Air filter wrap
by Duffyjr
Yesterday at 10:21 PM
15W-40 Delo, Delvac or Rotella For KUBOTA turbo
by pburchett
Yesterday at 09:50 PM
Traveler synthetic oil a slow seller?
by Electromotive
Yesterday at 09:34 PM
Tyre rubber, methanol, and bore wear
by Shannow
Choose for me
by Duffyjr
Yesterday at 09:26 PM
Help w/Transmission Drain & Fill
by klt1986
Yesterday at 08:58 PM
pennzoil ultra platinum pure plus
by Brayden
Yesterday at 08:10 PM
Group 5 synthetic oil
by Brayden
Yesterday at 08:07 PM
Ultra
by RubentheIowan
Yesterday at 08:03 PM
G-05 Change intervals, 3 or 5 years?
by Canadastang
CEL Code P2097, 2010 Mazda 6 with 2.5L I-4
by Snyperx
Yesterday at 08:01 PM
Laser scope on a Henry .22?
by Chris142
Yesterday at 07:58 PM
Doxxy, Jetstreamz06, TalNum, Spinnizle, JustinL
57758 Registered Users
25 registered (carlprop, BigD1, Blkstanger, camrydriver111, bubbatime, 2 invisible), 726 Guests and 173 Spiders online.
57758 Members
66 Forums
248280 Topics
Page 1 of 2 1 2 >
#2365811 - 09/03/11 04:15 AM New GM EOS and alternatives?
NovaMan Offline
Loc: Michigan
Please excuse me for not finding info with the search function, but I suspect it requires words with four or more letters, so "new GM EOS" results in no matches.
I've read that the new GM EOS has less zinc and phosphorus content and WAY more calcium than the original formulation. This is very unsettling! What did the original have, what does the new have, and what are the alternatives? ZDDPlus? Torco MPZ? Crane break-in concentrate?
(I need to know because I will soon be breaking in a flat tappet cam in a BBC.)
I know enough to know that I don't know enough.
#2365834 - 09/03/11 06:56 AM Re: New GM EOS and alternatives? [Re: NovaMan]
FL_Rob Offline
Loc: gulf coast FL.U.S.
Can you get your hands on Redline break-in oil? If so,I'd use
that.Next would be the Crane Cams concentrate.I wouldn't play
around with using the EOS even if you did find the "older" version.
#2366182 - 09/03/11 02:38 PM Re: New GM EOS and alternatives? [Re: NovaMan]
A_Harman Offline
Loc: Michigan
If you're looking for additional zddp content, EOS has been fourth-rate for that for a long time. ZDDPlus or Red Line Oil Oil Supplement and many other additives have much higher concentrations.
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#2366222 - 09/03/11 03:26 PM Re: New GM EOS and alternatives? [Re: NovaMan]
dailydriver Offline
Loc: Bucks County, Pa.
The Torco MPZ might be a good choice after break-in (has a TON of soluble moly as well).
For the actual break-in, you cannot do much better than the suggested Red Line product. wink
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#2366321 - 09/03/11 05:36 PM Re: New GM EOS and alternatives? [Re: NovaMan]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Comp Cam breakin additive is another quality product, if you're looking and come across it.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#2366580 - 09/03/11 11:15 PM Re: New GM EOS and alternatives? [Re: NovaMan]
NCGuy68 Offline
Loc: N. Carolina
All of the major cam grinders offer a quality break-in lube. Most important is to keep the RPMs around 2K or above upon inital fire-up making sure the cam is well oiled.
Some engine builders will suggest using a lighter valve spring to keep from hammering the cam until it seats.
I've had good results using Valvoline racing oil 10W40 in non street applicatios.
Craig S.
#2366584 - 09/03/11 11:21 PM Re: New GM EOS and alternatives? [Re: NovaMan]
NCGuy68 Offline
Loc: N. Carolina
Craig S.
