how often are you guys buying new tires
by bowlofturtle
9 minutes 18 seconds ago
Why are some experienced people so conceited?
by motor_oil_madman
16 minutes 39 seconds ago
alternative to Netstumbler...
by daves66nova
Today at 07:05 PM
Unable To Play Burned CD's in Car Player
by sleddriver
Today at 06:58 PM
Visiting Hudson Bay?
by JHZR2
Today at 06:54 PM
Two More VPs Leave (Fired from?) Tesla
by MrHorspwer
Today at 06:42 PM
Carlisle Radial Trail HD Trailer Tire
by totegoat
Today at 06:26 PM
Lubrication Engineers vs Schaeffer's
by Dad2leia
Today at 05:49 PM
Tesla reports a worse than expected loss $282.3m
by Nate1979
Today at 05:27 PM
Using P/S fluid in a system that takes ATF ok?
by gregk24
Today at 05:24 PM
Redoing an old retrofit job headlights please help
by OtisBlkR1
Today at 05:19 PM
Mobil at Walmart + Mobil Rebate + Ibotta= $1/quart
by macarose
Today at 05:13 PM
NatedeScate, Bogie69, Cali, Fyko, Palmer
57794 Registered Users
123 registered (Astro14, alcyon, abycat, aquariuscsm, askani79705, Abakev, 12 invisible), 0 Guests and 1 Spider online.
57794 Members
66 Forums
248477 Topics
Page 1 of 2 1 2 >
#2354544 - 08/22/11 07:13 PM Air Compressor oil change...
Big_Kat Offline
Loc: Iowa
... looked in my manual for my air compressor to see what it called for as of oil grade. It says Mobil 1 5w-30 should be used. I didn't have any on hand so I just dumped in some Amsoil SSO 0w-30. It sits in an unheated garage and i am tired of it tripping the breaker all the time.
2011 Jeep Compass 8000 mile OCI
Where would life be without mutations?
#2354570 - 08/22/11 07:26 PM Re: Air Compressor oil change... [Re: Big_Kat]
Trav Offline
Loc: MA, Mittelfranken.de
What kind of compressor is this?
Most recommend 30w compressor oil, you can get it at HD, Lowes or HF.
Compressors need no multi grade or add packs that combustion engines need.
#2354574 - 08/22/11 07:33 PM Re: Air Compressor oil change... [Re: Big_Kat]
JHZR2 Offline
Loc: New Jersey
I put amsoil compressor oil in my majors compressor and it ran notably cooler than the conventional lube. Sure, yours specs a syn so you're good there but I'd run a purpose-built lube...
#2354576 - 08/22/11 07:37 PM Re: Air Compressor oil change... [Re: JHZR2]
Big_Kat Offline
Loc: Iowa
its a Campbell Hausfeld compressor, the mono grade gets to thick in the winter and it won't turn the compressor. The manual says nothing about using compressor oil.
http://www.chpower.com/chpdfs/manual04/615600_0605.pdf
Page 5
OIL CHANGE
1. Allow compressor to run and warm
up oil. Unplug unit.
2. Position a pan under pump end of
unit.
3. Remove oil drain plug (see Figure 6).
Allow oil to collect in pan. Tilt unit to
completely drain.
4. Replace drain plug, fill pump to full
line on sight glass. Use Chevron
synthetic 5W-30, Mobil 1 5W-30 or
10W-30 synthetic motor oil. Using
other types of oil will cause starting
problems.
5. Change oil after every 50 hours of
use.
Edited by Big_Kat (08/22/11 07:41 PM)
#2354592 - 08/22/11 07:48 PM Re: Air Compressor oil change... [Re: Big_Kat]
Chris142 Offline
Loc: apple valley, ca
My ancient CH compressor says to use 10w40. Mine trips the breaker in winter too. I put Mobil-1 5w30 in it 10+ years ago and it does not trip the breaker anymore.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#2354615 - 08/22/11 08:04 PM Re: Air Compressor oil change... [Re: Big_Kat]
troyb43 Offline
Loc: VA
Should start a lot easier with SSO. I use their SAE 20 compressor oil in mine, it works well for me.
