How much are you paying for TC-W3?
by BrewCityR
06/18/13 10:51 PM
Long term use of Honda OEM oil filters
by gregk24
06/18/13 10:35 PM
MMO, again
by CourierDriver
06/18/13 09:56 PM
Discount Tire Direct pre 4th of July sale
by stephen9666
06/18/13 09:36 PM
Lense recommendation for a Canon 60D body?
by Kruse
06/18/13 09:32 PM
Questions about Toyota Celica GT/GTS
by Lillikai
06/18/13 09:21 PM
Is Royal Purple API-licensed dexos1-licensed?
by barlowc
06/18/13 09:06 PM
Supertech High Mileage ATF
by TechnoLoGs
06/18/13 08:46 PM
WTB: 1 or 2 quarts of Honda Z1 atf
by vinu_neuro
06/18/13 08:40 PM
12' Ford Super Crew 3.5 Ecoboost - what oil ??
by Boost00
06/18/13 08:31 PM
2000 lincoln conti floorboards flooding ?????
by OtisBlkR1
06/18/13 07:59 PM
Mityvac 7400
by 2James1
06/18/13 07:28 PM
Snowball, jin1234, BigDuke6, gl10, ufomorme
45904 Registered Users
63 registered (2ndgenrx7, aquariuscsm, 6x6man, ajchien, bdcardinal, 7 invisible), 871 Guests and 250 Spiders online.
45904 Members
64 Forums
195331 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
Page 1 of 2 1 2 >
#2329235 - 07/27/11 10:04 AM Oil change before or after storing car for winter?
HuberMini1 Offline
Loc: Ohio
I will not be driving my car during the winter months. I was wondering if it makes a difference changing the oil before it sits vs when I pull it out in the spring. I also assume I should start it a few times a month to cycle the oil.
Thanks,
Todd
#2329237 - 07/27/11 10:06 AM Re: Oil change before or after storing car for winter? [Re: HuberMini1]
electrolover Offline
Loc: TEXAS
i would change it in the spring, its not gonna hurt old oil to sit
2004 F150 5.4 160k-Castrol TXT 5/40, Distance+ 3410-KREEN
2004 Explorer 4.0 130k-PU 5w30, Distance+ 3410
#2329246 - 07/27/11 10:12 AM Re: Oil change before or after storing car for winter? [Re: HuberMini1]
hypervish Offline
Loc: new jersey
Change it before, because the oil already has contaminants in it. You don't want them to just sit in the engine for the whole winter. You want clean and fresh oil in the engine.
2000 Lexus RX300 AWD 195k miles
QSUD 0W-20
Castrol Transmax Import Multi-Vehicle ATF
Transfer Case and Rear Differential- Royal Purple 75w-90
#2329252 - 07/27/11 10:19 AM Re: Oil change before or after storing car for winter? [Re: HuberMini1]
Donald Offline
Loc: Upstate NY
Boaters always change their oil in the fall and have clean oil in the engine for the lay-over.
In reality, if the TBN in the oil is still high enough it will have neutralized any acids in the oil and thus your bearings will not be damaged by old oil.
On the other hand, an oil change in the fall or spring costs the same, so why not do it in the fall?
2001 Jeep Grand Cherokee Laredo 4.0 - PU 10W30 & D+
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
Amsoil ATF in both vehicles & Magnefine filter.
#2329256 - 07/27/11 10:23 AM Re: Oil change before or after storing car for winter? [Re: HuberMini1]
Norm Olt Offline
Loc: Pac NW
Maybe in storage (outside) in Nome, AK, it might make a slight difference...
What about the contamination of the new oil?
Or, in the alternative, what about the acids in the old oil eating holes through the engine block all winter long?
I guess you could just change it before AND after...
Or, not at all?
Just kidding: take it out for a nice, long drive once and a while and things will be just fine.
Cheers!
01ValkyrieIS 6K
93ZX-11D 30K
87F250 183K
88420SEL I. 178K
88420SEL II. 212K
91420SEL 220K
92SVX 182K
00Nighthawk250 1.5K
93SC400 90K
85F150 4.9 "Granny" 103K
#2329257 - 07/27/11 10:25 AM Re: Oil change before or after storing car for winter? [Re: HuberMini1]
gathermewool Offline
Loc: SE CT
1. It doesn't matter, unless you ran the oil out to the end of its life.
2. Do not start your car during the winter just to warm the engine up. Either take it for a decently long drive or hook up a trickle charger and leave it be.
FWIW, there are eleventy billion threads on this, so, if you don't find the "right" answer that you're looking for here, I'm sure you will via Google.