#2366586 - 09/03/11 11:23 PM Re: New GM EOS and alternatives? [Re: NCGuy68]
NovaMan Offline
Loc: Michigan
Well, I called around town today and looked around on the internet, and the best I could do was Rislone's 5010 ppm Zn additive. If I use the whole quart of that and 6.5 qts of Valvoline VR1 straight 30 (1200 ppm Zn), that should put me just over 1700 ppm Zn. With that much additive, is there any concern of diluting the additive package of the VR1, or messing up the viscosity?
#2366613 - 09/03/11 11:53 PM Re: New GM EOS and alternatives? [Re: NovaMan]
NCGuy68 Offline
Loc: N. Carolina
Nope.
Craig S.
#2367107 - 09/04/11 04:00 PM Re: New GM EOS and alternatives? [Re: NCGuy68]
marc1 Offline
Loc: AB, Canada
What are the factual real life beefs with EOS? I have used it for 26 years for new cam and lifter installs. My last camshaft and lifter job (Comp mechanical flat tappet, 350# open pressure) was with the new formula... that was 15,000 hard miles ago and the lash hasn't changed a lick. I don't keep it (or any other cam break-in lube) in the crankcase beyond the intial cam break-in and, it goes without saying, I have never lost a camshaft.
To the OP, I have started to use ZDDPlus just lately and haven't had any issues to date so I would recommend it as an option but I still use GM EOS primarily, even the new lighter ZDDP formula.
Here is the ZDDPlus I buy.
http://www.summitracing.com/parts/CRO-86092/
2006 Sierra Z71 96k km QSAD 5w30 Wix 51522
2011 Shelby GT500 SVT 21k km Mobil1 0w40 FL820S
1970 Chevelle SS454 LS6 39k mi Redline 10w30 Wix 51061
#2367170 - 09/04/11 05:09 PM Re: New GM EOS and alternatives? [Re: NovaMan]
NovaMan Offline
Loc: Michigan
EOS used to be great, and I used it with positive results a few years ago in my truck engine. The beef is I've read it has less zinc than it used to (I can't find the exact numbers, though), and over the past five years or so a number of new, more concentrated zinc additives have come on the market.
ZDDPlus would have been my second choice, but they don't have very good distribution (basically have to order it online), and I need to fire the engine on Monday.
#2367179 - 09/04/11 05:21 PM Re: New GM EOS and alternatives? [Re: NovaMan]
DR Racing Offline
Loc: so cal
With high performance engine oils available now like Joe gibbs and brad Penn there is no need for zinc additives anymore. These oils are much better than a modern api oil with additives as they are formulated to work together as a engineered package and not a afterthought. Dan
01 jetta TDI stock 205k and counting
92 integra GSR
Porsche 356A highly modified
#2367241 - 09/04/11 06:36 PM Re: New GM EOS and alternatives? [Re: NovaMan]
NovaMan Offline
Loc: Michigan
This is for a cam break-in I'm doing tomorrow, not for regular use.
#2367420 - 09/04/11 10:10 PM Re: New GM EOS and alternatives? [Re: NovaMan]
marc1 Offline
Loc: AB, Canada
In a pinch you can use a good diesel oil, I have used Rotella 15w40 for cam break-ins many times w/o EOS.
Most of the speed shops in my neck of the woods carry ZDDP additives, Joe Gibbs oil and VR1 oil in stock... you should be able to find something in Michigan I would think.
What are your spring pressures? If they aren't excessive it won't matter anyway if you use a ZDDP additive or not.
#2367531 - 09/05/11 01:05 AM Re: New GM EOS and alternatives? [Re: NovaMan]
NovaMan Offline
Loc: Michigan
I don't think I have enough Rotella on hand (need 7qts + filter). Haven't they lowered the zinc in that yet?
The nearest store that I would call a speed shop is 30 miles away, and I needed to fit my exhaust pipes yesterday before 1PM, which precluded going all that way. Of course, they'll be closed on Labor Day.
According to my calculations, my spring pressures should be 128 PSI on the seat and 363 PSI open, BUT they're double springs, and I took out the inner springs for break-in.
Page 1 of 2 1 2 >
