Trailer light wiring
by Donald
05/24/13 06:59 PM
Advance Memorial Sale 20% off + $50 coupon on $100
by tenderloin
05/24/13 05:58 PM
Old Engine Motor Oil
by VintageMonte
05/24/13 05:50 PM
Cruze Diesel hitting dealer lots
by Finklejag
05/24/13 05:48 PM
Bar's Leak rear main seal conditioner...
by OneEyeJack
05/24/13 05:13 PM
2013 6.7 F350 LE 5w40 4276mi
by BeerCan
05/24/13 04:04 PM
Another K-mart commericial.
by simple_gifts
05/24/13 03:58 PM
Super Amazon Prime Deal on M1 plus M1 Filters
by BerndV
05/24/13 03:27 PM
S2000 vs rx8 R3
by donnyj08
05/24/13 03:22 PM
Oil filter capacity and oversizing thoughts...
by KCJeep
05/24/13 03:17 PM
Pump shotgun or Taurus Judge for home defense?
by TaterandNoodles
05/24/13 03:12 PM
Mobil 1 EP vs Amsoil Signature Series 5W-30
by BerndV
05/24/13 02:10 PM
Kenber, eage8, macattictom, Miggz10, stevesnj
45545 Registered Users
109 registered (AmishFury, abycat, 05LGTLtd, AlienBug, aquariuscsm, 95busa, 13 invisible), 1470 Guests and 251 Spiders online.
45545 Members
64 Forums
193887 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
Page 1 of 2 1 2 >
#2321006 - 07/19/11 04:06 PM what is a good fan belt dressing
coconut_lover Offline
Loc: wa., usa
Does any one have experience with fan belt dressings? Do you have any to recomend to me? Is the one made by gunk any good?
Thanks guys!
#2321016 - 07/19/11 04:14 PM Re: what is a good fan belt dressing [Re: coconut_lover]
wallyuwl Offline
Loc: Lexington, KY
The only dressing I like is Western.
If the belt squeaks it is most likely worn out. Replace it and the tensioner.
#2321021 - 07/19/11 04:19 PM Re: what is a good fan belt dressing [Re: coconut_lover]
Donald Online   content
Loc: Upstate NY
If the belt is tensioned properly then its probably worn out or damaged. As has been mentioned, check the belt tensioner(s), rust or grease or anything similar on the pulleys.
Forget belt dressings.
2001 Jeep Grand Cherokee Laredo 4.0 - PU 10W30 & D+
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
Amsoil ATF in both vehicles & Magnefine filter.
#2321026 - 07/19/11 04:22 PM Re: what is a good fan belt dressing [Re: Donald]
river_rat Offline
Loc: Iowa
+1
You are asking for tow truck trouble by not replacing.
I have temporarily stopped squeals with bar soap, but only to get another belt and tensioner.
#2321083 - 07/19/11 05:26 PM Re: what is a good fan belt dressing [Re: coconut_lover]
chubbs1 Offline
Loc: Merritt Island FL, USA
If you have to use some in the meantime, Pyroil (made by Valvoline) is the best out of many I have tried. It was the only one that worked on my old Jeep Cherokee.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
PYB 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
M1 0w40 OEM
#2321103 - 07/19/11 05:50 PM Re: what is a good fan belt dressing [Re: coconut_lover]
Trav Offline
Loc: MA, Mittelfranken.de
None. Seriously they just mask a problem for a short time.
IMHO one of those worthless products that doesn't even belong on the market.
ASE L1, Master. Deutsch Meisterbrief
#2321115 - 07/19/11 05:56 PM Re: what is a good fan belt dressing [Re: coconut_lover]
229 Offline
Loc: Mid Atlantic
Use Gates products and change the belt and/or the belt tensioner. Fix any coolant or oil leaks that may get on the belt.
Eneos
#2321219 - 07/19/11 07:46 PM Re: what is a good fan belt dressing [Re: coconut_lover]
Rick in PA Offline
Loc: Southeastern, PA
I've used WD-40 to temporarily quiet a chronically squeaky belt, it didn't last. I tried some sort of spray on belt dressing once, and then it started squealing like the proverbial "stuck pig". Yeah, new belt time...
"Heat is your friend."
#2321228 - 07/19/11 07:54 PM Re: what is a good fan belt dressing [Re: coconut_lover]
Spector Offline
Loc: Richmond, VA
Never havehad luck with any dressing, either very short term relief or made it worse
#2321304 - 07/19/11 08:58 PM Re: what is a good fan belt dressing [Re: coconut_lover]
berniedd Offline
Loc: A Warm place to live in
Belt dressings are a temporary fix. Replace the belt ASAP.
#2321525 - 07/20/11 01:04 AM Re: what is a good fan belt dressing [Re: coconut_lover]
mjoekingz28 Offline
Loc: I-55 @ I-20
Go through the Dayco Q and A. It used to be recommended on here to put dielectric grease on the belt. We tried that and belt dressing before and what actually worked was.............a new belt.
#2321642 - 07/20/11 07:57 AM Re: what is a good fan belt dressing [Re: coconut_lover]
MetalSlug Offline
Loc: Garland, Texas
Replace the bell
Anti-Snake oil
Anti-Hoarding
Say yes to QS DEFY and say no to Jeep 4.0
#2321890 - 07/20/11 12:07 PM Re: what is a good fan belt dressing [Re: coconut_lover]
mechtech2 Offline
Loc: Chicago Area
I've tried a lot, and all sorts of substitutes.
Many things will work for a while, but usually end up being noisier than before.
Belt dressings are OK for ancient leather drive belt systems -maybe.
But on modern belts, forget it!
#2322380 - 07/20/11 07:39 PM Re: what is a good fan belt dressing [Re: coconut_lover]
artificialist Offline
Loc: Florida
Replacing the belt and whatever is failing on the belt drive is the only solution.
My dad once tried using canned belt dressing on a 1995 Honda Accord. The noise quickly came back, and under the hood, there was a real mess where the belt dressing got thrown off the belt.
2010 Lancer Ralliart Sportback
#2322645 - 07/21/11 12:53 AM Re: what is a good fan belt dressing [Re: coconut_lover]
AdRock Offline
Loc: Texas
Out of everything I ever used over the years silicone spray worked the best.
However, if the belt looks ok and the tensioner seems to be working.. Try taking the belt off and cleaning all the pullies with a good carb cleaner or something of the such. Check the belt, both sides, to see if anything is on it or for any abnormalities.
Check and see if either edge of the belt has more wear than the other. I've seens pullies out of alignment very slightly that would end up causing any belt to start sqealing eventually.
HOWEVER, 9 times out of 10, I'd give the same advise I gavemy customers. Replace the belt AND/OR the tensioner.
2002 Mustang GT
Page 1 of 2 1 2 >
