt, 45k miles, Q syn 10w-30
#2382015 - 09/19/11 06:42 PM
[Re: Cutehumor]
Loc: MN
I got under the hood today, and yes, the PCV valve is right in plain view. I had mine replaced on a 96 v6 camry, and it definitely was not in plain site.
#2382528 - 09/20/11 08:25 AM
[Re: mjk]
Loc: MN
I don't have documentation on water pump/timing belt replacement, so it will have to be dealt with prior to late fall.
I was in the process of replacing plugs (NGK Copper) yesterday, and when I pulled first plug, was pleasantly surprised to find nearly new NGK platinums in there. I guess I have back up plugs now..... Antifreeze checked to a strong -25, but will probably flush it in early November.
