Out with the old, in with the new F150
by MNgopher
06/30/16 12:14 PM
Hard Workers
by AirgunSavant
06/30/16 10:55 AM
which kind of vinegar to use?
by bmwjohn
06/30/16 10:53 AM
0% ethanol gas please
by yvon_la
06/30/16 10:17 AM
Motorex Legend 4T
by Junkie
06/30/16 09:56 AM
2ZR-FE Oil filter Comparison
by Tech819
06/30/16 09:45 AM
Andrews AFB
by AirgunSavant
06/30/16 08:55 AM
Luber Finer cut open
by Tech819
06/30/16 08:42 AM
Meguiars wax
by whip
06/30/16 08:02 AM
Weird problem with laptop. Thoughts?
by d00df00d
06/30/16 07:42 AM
Silverado 6.2L Fram TG 3 years and ~45,000 miles
by DriveHard
06/30/16 07:15 AM
Old bike, new engine -synth or dino oil?
by mr_blackstock
06/30/16 06:56 AM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
82 registered (901Memphis, AirgunSavant, 97f150, 97K15004WD, 87sammy, 3 invisible), 1876 Guests and 8 Spiders online.
58322 Members
66 Forums
251033 Topics
Page 1 of 8 1 2 3 4 5 6 7 8 >
#2348449 - 08/16/11 02:25 PM The switch from Honda ATF Z1 to DW-1.... issues.
2K5TSX Offline
Loc: Toronto, Ontario
Ok.. so I know DW1 vs Z1 has been discussed a number of times on here.. but I wanted to tell my story.. and see if anyone can help.
2005 Acura TSX 5AT with Z1 from factory. Did a factory drain and fill in 2008 (45k) which was early compared to the 96k recommendation. I then had a tranny failure on my Mazda, so it got me concerned about my Acura.
So I brought her into Acura to do a drain and fill.. by then the Z1 fluid looked pale red in colour.. not black or anything. It was 86,000kms or 41k since last changed. (all KMs not Miles).
After the drain and fill, I noticed the dip stick was about a cm over the full when cold and after highway drives.. about 3cms over the full. I also started to notice hard jerks when I was on and off the throttle..(think of applying the brakes hard when the tranny was making a shift). This usually happened when the tranny was cold and from 1st to 2nd gear.
I brought it back to the dealer and they drained ˝ liter of fluid (now a mix of Z1 & DW1). On the highway the next day I downshifted using the sportshift and it banged hard into gear. I brought it back to Acura and told them to do another drain and fill… because the fluid must have got aerated from being over-full. (approx 6L DW-1 and 3L Z1)
The car no longer banged hard into gear.. but it also was slowly turning from Winter to Spring.. and the tranny fluid was much warmer… it’s been about 7 months with the DW1 in the tranny.. and it was almost back to normal minus the occasional sharp shifts that have made driving kind of uncomfortable. It has made me extremely sensitive to transmission shifts in any car.. including our new Toyota.
I went back to have one last tranny drain and fill done.. to completely run DW-1… no real change.. I still feel every shift. The shift points also seem to be different, shifts faster than I would expect for other gears and slower from 1st to 2nd.
I have had the Acura dealer drive the car cold and warm on two difference occasions. They find nothing wrong with the tranny. I’ve spoken with a few transmission shops and they explain that DW-1 is doing what it should and making the shifts harder.
I’m considering going BACK to Z1 just to get the smooth shifts I purchased this car for.. is that a waste of time? I know Z1 has a pretty bad rep, but it worked great in my car.. butter smooth shifts. Use to love driving my car, now I look for every excuse not to drive it.
2011 Toyota Venza V6 6AT
2005 Acura TSX 5AT
2002 Honda Civic Si 5MT (Sold)
1999 Mazda Protege LX 4AT (Sold)
#2348465 - 08/16/11 02:41 PM Re: The switch from Honda ATF Z1 to DW-1.... issues. [Re: 2K5TSX]
2K5TSX Offline
Just to add... I find the car drives best when it has been sitting for a few days. Also drives much better in moderate temps.. anything too hot or too cold and it shifts harder.
The mourning drive into work the car is pretty decent. Drive it home from work after sitting 8 hours it shifts harder. Stop and go traffic is like a nightmare.. so many 1st to 2nd shifts.
On the highway if I'm on and off the gas (say at 100km/h) there is a slight pause or disconnect between the power to the wheels and the gas pedal.
2005 Acura TSX 5AT
#2348468 - 08/16/11 02:44 PM Re: The switch from Honda ATF Z1 to DW-1.... issues. [Re: 2K5TSX]
229 Offline
Loc: Mid Atlantic
Friction modifiers do change the coefficient of friction and affect hydraulic actuation. Z1 is getting harder to find. A firmer shift will make a tranny last longer.
Eneos Dealer
#2348469 - 08/16/11 02:45 PM Re: The switch from Honda ATF Z1 to DW-1.... issues. [Re: 2K5TSX]
brandini Offline
Loc: Richmond, VA
I had a 07 Mazda6 with the newer Mazda FNR5 5-speed auto, cold mornings were sluggish for a few miles, things felt like an awkward teen on hotter days...
Switched to this:
http://www.amsoil.com/storefront/atf.aspx
On the COLDEST days the first shift of the day was slow, then perfect thereafter. Hot days became just like any other day, smooth shifts when i wanted them.
Don't do a drain and refill, do a flush, low or no pressure (uses the car's fluid pump to move the fluid). Then unplug the battery so the tcu will relearn from scratch.
