Weather guys wrong again
by NHHEMI
34 minutes 28 seconds ago
More snake oil?
by Duffyjr
Today at 06:27 AM
Harrop's Howler
by Shannow
Today at 05:35 AM
2002 GMC Yukon Climate Control Problems
by Kgrant
Today at 01:11 AM
Vacuum leak after 3800 intake manifold gasket job
by CaliCarLover
Today at 12:17 AM
Pops-a-vent fuel can vent
by 901Memphis
Yesterday at 11:08 PM
GM Oil Life Update
by CapitalTruck
Yesterday at 10:48 PM
Toyota 2.4L & AWD Ok?
by Nick1994
Yesterday at 10:40 PM
0W20 in the US but 5W30 outside US for Mazda
by perryg114
Yesterday at 08:58 PM
Thoughts on Delo 10w-30 XLE for gas engines?
by Hal9000
Yesterday at 08:48 PM
why would someone want to pay with a phone?
by turtlevette
Yesterday at 08:16 PM
The connection was reset problem
by Triple_Se7en
Yesterday at 08:14 PM
rsritchey, Ball9320, 06Corolla, AyPapii, JakeTheYankee
56834 Registered Users
58 registered (b1amgm47, Astro14, AlienBug, Astro_Guy, 3800Series, 97K15004WD, 4 invisible), 974 Guests and 130 Spiders online.
56834 Members
66 Forums
244298 Topics
Page 1 of 2 1 2 >
#2360408 - 08/28/11 08:29 PM Why does my car shake when I first turn it on?
johnsmellsalot Offline
Loc: Texas
Why does my car shake when I first turn it on? This first happened last night. Today after work i started up my car and it did it again. The car only shakes when its been off for more than 8 hours. There are no check engine lights. All fluid levels are always full. I think it might be a misfire or something with the transmission.
1999 Buick Century 180,000 miles (first car)
2008 Chrysler PT Cruiser 70,000 miles
#2360420 - 08/28/11 08:52 PM Re: Why does my car shake when I first turn it on? [Re: johnsmellsalot]
milehigh Offline
formally milehighhyundai
Loc: CO
Does it clunk when you put it in gear? If so, maybe a weak motor mount?
#2360431 - 08/28/11 09:12 PM Re: Why does my car shake when I first turn it on? [Re: johnsmellsalot]
71Chevyguy Offline
Loc: Martinsburg West Virginia
Not sure how aggressive your driving style is but if you ever floor the car and let it wind up (warmed up of course) you would find out if it is the plug wires. If the wires are bad it will usually misfire when you really lay into it. Another thing to check is to see if you are having the LIM leaks. Also check your oil to see if any water is mixing in with it.
99 Beetle TDI 106k RT6 / Mahle filter
99 Beetle TDI 219k RT6 / Mann
87 Caprice 305
71 Nova 250
#2360481 - 08/28/11 10:29 PM Re: Why does my car shake when I first turn it on? [Re: johnsmellsalot]
jorton Offline
Loc: San Antonio, TX
The idle speed must be too slow when the engine first starts. Do you know of a mechanic who is good at tracing electrical, wiring, sensor problems?
"If everything seems under control, you're just not going fast enough."
- Mario Andretti
#2360544 - 08/29/11 01:25 AM Re: Why does my car shake when I first turn it on? [Re: johnsmellsalot]
Loc: Texas
The car only shakes for about 15 long seconds. It continues to shake when I put it from park to reverse. I don't think it's a motor mount because when I put it from drive to park, everything works fine. I think the intake gasket is leaking. You can see oil around the outside of the engine. I change the oil every 3,000 miles. I don't see coolant in it.
#2360552 - 08/29/11 02:39 AM Re: Why does my car shake when I first turn it on? [Re: johnsmellsalot]
Colt45ws Offline
Loc: Central Washington
You might check that you are not losing coolant. It might be pooling in a cylinder and cause a misfire until it is burnt out.
This is the exact same thing I dealt with on the 3400 in the Montana after I did the LIM on it. Start it and it would miss like it had a dead hole for 10-15 seconds. Never caused a CEL for misfire, just a "EGR Stuck" code. After that it was smooth as new. Kinda thought that might have been it from the extra 'air' coming through the EGR. I had done the ignition with the LIM so that was all new. Compression was within tolerance. Actually, all the cylinders were really close to each other.
In the mean time I had the oil tested again and it had twice the coolant intrusion than the test that made me do the LIM. In half the miles.
btw, I never saw coolant in the oil either. Since I had been testing oil that is how I caught it.
Something else I noticed got me suspicious. The coolant smelled like gas. It was pretty potent. It had also changed color from [censored] yellow to a kind of burnt orange color.
Finally I threw my hands up and bought a combustion gas detector setup that you put on the radiator. Popped positive for combustion leak almost instantly.
When I finally pulled the rear head, I seen what was going on. The gasket material had been eaten starting at a coolant port and once it got to the fire ring of the back passenger hole it rusted that out. Over a period of time after shutoff due to the pressure in the coolant system it was seeping into the cylinder and pooling. Causing a misfire at initial startup. Still dont know how it passed a compression test so well. That whole setup made me question the validity of compression test results as manner of grading an engine. They only seem to show obvious defects as a sort of "Go/No Go" system. More like "Maybe Go/No Go." :P
Didnt mean to write a book, or to scare you unnecessarily. Just wanted to explain my experience. :P Sorry.
