Just an interesting question
by southernjeeper
05/26/16 01:52 AM
Value power Walmart battery acid flying out
by bbhero
05/26/16 12:44 AM
Leased 2013 Ford Suv With19,882 Miles Original Oil
by crazyoildude
05/25/16 10:35 PM
Steak-House Burgers
by sleddriver
05/25/16 09:53 PM
Got into an accident.
by bdcardinal
05/25/16 09:42 PM
Its coming here more and more
by CourierDriver
05/25/16 08:40 PM
Interpreting oil pressure vs engine RPM
by Emperors6
05/25/16 08:39 PM
$4 Fram Ultra - Blain's F&F
by Poohbah
05/25/16 08:21 PM
Toolbox - Pliers
by greasegunn
05/25/16 08:09 PM
ProSelect Oil Filter????
by qwerty1234
05/25/16 08:05 PM
Completing your 80% lower with a CNC Machine
by Merkava_4
05/25/16 07:33 PM
Motor oil Sale
by GuinnessGuy
05/25/16 07:26 PM
jerryg, 1971tr350, Mak712, Lex4TDI4Life, cdub76
57988 Registered Users
27 registered (asand1, Burt, Bandito440, Astro14, 4 invisible), 583 Guests and 283 Spiders online.
57988 Members
66 Forums
249411 Topics
#2348560 - 08/16/11 04:15 PM Fresh from Canada -- Rotella T5 0w40 Blend
Matt_N Offline
Loc: Akron, OH
BITOG'ers,
I was in Toronto over the weekend, and stopped at a Canadian Tire on my way back to Ohio. I wanted to check out their oil selection, of course!
I left the store with a 5L jug of Shell Rotella T5 0w40 synthetic blend...don't see that in the US! My intentions were to use it in my wife's '06 Jetta TDI this coming winter (currently using RT6 5w40 all year).
Upon closer inspection of the bottle, I see that this oil is CF / CG-4 / CF-4 / SJ Certified. Those are pretty old certifications -- my question is -- should I hesitate before using this in my wife's 2006 Jetta TDI this winter?
Thanks,
Matt
#2348563 - 08/16/11 04:17 PM Re: Fresh from Canada -- Rotella T5 0w40 Blend [Re: Matt_N]
addyguy Offline
Loc: Canada
Nope. Rotella oils are top-notch.
This isn't a blend, it's a full-syn - the T5 10W-40 is a blend, AFAIK.
2010 Kia Soul 2U - 2.0L I-4, auto, 85k miles.
QSGB 5W-20, NAPA select filter(?)
#2348568 - 08/16/11 04:21 PM Re: Fresh from Canada -- Rotella T5 0w40 Blend [Re: Matt_N]
BobFout Offline
Loc: Indiana
Originally Posted By: Matt_N
BITOG'ers,
Thanks,
Matt
AFIAK only CI-4+ and CJ-4 API oils have been used in PD TDIs. You would be in uncharted waters using a CG-4 oil.
2003 VW Jetta TDI (Sold) / 2015 VW GTI 2.0T
#2348572 - 08/16/11 04:26 PM Re: Fresh from Canada -- Rotella T5 0w40 Blend [Re: Matt_N]
BobFout Offline
Loc: Indiana
BTW, I would to try this oil in my VE TDI!
#2348639 - 08/16/11 05:49 PM Re: Fresh from Canada -- Rotella T5 0w40 Blend [Re: Matt_N]
scurvy Offline
Loc: Chicago IL USA
I also would not use it in your wife's PD. Nor would I use Mobil 1 0w40, several cars running it on TDIClub have succumbed to the dreaded cam/lifter wear.
I'd continue using T6 or one of the other excellent CJ-4 synthetic 5w40 oils out there - Mobil 1 TDT, Schaeffer 9000, Amsoil DEO, Red Line, etc...
You are entitled to your own opinion but not your own facts.