07 Mazda3s Hatch - ZoomZoom - Using EAO-ALM-BF3-MTG-ANT-ATF
#2348475 - 08/16/11 02:48 PM Re: The switch from Honda ATF Z1 to DW-1.... issues. [Re: 2K5TSX]
Hokiefyd Offline
Loc: Virginia
I've changed 1/3 of my fluid out from Z-1 to the new DW-1 and the shifting has gotten smoother. Maybe it's just due to new fluid. Shifts are almost imperceptable now.
I have read that DW-1 is reported to make shifting firmer in colder temperatures, and the "solution" is to mix in some Z-1. I'm not sure how one is supposed to do that now that Z-1 is discontinued.
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
#2348480 - 08/16/11 02:51 PM Re: The switch from Honda ATF Z1 to DW-1.... issues. [Re: 2K5TSX]
tdpark Offline
Loc: New York
I have done 2 drain and refills with DW-1 and 04 odyssey shifts great. No Issuer or complaints here.
#2348482 - 08/16/11 02:52 PM Re: The switch from Honda ATF Z1 to DW-1.... issues. [Re: 2K5TSX]
229 Offline
Loc: Mid Atlantic
You may have some tranny solenoids getting weak or need an PCU flash update. My 2008 had a factory update reprogramming.
Eneos Dealer
#2348485 - 08/16/11 02:53 PM Re: The switch from Honda ATF Z1 to DW-1.... issues. [Re: 2K5TSX]
Pete591 Offline
Loc: Michigan
The bottom line from a Honda Service Bulletin:
A new ATF will be available for 2011 models in mid-July. Honda ATF DW-1 is the new transmission fluid that helps improve low temperature performance. Initial shipments will be arriving at your dealership soon. Please begin using ATF DW-1 on all 2011 AT models. For AT models 2010 and older, you can continue using Honda ATF-Z1. Future communications will be sent regarding the supply of ATF-Z1 and ATF DW-1.
DW-1 is semi-synthetic and backwards compatible.
I have a Honda Accord V-6 2010 and 2006 CRV.
My .02?
I am going to use DW-1
Edited by Pete591 (08/16/11 02:54 PM)
#2348516 - 08/16/11 03:24 PM Re: The switch from Honda ATF Z1 to DW-1.... issues. [Re: 2K5TSX]
chubbs1 Offline
Loc: Merritt Island FL, USA
I had a post earlier about using the DW-1 just a drain and fill with my brother's Civic. We can both tell it shifts better. Maybe try to change back to Z1. I hope there is no problem because I have heard more good reviews than bad and it has worked fine for us (no miracle) but a difference nontheless.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2348534 - 08/16/11 03:48 PM Re: The switch from Honda ATF Z1 to DW-1.... issues. [Re: 2K5TSX]
2K5TSX Offline
Well unless you hoard some Z1.. all Honda trannies will be on DW-1 if they stick to Honda fluid eventually. I really don't like how it drives. Maybe there can be an unrelated issue... praying for a motor mount issue.. the car also vibrates at 100km/h when on and off the gas... (not tire related).. and vibrates at idle while in gear... maybe related.. maybe not.
2005 Acura TSX 5AT
#2348550 - 08/16/11 04:05 PM Re: The switch from Honda ATF Z1 to DW-1.... issues. [Re: 2K5TSX]
Pete591 Offline
Loc: Michigan
Amsoil or Valvoline or M-1? Thoughts?
What does it mean on the bottle when it say "not for CVR".?
#2348552 - 08/16/11 04:07 PM Re: The switch from Honda ATF Z1 to DW-1.... issues. [Re: 2K5TSX]
tdpark Offline
Loc: New York
That does sound like worn motor mounts and worn motor mounts can affect shifting feel.
#2348561 - 08/16/11 04:16 PM Re: The switch from Honda ATF Z1 to DW-1.... issues. [Re: tdpark]
2K5TSX Offline
I hope. The tranny otherwise shifts pretty clean.. no slip.. no loss in power.. just that I feel everything. Mechanic noticed the vibration and said my motor mount was on the way out.. and to wait for it to get worse to determine which one.. its not a simple tear to look for.. my front mount is vacuum controlled.. so its a sealed liquid mount. My rear mount is also fluid filled.
2005 Acura TSX 5AT
#2348608 - 08/16/11 05:07 PM Re: The switch from Honda ATF Z1 to DW-1.... issues. [Re: 2K5TSX]
Pete591 Offline
Loc: Michigan
What's the procedure to drain and fill as opposed to a full flush?
Think Valvoline is fine or Amsoil? or Royal Purple?
How much comes out and how much goes in?
DO you have to run through the gears to get air out?
What's the best way to do it or leave it to Honda?
Oh, also...some fluids say Honda Compatible" but not CVR compatible. What is CVR ...I assume it's not the CRV... ignorance IS SHOWING.
Also, do you need a new crush washer every time you drain and re-install the plug?
Edited by Pete591 (08/16/11 05:09 PM)
#2348781 - 08/16/11 08:34 PM Re: The switch from Honda ATF Z1 to DW-1.... issues. [Re: 229]
Happy Birthday The_Eric Offline
Loc: Iowa
Good suggestion with the re-flash.
Go back to the dealer and check for any re-flashes. If none are available, have them re-set the adaptives for the transmission and drive as you normally would after, so it can re-learn your driving habits.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
