Static electricity accumulation of earth and human
by yvon_la
05/30/16 07:26 AM
18.14F this morning....
by Shannow
05/30/16 06:09 AM
Why it's a bad idea to ignore wheel-bearing noises
by Tegger
05/30/16 03:29 AM
Water decarbonization, does it work?
by FordCapriDriver
05/30/16 01:56 AM
Do I need a better tire for PNW trip?
by The_Eric
05/29/16 11:51 PM
Turtle Beach PC headset hack
by asand1
05/29/16 11:34 PM
Lengthy question for the seasoned oil gurus
by Jetstreamz06
05/29/16 11:10 PM
Jeep Cherokee Heater Valve - Brands?
by Nick1994
05/29/16 11:00 PM
Hyundai Entourage/Kia Sedona minivans
by Number_35
05/29/16 10:41 PM
Oil in air breather tubing
by Nissan101
05/29/16 10:06 PM
Dust caps needed to protect wheel bearings?
by Drew99GT
05/29/16 09:51 PM
2014 Mazda CX5 SkyActiv
by Matt_V
05/29/16 09:38 PM
kevinstoyhauler, jimx1169, W9HDG, LloydChristmass, dodge96
58019 Registered Users
61 registered (74DartSport, BobS, 3800Series, 94astro, bigt61, Atesz792, 3 invisible), 1073 Guests and 260 Spiders online.
58019 Members
66 Forums
249586 Topics
#2330292 - 07/28/11 11:00 AM Shell Rotella T 5w40 VOA
BobFout Offline
Loc: Indiana
Shell Rotella T 5w40 (API CJ-4, CI-4+, CI-4, CH-4, CG-4, CF/SM), Cummins CES 20081, Cat ECF-2 and ECF-3, DD 93K218, Mack E0-0 Premium Plus, MB 228.31, Volvo VDS-4
2003 VW Jetta TDI (Sold) / 2015 VW GTI 2.0T
#2330398 - 07/28/11 12:31 PM Re: Shell Rotella T 5w40 VOA [Re: BobFout]
chubbs1 Offline
Loc: Merritt Island FL, USA
Virtually no difference from the T6. That being said its hard to say which oil would have better TBN retention, low temp performance etc. I think I would choose this over the T6 with price factored in.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2330996 - 07/29/11 12:10 AM Re: Shell Rotella T 5w40 VOA [Re: chubbs1]
BobFout Offline
Loc: Indiana
The CJ-4 RTS to CJ-4 T6 transition (this has been about 2 years ago) was mostly a base-stock and/or VII change.
#2331230 - 07/29/11 09:32 AM Re: Shell Rotella T 5w40 VOA [Re: BobFout]
sm00thpapa Offline
Loc: Spring Hill, FL
Well for bikes it makes a difference. T6 is JASO MA certified and the T isn't.
16 Sonata Sport
16 Elantra SE
09 FZ6R
04 Ascender
96 Cavalier
#2331310 - 07/29/11 11:01 AM Re: Shell Rotella T 5w40 VOA [Re: sm00thpapa]
Quattro Pete Offline
Loc: Great Lakes
Mostly likely only because SOPUS didn't bother to have it tested against JASO MA before.
The add pack hasn't changed, and that's the main determinant of the friction modifier test results of JASO MA spec.
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#2449189 - 11/30/11 12:07 PM Re: Shell Rotella T 5w40 VOA [Re: BobFout]
Loobed Offline
Loc: Northern California, USA
Is the numbers for magnesium and calcium reversed?
Calcium seems low for such high TBN @ 786
Does the magnesium compensate for the calcium?
Engine: 2001 GM 5.3L LM7
Current Fill: Valvoline Synpower 5w-30 w/Pure-One PL25288 filter
I.M.N Oil Enthusiast
#2491041 - 01/12/12 10:03 AM Re: Shell Rotella T 5w40 VOA [Re: BobFout]
shpankey Offline
Loc: Tulsa, Oklahoma, USA
Yes, as I understand it anyways.
06 VW Jetta TDI, M1 5w40 TDT
01 GMC Jimmy, 196k mi Pennzoil Ultra 5w30, Pure 1 oil filter
#2501235 - 01/21/12 12:21 PM Re: Shell Rotella T 5w40 VOA [Re: BobFout]
Gokhan Offline
Loc: Los Angeles, California
I would personally stay away from this oil because its Ca / Mg ratio is less than 1 (well less than 1 indeed). Mg is certainly corrosive and increases wear at high ratios; although, it's a good TBN retainer (helps retain initial TBN).
Answering question on high initial TBN, both Mg and Ca will result in increasing the high initial TBN. They both come from detergents, which means they are both bases (as in total base number [TBN]).
I like the high ZDDP (phosphorus) though. But the unusually large ratio of Mg in this oil is enough for me not to consider it.
Thanks for the VOA, as always.
1985 Toyota Corolla LE, 4A-LC engine, ~ 263,000 M
Mobil 1 (M1) 0W-40 SN synthetic
Toyota 90915-YZZF2 filter, 90430-12031 drain gasket