06 VW Golf TDI: Schaeffer 9k 5w40, HU726/2x, EaBP90
12 Mazda 5: Amsoil SSO 0w20, FL910S
#2348832 - 08/16/11 09:39 PM Re: Fresh from Canada -- Rotella T5 0w40 Blend [Re: Matt_N]
Matt_N Offline
Loc: Akron, OH
[censored]. Any suggestions for what I do with this stuff? It was $40, and I kinda can't return it now ;-).
Would you put it into a 2002 BMW 525iT with the M54 motor?
I was so excited when I bought it...didn't look at the API certs. Haha.
#2348843 - 08/16/11 09:46 PM Re: Fresh from Canada -- Rotella T5 0w40 Blend [Re: Matt_N]
BobFout Offline
Loc: Indiana
Does BMW allow API SJ oil in it?
You could sell it on BITOG....rare item here in the US laugh
#2348859 - 08/16/11 10:05 PM Re: Fresh from Canada -- Rotella T5 0w40 Blend [Re: addyguy]
Garak Offline
Loc: Regina, Saskatchewan, Canada
I believe it's a blend, at least it pretty much says so on the bottle. The T5 0w-40 says synthetic technology or something to that effect, while the T6 5w-40 says full synthetic.
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#2349001 - 08/17/11 04:33 AM Re: Fresh from Canada -- Rotella T5 0w40 Blend [Re: Matt_N]
dnewton3 Offline
Loc: Indianapolis, IN
As far as I understand the marketing approach, all the T-5 products are "blends" (meaning semi-syn in our BITOG world). If it says T-5 on the label, it's semi-syn.
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#2349089 - 08/17/11 08:23 AM Re: Fresh from Canada -- Rotella T5 0w40 Blend [Re: Matt_N]
scurvy Offline
Loc: Chicago IL USA
I would, without hesitation or worry. The double VANOS system might not like it - although they seem to work fine on Mobil 1 0w40, so who knows.
#2349405 - 08/17/11 02:20 PM Re: Fresh from Canada -- Rotella T5 0w40 Blend [Re: Matt_N]
Ken2 Offline
Loc: Washington St.
Shell Rotella T5 0W-40 data sheet:
http://www-static.shell.com/static/can-en/downloads/shell_for_businesses/oils_lubricants/1-54.pdf
I agree with the postings above...excellent oil, but not suitable for every engine including VWs.
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
#2349761 - 08/17/11 08:51 PM Re: Fresh from Canada -- Rotella T5 0w40 Blend [Re: Matt_N]
Matt_N Offline
Loc: Akron, OH
I checked the BMW owner's manual today. They spec the BMW Synth 5w-30 (of course), but otherwise only mention using an API SH 5w30 or 5w40 when that is not available. No mention of BMW LL-01 or ACEA A3/B3 in the owner's manual...kinda surprised me.
I think I'll try the T5 0w40 in the BMW this winter and see how it does. Last winter I ran M1 0w40 and sustained quite a bit of fuel dilution and visc loss (ended up in the mid 11's @ 100C). We'll see if this does any better...more than likely it's just my driving cycle. Frequent short trips don't help. Maybe an HDEO will better cope with fuel...
#2388801 - 09/26/11 07:30 PM Re: Fresh from Canada -- Rotella T5 0w40 Blend [Re: Matt_N]
OceanDoctor Offline
Loc: Canada
With the SJ rating, I wouldn't worry about cam wear like I would with M1 0w40
370K '97 Camry 2.2L - Winter Fill 50/50 PC 0w30 / Honda 0w20
150K '05 Pontiac G6 - 25% PYB 5w20 25% Honda 0w20 50% PC 0w30
#2390936 - 09/28/11 10:11 PM Re: Fresh from Canada -- Rotella T5 0w40 Blend [Re: OceanDoctor]
Smokefan1977 Offline
Loc: Gilbert, AZ
I'd love to get my grubby hands on some of this. Is it in Canada Only?
2000 F350 7.3 4X4- Highly modded. Redline 15-40
99 F150 2wd. Mobil 0-40 MC820S
07 F150 2wd. Ultra 5-30 or Redline MC820S
