Decent Wireless Computer Headset?
by 99Saturn
06/25/16 11:41 PM
Need Fuel Pump Assembly for Camry
by Nick1994
06/25/16 11:36 PM
2015 Accord V6 VCM engine UOA 36,680 mi / 9812 OCI
by TNM1982
06/25/16 10:55 PM
Why did Toyota recommend a winter and summer oil?
by BrianApp
06/25/16 10:00 PM
Fram TG 7317 6k miles
by bbhero
06/25/16 09:57 PM
Sta-Lube Moly-Graph Grease
by JHZR2
06/25/16 09:20 PM
Dead battery locks me out of Altima!
by Tom NJ
06/25/16 08:56 PM
Second lawn mower blade
by greasegunn
06/25/16 08:11 PM
Echo weed trimmer - carb issue?
by ryan2022
06/25/16 07:13 PM
Reviving Old Hard Rubber Experiment
by sleddriver
06/25/16 04:47 PM
Where do pets go?
by Whitewolf
06/25/16 04:47 PM
Help reading Bosch 3330 date code
by beavis87
06/25/16 04:11 PM
paul2005tb, Martyaus, carmelo, Shellman, SSO
58272 Registered Users
64 registered (2015_PSD, 67lemans, abycat, austinlunsford, AntsinmyEyes, 7 invisible), 1279 Guests and 8 Spiders online.
58272 Members
66 Forums
250817 Topics
#2339138 - 08/06/11 11:56 AM Should I use Lucas Transmission Fix additive ???
gn2 Offline
Loc: Kingston, Ontario
I've got a 2002 Toyota Camry V6. New to me, with high mileage but running really nice. The previous owner put a used transmission in about 18 months ago.
I've done two drain and fills using PetroCanada Duradrive MV ATF, marked as "Synthetic" on the bottle. From what I read, its a high quality synthetic ATF appropriate for this transmission.
What I'm wondering is if I should ALSO add a bottle of Lucas Transmission Fix additive ?
I've noticed some "funny" working at low speed with this trans, it seems to "flutter" a bit, hunting a bit when you're just easing along taking your foot on and off the gas. When you put your foot into it, everything is fine and when you accelerate smoothly up to highway speed, you can't even feel the shifts...
Are there any negatives to adding the Lucas ??
I've done a few searches here and can't find anything definitive, nor even any strong opinions...
#2339142 - 08/06/11 12:04 PM Re: Should I use Lucas Transmission Fix additive ??? [Re: gn2]
DrDusty86 Offline
Loc: TX
My opinion, Don't do it. I would change the filter if you haven't already done so. Also try disconnecting the battery for 15 minutes to attempt to let the transmission "relearn" your style of driving.
Dusty
#2339144 - 08/06/11 12:06 PM Re: Should I use Lucas Transmission Fix additive ??? [Re: gn2]
Eddie Offline
Loc: Florida, Cape Coral
I would not add anything other than the recomended ATF based on the issues you alluded to. Lucas products seem to not be highly recomended on this site. Maybe others will advance their opinions on thsi. Ed
CX5 Touring 2.5L :-)
#2339145 - 08/06/11 12:06 PM Re: Should I use Lucas Transmission Fix additive ??? [Re: gn2]
pbm Offline
Loc: New York
I know that LUCAS products are generally thought of negatively on this site but I knew a guy who had over 200K on a 2001 Civic A/T using Lucas A/T additive. (I guess the trouble-prone tranny liked the thickening effect).
I prefer Lubeguard Red myself.
I wish I was able to buy that PC MV ATF here in the states.
What does it cost per quart?
#2339153 - 08/06/11 12:12 PM Re: Should I use Lucas Transmission Fix additive ??? [Re: gn2]
Mr Nice Offline
Loc: Orlando, FL
NO !!!!!!!!!!!!!!!!
Clean fresh ATF is your best investment.
2007 Civic EX
2006 Accord SE
2005 RSX base
#2339160 - 08/06/11 12:26 PM Re: Should I use Lucas Transmission Fix additive ??? [Re: gn2]
Lead Shoes Offline
Loc: Mn
At the most add a bottle of lubegard red or friction modifier...