#2354641 - 08/22/11 08:20 PM Re: Air Compressor oil change... [Re: troyb43]
daman Offline
Loc: Bad Axe, MI
Use a thinner compressor oil like a 20w.
"Always"....Mobil 1
Current fill: AFE 0w30
#2354650 - 08/22/11 08:27 PM Re: Air Compressor oil change... [Re: daman]
Big_Kat Offline
Loc: Iowa
SSO is what i have on hand and i trust it more than other multi-viscosity oils that might shear. Classes start tomorrow so im broke.
#2354822 - 08/23/11 12:54 AM Re: Air Compressor oil change... [Re: Big_Kat]
EricF Offline
Loc: SF Bay Area
my horizontil CH wanted 30W non-detergent oil. I changed the oil every season whether I got to use the compressor or not.. but I always used regular 30W, never had an issue with it..
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
#2354877 - 08/23/11 05:50 AM Re: Air Compressor oil change... [Re: Big_Kat]
Trav Offline
Weird. On page 5 its says in bold letters.
"Do not use regular automotive oil such as 10W-30"
"additives in regular motor oil can cause valve deposits and reduce pump life"
IMO CH should get it straight with its Chinese manufacturer.
If your having trouble in cold weather use something like Redline or Amsoils 20w, both great oils and will hold up a long time in this compressor.
#2354931 - 08/23/11 08:03 AM Re: Air Compressor oil change... [Re: Big_Kat]
deeter16317 Offline
Loc: SE, PA
I've ran Mobil 1 5w30 for a LOT of hours (and years) in my big CH without a single issue, in any temperature from 100*F to -25*F. I think I've changed it once in all those years...it was the second fill after about a 30 minute break-in.
I recent changed the oil in my generic pancake compressor (it wouldn't start below 40*F) to 5w20 Mobil 1 (hey, its a cheap experiment) and it not only starts faster, it recovers quicker and runs cooler too! It was a very notable improvement.
I could understand the "additives in regular motor oil can cause valve deposits and reduce pump life" if we were talking about an oil from 1955, but aren't today's oils are specifically made to not leave deposits?
2004.5 Dodge 2500 Cummins
#2355143 - 08/23/11 12:01 PM Re: Air Compressor oil change... [Re: Big_Kat]
tig1 Offline
Loc: Illinois
XM says not to use engine oil in air compressors. I use Lowes semi syn in mine. Here's a link.
http://www.mobiloil.com/USA-English/MotorOil/Car_Care/AskMobil/Oil_for_Air_Compressors.aspx
2007 Ford Fusion 179,000 miles
M1 0-20 AFE
2007 Ford Focus 153,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
#2356896 - 08/24/11 10:24 PM Re: Air Compressor oil change... [Re: Big_Kat]
Big_Kat Offline
Loc: Iowa
So i went ahead and got Amsoils 20wt compressor oil as the compressor is out of service because i destroyed the air filter... long story stooges duh
#2357610 - 08/25/11 04:22 PM Re: Air Compressor oil change... [Re: Big_Kat]
Tempest Offline
Loc: Las Vegas NV
I've used Amsoil 40 grade compressor oil in my little Makita for several years now and it's been great. "Cold" here is about 30F in the winter and it starts up without issue.
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
#2357682 - 08/25/11 05:52 PM Re: Air Compressor oil change... [Re: Tempest]
Big_Kat Offline
Loc: Iowa
I was trying to air up a flat tire last winter in -5 degree temps and had to flip the on of switch back a forth for about five minutes to get the thing to run. Once the oil got to flowing it was all good just had to see how much wear took place during that time..
Page 1 of 2 1 2 >
