Consensus on 12 month interval oil changes
by accobra66
06/25/16 09:11 AM
Truck Wars
by AirgunSavant
06/25/16 09:06 AM
A good read....The more things change....
by ryan2022
06/25/16 08:46 AM
Opinions on linksys 1900acs router
by madRiver
06/25/16 08:18 AM
Pick my oil change
by ram_man
06/25/16 08:09 AM
Weird!
by AirgunSavant
06/25/16 08:05 AM
Good Deed?
by AirgunSavant
06/25/16 08:02 AM
Vibration after rotating tires and painting wheels
by Drew99GT
06/25/16 08:02 AM
BIBLE STUDENT GONE?
by Eddie
06/25/16 06:23 AM
Avoiding short trips like the plague
by FordCapriDriver
06/25/16 03:11 AM
API CK-4
by JustPlainFolks
06/25/16 02:37 AM
Rotella T
by momo
06/25/16 01:51 AM
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
86 registered (accobra66, AirgunSavant, adamrc, AandPDan, 2015_PSD, 9 invisible), 1586 Guests and 13 Spiders online.
58257 Members
66 Forums
250777 Topics
#2357402 - 08/25/11 12:51 PM Hydraulic Fluid vs ATF
OnTheWaterfront Offline
Loc: DE
I have a new crane that utilizes outriggers with hydraulic cylinders for stabilization, but the hydraulic cylinders are a little bit spongy, so I complained to the manufacturer who has told me to replace the hydraulic fluid with an ATF fluid. They refuse to disclose the nature of the problem or why the ATF fluid fixes the issue.
Does anybody have any idea what the problem could possibly be?
They viscosity of the ATF (Mobil Esso ATF 200) and the Hydraulic fluid (Q8 Handel 46) are very close, the ATF is slightly thinner. I'm also worried about voiding the warranty on the hydraulic pump (multi-stage piston pump with variable swash plate, very expensive) by running ATF.
Edited by OnTheWaterfront (08/25/11 12:52 PM)
#2357437 - 08/25/11 01:32 PM Re: Hydraulic Fluid vs ATF [Re: OnTheWaterfront]
440Magnum Offline
Loc: Texas
The only thing I can guess is that ATF has better anti-foaming additives.
As for the warranty on the pump... good question! You say the manufacturer is recommending ATF- I'd at least get that in writing to be sure the pump is still covered.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#2357742 - 08/25/11 07:21 PM Re: Hydraulic Fluid vs ATF [Re: OnTheWaterfront]
MolaKule Offline
Loc: Iowegia - USA
Check your breather or reservoir tank and see how much foaming is occurring because spongyness is usually due to air entrainment.
Also have the mechanic check input line or low pressure lines and fittings to see if they are tight and no air is getting sucked in.
Magnum gave some good advice. Get that in writing before changing over.
ATF and I repeat, ATF DOES NOT have the same level of anti-wear additives as do regular hydraulic oils, regardless of closeness in vscosity.
Edited by MolaKule (08/25/11 07:22 PM)
Why do seagulls fly over the sea? Because if they flew over the beach they would be called, "Beaguls." smile
#2357818 - 08/25/11 09:08 PM Re: Hydraulic Fluid vs ATF [Re: OnTheWaterfront]
roadrunner1 Offline
Loc: oh
+1 on checking for suction side leaks, instead of ATF, if no leaks are found, try an ISO 32 viscosity.
'15 F350 6.7
#2367301 - 09/04/11 07:55 PM Re: Hydraulic Fluid vs ATF [Re: OnTheWaterfront]
deeter16317 Offline
Loc: SE, PA
Also check the rating on the hoses (they may be part of the sponginess), I saw this on a drill rig I ran at one point.
2004.5 Dodge 2500 Cummins
#2411053 - 10/20/11 10:22 AM Re: Hydraulic Fluid vs ATF [Re: OnTheWaterfront]
Loc: DE
The crane manufacturer is going to replace the original hydraulic fluid (Q8 Handel 46) with a different hydraulic fluid (Mobil DTE 10 Excel 46) in an attempt to get rid of the sponginess. I don't see how changing from one ISO 46 fluid to another ISO 46 fluid will make any difference.
#2413691 - 10/23/11 01:49 PM Re: Hydraulic Fluid vs ATF [Re: OnTheWaterfront]
George Bynum Offline
Loc: Greenville SC
Without suggesting that one oil is better than the other, it may be that one has better de-airation properties. Reservoir design (hot oil across almost horizontal surface for thin layer of fluid) is incorporated in many of them. Different oil chemistries do have different bulk modulus values.
#2431960 - 11/11/11 03:01 PM Re: Hydraulic Fluid vs ATF [Re: George Bynum]
FKPhil Offline
Loc: UK
I struggle to see foaming as the issue here.
Air entrainment into the liquid could be the problem, and so good “air release” is desirable but air release property of the oil can be independent of foaming characteristics.
Also air getting into the pressure side of the hydraulic system might be due various mechanical or operational problems (some suggested above); might not be the oil.
If the cylinder is under high load the “sponginess” might not be air, but be due to low viscosity of the oil. Temporary viscosity loss shearing characteristics due to the Viscosity modifiers in these oils mean they can be well below the ISO46 when in high stress operation and this will slow cylinder filling. ISO46 on the can might not be what the equipment experiences. Temporary low viscosity means the pump is inefficent due to internal leakage. If this is the cause then ATF also will be poor; ATF's generally have poor temporary viscosity loss characteristics. However the Mobil DTE 10 Excel 46 is very good in this respect. (and no I don’t work for Mobil).