-Colton
2004 Ford Crown Vic LX, 89k "Tank" (Totaled 12/06/15 22:30 PST)
2002 Ford Crown Vic PI, 170k "Highwayman" (Ex-Kootenai County, ID Unit #42)
#2360593 - 08/29/11 07:21 AM Re: Why does my car shake when I first turn it on? [Re: johnsmellsalot]
The_Eric Offline
Loc: Iowa
Before we start condemning the intake and/or head gaskets, lets start a little more simple. When was the last time it was tuned up? Fuel filer, air filter, plugs, wires, pcv valve and so on? Vacuum leaks?
If you see oil at the base of the LIM, then no doubt it's starting to leak (doesn't necessarily mean coolant just yet), but for now start with the basics.
2001 Hyundai Elantra 2.0
1998 Chevy Malibu 2.4
1995 Pontiac Grand Am 3.1
1979 Ford F-150 351M
#2360676 - 08/29/11 09:52 AM Re: Why does my car shake when I first turn it on? [Re: The_Eric]
Loc: Texas
The fuel filter was replaced approximently 5 months ago, and the air filter was replaced 10 months ago. The mechanic told me that the spark plugs were fine. I personally checked the PCV valve by shaking it and it rattled. I changed the transmission fluid and filter about 2 months ago. I used Dexron III.
#2360791 - 08/29/11 11:45 AM Re: Why does my car shake when I first turn it on? [Re: johnsmellsalot]
mechtech2 Offline
Loc: Chicago Area
Only stone cold?
A coolant sensor that is faulty may be the deep down culprit.
It is telling the computer that the car is warm, when it really needs more fuel.
#2361098 - 08/29/11 05:13 PM Re: Why does my car shake when I first turn it on? [Re: johnsmellsalot]
Loc: Texas
UPDATE: Ok I was driving to Dallas when all of the sudden the check engine light came on. 5 minutes later it started blinking so I turned around. I stopped by Auto Zone and it turned out to be a misfire. I breathed a sigh of relief. I thought it might be the transmission because I just changed it less than 10,000 miles ago. I'm going to take out the spark plug and see how it looks. I'm hoping there's no oil on it. If it looks kinda old, I'm going to change all of them with E3 spark plugs and Bosch wires. The service manual says to change the spark plugs every 30,000 miles. My car has over 170,000 miles and there's no telling when the spark plugs were last changed.
As for the coolant light, I'm thinking maybe a bad or dirty sensor.
#2361284 - 08/29/11 08:13 PM Re: Why does my car shake when I first turn it on? [Re: johnsmellsalot]
The_Eric Offline
Loc: Iowa
Stick with an O.E.M. plug type.
#2361981 - 08/30/11 01:45 PM Re: Why does my car shake when I first turn it on? [Re: johnsmellsalot]
mechtech2 Offline
Loc: Chicago Area
Forget the E3s.
But an ignition misfire could be wire or coils , too.
And an ignition misfire would show up in normal driving, not just cold starts.
#2362262 - 08/30/11 06:13 PM Re: Why does my car shake when I first turn it on? [Re: johnsmellsalot]
Jim Spahr Offline
Loc: Lexington, SC
I concur with the plug recommendation. Go with the AC/Delco spark plugs, not the E3's. Advance Auto or AZ will have the newest rec. version of the correct plug for your car. I would use the AC/Delco wires as well. I know no one has mentioned, O2 sensors yet, but they are esp. critical to use the OEM O2 sensors for GM products.
Chevy Impala SS 1994 LT1 5.7L V8
Chevy Blazer LS 4WD 2003 4.3L V6
Chevy Lumina 4 door 1996 3.1L V6
#2362361 - 08/30/11 08:14 PM Re: Why does my car shake when I first turn it on? [Re: johnsmellsalot]
GMBoy Offline
Loc: Texas
I also agree - don't get the E3's. It's a gimmick plug, not even a platinum/iridium plug and they charge you like they are. I installed these in a 2002 Trans Am for a woman. She bought them at the advice of a parts man and I argued with her to let me replace the plugs with the AC Delco or even Autolights but she insisted. Two weeks later, she was back and told me to put whatever plugs I want in it.
#2362471 - 08/30/11 10:11 PM Re: Why does my car shake when I first turn it on? [Re: GMBoy]
Loc: Texas
The guy in Auto Zone also told me to stick with AC Delco. He said that the manufacturer spent millions designing the engine with those spark plugs. So I'm going to get AC Delco plugs and wires.
Someone else said something about the car only shaking on cold starts. The guy in Auto Zone explained this. He said he worked at an emission inspection place for 15 years. He looked at my spark plugs and immediately asked what brand of gas I was putting in it. I've been putting in Valero because its cheap and its on the way to work. He said only use gas that advertises detergents in it. An example of a gas with detergents would be Chevron with Techron. Anyways on the way to Dallas, the car started shaking really bad so I drove back going below 55 MPH. The car started misfiring while cold 2 days ago and then yesterday misfired from normal driving. That guy in Auto Zone sold me 2 containers of fuel system cleaner. He said it'd get that carbon out of there. I'm going to run 1 container after I fill up. I'll do this twice. After that, I'm going to change the spark plugs.
Page 1 of 2 1 2 >