1992 BMW 325i 176k
Castrol 0w40/Mahle
#2339166 - 08/06/11 12:28 PM Re: Should I use Lucas Transmission Fix additive ??? [Re: Lead Shoes]
SuperDave456 Offline
Loc: Dallas, Texas
+1 for Lubegard Red.
Also, dropping the pan and cleaning things out along with changing out the filter does A LOT for strange transmission issues.
That being said, are you doing drain and fills via drain plug or cooler line?
#2339246 - 08/06/11 02:21 PM Re: Should I use Lucas Transmission Fix additive ??? [Re: gn2]
EricF Offline
Loc: SF Bay Area
Lubegard Red if you feel the need to add something.
Otherwise stay faw away from all Lucas products.
they're nothing more than thickeners.. tranny's don't like thick oils.
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
#2339253 - 08/06/11 02:33 PM Re: Should I use Lucas Transmission Fix additive ??? [Re: SuperDave456]
gn2 Offline
Via drain plug...
The MV was expensive($9.99/L) because I bought it right from a gas station. I was in a hurry, the next batch will be direct from the regional supplier. Even at $9.99/L, it was the least expensive synthetic I could find anywhere here in Kingston, my next least expensive was Royal Purple at $13.50/L. Amsoil was $16./L and that was the extent of choices I had...
Thanks for the feedback on the Lucas, I'll hold off on it and look for some of this Lubegard Red stuff that does get recommended.
#2339693 - 08/06/11 09:44 PM Re: Should I use Lucas Transmission Fix additive ??? [Re: gn2]
The_Eric Offline
Loc: Iowa
I agree with the others - no Lucas is needed. You also should either disconnect the battery for 10+ minutes or better yet, get the adaptives cleared for the transmission. Also check with the dealer to see if there is a reflash needed. Mine (Hyundai) had a reflash for it that solved similar problems.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
#2339959 - 08/07/11 10:28 AM Re: Should I use Lucas Transmission Fix additive ??? [Re: gn2]
Donald Offline
Loc: Upstate NY
Go with a Magnefine filter. But first change the factory filter and clean the pan.
Quality synthetic ATF is your best bet.
My 1994 Camry was running fine at around 220K using Amsoil ATF for the last 100K miles. It had the Magnefine.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#2340122 - 08/07/11 01:40 PM Re: Should I use Lucas Transmission Fix additive ??? [Re: gn2]
CBR.worm Offline
Loc: Jupiter, Fl
I wouldn't add anything other than the correct ATF.
'06 Infiniti G35 Sedan 6MT - 160k
#2344381 - 08/11/11 10:18 PM Re: Should I use Lucas Transmission Fix additive ??? [Re: gn2]
gn2 Offline
Just wanted to update, I did three drain and fills with the synthetic and added Lubegard Platinum on the last one. I think the Lubegard is the key difference. There was little change in shift action after the first one, but it got very slightly better after the second, and immensely better after the last one. The nature of the change is a faster shift, and more solidly in gear after the shift, no more "hunting" action.
Before the change, hard acceleration produced good, but also noticeable shifts, after the last, the hard acceleration now produces very fast shifts that I can't even tell when they occur.
#2344664 - 08/12/11 09:18 AM Re: Should I use Lucas Transmission Fix additive ??? [Re: gn2]
meep Offline
Loc: Southeast
was gonna say-- I think your ATF was not appropriate for the trans and you were feeling TC partial modulation. LG is probably what helped... because the friction properties of the fluid likely were not correct by themselves.
M
2006 Tundra 2wd
2002 MDX (wifey!)
2005 s60 2.4L
#2346502 - 08/14/11 09:42 AM Re: Should I use Lucas Transmission Fix additive ??? [Re: gn2]
71Chevyguy Offline
Loc: Martinsburg West Virginia
Yeah stay away from the Lucas unless you know your tranny is shot and you are just trying to make it "seem" like it is fine to trade the car or sell it. Have used Lucas in the past to hide problems but it is not a "FIX"
15 Chevy Sonic RS QSUD / Delco filter
85 Buick Skylark 2.5 VNGHM / PF52
87 Caprice 305
71 Nova 250
