Car has 247000 miles. 2.1 liter water cooled, oil bearing, intercooled turbo with 12 psi. K-jet mechanical fuel injection with a few slight mods. Engine has never been open.
Oil is AME 15W-40 Synthetic HD Diesel oil. About a qt of make up oil over 10K. Sump is 6 qts.
I drove hard this OCI. I pulled a trailer and used lots of boost. I blew a radiator during this OCI. I used lots of FP and tested regular fuel and had some super BAD knocking sessions….the car is my commuter beater, dump run, campmobile. Sits out year ‘round.
The oil is well over 6 months old. Amsoil recommends 6 months max for gas turbos. I went near 10 months. Amsoil also recommends 3X the mfr’s OCI, and I was about dead nuts on that.
This seems like a strange analysis to me. This car has never had Cu or Na over 10 ppm, yet Cu a 22 and Na at 18 seems weird. OTOH, this is the first OCI that I didn’t change the oil filters. I have a generic dual remote and ran two Motorcraft FL-1A’s. The car has an oil cooler, and this is the first analysis after a thorough AutoRx cleaning.
I use an Amsoil foam filter, I was thinking about dumping it. 5 ppm Si? 3 ppm Al and Fe at 6 ppm say: Keep it! And the silly thing I haven’t cleaned the air filter for well over a year. A turbo with an intercooler has miles of area to spring leaks, but I check the hoses and clamps regularly.
The oil thinned a bit (note: did not thicken). Oxidation and Nitration seem nominal, especially for a turbo. TBN at 7.14 seems to be pretty equal to or a bit less than previous OCI’s.
Now I’ve changed to 50/50 mix of same oil and Pennzoil LL 15W-40.
code:
Fe 6
Cr 0
Pb 10
Cu 22
Sn 0
Al 3
Ni 0
Ag 0
Si 5
B 5
Na 18
Mg 33
Ca 2230
Ba 0
P 906
Zn 1123
Mo 2
Ti 0
K 0
Fuel
Vis (cSt) 12.03
H2O 0
Glycol Neg
TBN 7.14
Oxi 7
Nit 26
