Yet Another WM Clearance on Oil
by Greg L
05/25/13 06:03 PM
hydrostatic woes
by ram_man
05/25/13 06:00 PM
Looking for Longer Fram Ultra Oil Filter
by 147_Grain
05/25/13 05:38 PM
Autozone clearance
by docsteveg
05/25/13 04:29 PM
any advantage of 10W-30 over 5W-30 or 0W-30?
by LScowboy
05/25/13 03:39 PM
1985 ford f150 5 liter keeps shorting coil....help
by GoHeels1981
05/25/13 03:09 PM
Craiglist Selling Tips?
by Rock_Hudstone
05/25/13 03:07 PM
Craftsman 154 pc Mech.Tool Set ~$75 + Free Ship..
by sayjac
05/25/13 03:01 PM
Need assistance on oil filter brand
by Eosyn
05/25/13 02:28 PM
PENNZOIL ULTRA 0W-40 eBay.....
by Hethaerto
05/25/13 02:20 PM
Oil for 03 Camry with low miles?
by gregoron
05/25/13 01:51 PM
Pennzoil synthetic blend vs full synth
by kenpoed
05/25/13 01:03 PM
goodolboy, Rick_Kean, patmoetighe, ohbehave, Maritimer
45560 Registered Users
114 registered (addyguy, 147_Grain, 95busa, AlienBug, 04SE, 2010_FX4, 9 invisible), 1490 Guests and 240 Spiders online.
45560 Members
64 Forums
193944 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#2350568 - 08/18/11 07:05 PM Valvoline Mercon V- Full Synthetic
Nightmare Offline
Loc: KY
Sifting thru the choices for a Ford Mercon V Transmisson fluid change,---- and noticed that yes, Valvoline Mercon V is a full synthetic.
MERCONŽV ATF is a premium, full synthetic automatic transmission fluid engineered to be superior to conventional ATF.
http://www.valvoline.com/products/brands/valvoline/automatic-transmission-fluid/35
Is there really any reason for me to buy say Mobil 1, RP, Redline, etc., for a daily city driver?
BTW, I also noticed the Castrol Mercon V is not fully synthetic. Same price @ my AutoZone.
#2350569 - 08/18/11 07:07 PM Re: Valvoline Mercon V- Full Synthetic [Re: Nightmare]
qdeezie Offline
Loc: Charlotte, NC
You might want to check out Valvoline Maxlife as well. That's also synthetic. It is great stuff.
1990 F150 XLT Lariat
302/5.0L - E4OD
3.55 Gears / Non-Limited Slip
1998 Chevy Cavalier
2.2L - 4T40E
352,000 Miles and counting....
#2350616 - 08/18/11 07:40 PM Re: Valvoline Mercon V- Full Synthetic [Re: qdeezie]
chad8 Offline
Loc: michigan
I put amsoil in my taurus and couldn't be happier. Found a dealer who couldn't get rid if it. Bought 15 quarts for $50.
I tow a trailer with periodically it and it shifts smoothhhh.
Amsoil meets mercon v.
#2350708 - 08/18/11 08:58 PM Re: Valvoline Mercon V- Full Synthetic [Re: Nightmare]
-SyN- Offline
Loc: Tornado Alley
I don't think Valvoline Mercon V is a-->{True} Full Synthetic... It is a top quality ATF... Valvoline Maxlife I believe was stated at a semi-synthetic... with a very robust additive package...
If you are looking for a so called Full Synthetic ATF? Look into--->M1-Amsoil-Redline
Be careful what is in print...Companies kinda fudge the {Fully Synthetic} Slogan! It all depends on the base stocks... Do some in depth research and you will see...
01 Ford 7.3L PSD 4x4 {300K Miles}
06 Audi A4 Quattro 2.0T
08 Ford F150 FX4--{5.4L 3V}
12 Ford Edge Limited--{3.5L 4V)
#2350965 - 08/19/11 06:58 AM Re: Valvoline Mercon V- Full Synthetic [Re: Nightmare]
chad8 Offline
Loc: michigan
Syn , I think you are right. Although valvoline states that its mercon v is full synthetic ,several other places in its literature say that it is a blend. Since Motorcraft Mercon v is a blend , they are getting away with it. There might even be 2 versions with the same stock numbers.The below statements are from various valvoline websites
I think I found it.
The blue bottle with lighter blue stripes where it says mercon v written in white seems to be full synthetic. The blue bottle with greenery and mercon v written in yellow is the blend.
Both have the same stock number.
I would steer clear unless you either got a great deal or the bottle stated full synthetic on it.
Valvoline VV360 MERCON V DEXRONIII ATF Pack of Twelve 1 Quart Bottles : Valvoline Mercon V ATF is a premium synthetic blend automatic transmission fluid engineered to provide performance benefits over conventional ATF fluids. Have techical questions, please feel free to call our Tech Service 1-800-TeamVal
Does Valvoline make a synthetic ATF?
Yes. Valvoline makes several synthetic ATF's. MaxLife Dexron/Mercon ATF, Mercon V ATF, ATF +4 and Dexron VI are all synthetic
Sizes and Grades
Name MerconŽ V ATF
Size 5-Gal
Part VV318
UPC 0 74130 0031 0
Name MerconŽ V ATF
Size Quart
Part VV360
UPC 0 74130 00360 6
Name MerconŽ V ATF
Size 55-Gal
Part VV320
UPC 0 74130 0032 0
#2351491 - 08/19/11 06:21 PM Re: Valvoline Mercon V- Full Synthetic [Re: Nightmare]
Nightmare Offline
Loc: KY
Thanks for the suggestions everyone!! I'm just doing a partial change using a suction device, 5-6 qts.. from a 13.4 capacity trans.
Probably will just go with some Valvoline based on price, and it's just a partial. Also Valvoline/Ashland Oil Co., is based here in KY.
Actually I went earlier to O'Reilly's to get some Motorcraft for 70 cents a bottle cheaper than Valvoline or Castrol. None in stock.
What I did see was RP for $13.99 qt., and Amsoil ATF for
$13.49 qt.
Probably do a partial 5 qt in a few months , right before winter. I want to try either one, or a few of each. I have seen Redline @Aamazon for $10.49 qt..LQQKs tempting also...
I forgot to mention I have 58,000 miles on the car. Is it too early to use Max-Life? Or would it even matter? I didn't see on the specs online that it is formulated for Mercon V. Just regular Mercon & Mercon SP & LV
Edited by Nightmare (08/19/11 06:29 PM)