08 WRX STI
50/50 Mag1/T6 5W-40 + Subaru H6 filter
08 Civic LX (Auto)
50/50 Edge 0W-20 / Amsoil Euro (Low-SAPS) 5W-30 + Fram Xtended Guard (2nd OFI)
#2329292 - 07/27/11 10:58 AM Re: Oil change before or after storing car for winter? [Re: gathermewool]
HuberMini1 Offline
Loc: Ohio
Thanks for the advice. I never had a car that I would be garaging for the winter before and just wanted to make sure I wasn't breaking some golden rule. It sounds like as long as I change it on the "normal" basis I will be fine. Thanks again.
#2329309 - 07/27/11 11:14 AM Re: Oil change before or after storing car for winter? [Re: HuberMini1]
johnachak Offline
Loc: NY USA
You should add fuel stabilizer. IMO
06 Ford Freestyle, MC / kendall syn 5w20 MC filter
09 CTS 3.6 D.I. AWD, M1 5w30 Delco filter
Every so often Penzoil Platinum in both.
JMH
#2329317 - 07/27/11 11:23 AM Re: Oil change before or after storing car for winter? [Re: HuberMini1]
ARCOgraphite Offline
Loc: N.H, U.S.A.
GMwool's advice is solid, but since folks do things based on emotion: Fresh oil + jack stands b4 storage and fuel stabiliser of your choice. Aside: I just saw both of my neighbors throwing out their homelite weed whackers - exact same model as mine. I guess they didnt add fuel stabilizer or maybe, TC?! That homelite engine would make a nice model airplane engine I would guess, NO? I brought them home to check out and my wife made me put them back in their trash frown
Edited by ARCOgraphite (07/27/11 11:25 AM)
2012 Honda Fit Sport 5MT, OC#4 13,7kmi-QSUD 0W20SN+WIX 57356 Filter
2011 Forester 5MT 5Door, OC#6 42Kmi-QSUD 0W20SN+TokyoRoki 130 Filter
#2329328 - 07/27/11 11:33 AM Re: Oil change before or after storing car for winter? [Re: hypervish]
pbm Offline
Loc: New York
EXACTLY...
Some people change it again in the spring which I consider a waste of time and oil.
Nothing will happen to fresh oil in the crankcase over the winter.
Starting the car for a few minutes every couple of weeks (in the winter) may do more harm than good.
#2329329 - 07/27/11 11:33 AM Re: Oil change before or after storing car for winter? [Re: HuberMini1]
SteveSRT8 Offline
Loc: Sunny Florida
Whatever you do, do not put the car up on jack stands. Hanging the suspension out like that is usually a BAD idea.
And as mentioned above, if you can't DRIVE it for at least 20 minutes or so don't even start it up.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#2329340 - 07/27/11 11:41 AM Re: Oil change before or after storing car for winter? [Re: HuberMini1]
WishIhadatruck Offline
Loc: Grand Rapids, MI
For one year I did not use my Grand Prix much due to having 3 cars for a year and a half. I was waiting for my '94 GP to die or not be worth fixing and stored my '01 GP during much of that time.
Oil drained out in July2006 was in there for about 4 months and was run 4900 miles.
Oil drained out in Sept2007 was in there for 14 months and the car was stored all winter long plus some of the other months of the year and had 5700 miles on it.
Both oils were M1 10W-30
Look at this thread for my UOA history. They would be the two UOA's all the way to the right just left of the universal averages. To me the difference was not significant and the storage was nothing to worry about.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2064633
For my lawn tractor that sits all winter, I just change it in the fall.
1996 Buick Roadmaster Wagon
2001 Pontiac Grand Prix
#2329346 - 07/27/11 11:50 AM Re: Oil change before or after storing car for winter? [Re: SteveSRT8]
Loc: N.H, U.S.A.
Steve, I didnt mean off the ground, but I wasnt clear smile It seems even going in for an alignment or up on a lift something happens to struts when they are fully extended to screw up handling and steering. Also, tight control arm bushing may creep around and then leave the car on tip toes for months after hitting the ground again. The Twilight Zone of weird car effects ...
#2329355 - 07/27/11 11:59 AM Re: Oil change before or after storing car for winter? [Re: HuberMini1]
Eddie Offline
Loc: Florida, Cape Coral
For only 3+ months oe so, I would not change and continue to follow the normal oil change interval. You mention starting a couple of times. I would not do this unless I was goine to drive it to full warm or about 10 miles at each startup. I would also consider charging the battery every month or so if I did not drive the vehicle. JMTs. Ed
#2329356 - 07/27/11 12:01 PM Re: Oil change before or after storing car for winter? [Re: HuberMini1]
mechtech2 Offline
Loc: Chicago Area
Raising the car to unload the tires and suspension is fine.
it does not have to hamg - you ca split the difference.
Change the oil before you sore it.
Page 1 of 2 1 2 >
