Mobil 1 Full Synthetic $3.99 AR Menards
by John_K
Today at 10:32 PM
Causes of steering wheel shudder
by buck91
Today at 10:14 PM
Brand new Focus ST...
by Striker
Today at 09:55 PM
Chevy Volt bad idea for BITOG members!
by kohnen
Today at 09:22 PM
Looking for oil suggestion Chevy Express 3500 6.0L
by Goofball1205
Today at 08:38 PM
What ATF? 2004 Toyota Sequoia 4WD
by ShadowSix
Today at 08:35 PM
Tundra steering wheel
by RN89
Today at 08:11 PM
98-02 Corolla and Oil Consumption
by mmorri16
Today at 08:10 PM
How does fuel dilution affect HTHS viscosity?
by HKPolice
Today at 07:58 PM
Volkswagen bets big on EV(Electric Vehicle)
by HTSS_TR
Today at 07:50 PM
Did I goof?
by mv6845
Today at 07:33 PM
Opinions on Indestro tools?
by Vern_in_IL
Today at 07:25 PM
sledhead1, AtillatheHunk, Goofball1205, Djlmedic, BigHoss256
58926 Registered Users
43 registered (bvance554, BrocLuno, cb4017, BrownParticles, bbhero, bdcardinal, 4 invisible), 1029 Guests and 23 Spiders online.
58926 Members
66 Forums
253566 Topics
Page 1 of 3 1 2 3 >
#2318842 - 07/17/11 06:21 PM 2005 Honda 2.4L (CR-V) valve adjustment...yes/no?
Chris Meutsch Offline
Loc: Cincinnati
Subject says it all. Coming up on 110k where the manual says to inspect valve adjustments and adjust only if needed.
Indy mechanic is doubtful this is needed. I drive 90% highway.
Your opinions?
"I've never heard 'Taco Bell' and 'tasty' mentioned in the same sentence before."
---mclasser, 7/25/16
#2318846 - 07/17/11 06:28 PM Re: 2005 Honda 2.4L (CR-V) valve adjustment...yes/no? [Re: Chris Meutsch]
229 Offline
Loc: Mid Atlantic
The valves have been tight on every one I have checked even at half your mileage.
Eneos Dealer
#2318849 - 07/17/11 06:30 PM Re: 2005 Honda 2.4L (CR-V) valve adjustment...yes/no? [Re: Chris Meutsch]
Eddie Offline
Loc: Florida, Cape Coral
The first thing I would do is with a fully warm engine listen to the engine. I would use a Lent of dowel rod and use it as a stethoscope. Theo hear the tapping from each set of valves. If any sound much different then a readjustment is in order. You should hear a tapping from each valve, which shows there is some Clarence as no tapping can lead to exhaust valve burning. How much does it cost to follow the factory recommendation to do it?
CX5 Touring 2.5L :-)
#2318867 - 07/17/11 06:44 PM Re: 2005 Honda 2.4L (CR-V) valve adjustment...yes/no? [Re: Chris Meutsch]
Viggen Offline
Loc: Bath, ME
I have a 94 Accord 2.2L. It also hase manually adjustable valves as well.
I'd be interested to hear from a Honda tech about this. I don't know if the valves have ever been adjusted in this car.
127k mi now. No problem except a bit of oil weep from the valve cover gasket.
Edited by Viggen (07/17/11 06:44 PM)
#2318869 - 07/17/11 06:46 PM Re: 2005 Honda 2.4L (CR-V) valve adjustment...yes/no? [Re: Viggen]
229 Offline
Loc: Mid Atlantic
You did.
Eneos Dealer
#2318872 - 07/17/11 06:46 PM Re: 2005 Honda 2.4L (CR-V) valve adjustment...yes/no? [Re: Chris Meutsch]
1999nick Offline
Loc: Germantown TN 38138
Do the latest Honda engines have hydraulic valve lifters?
#2318879 - 07/17/11 06:50 PM Re: 2005 Honda 2.4L (CR-V) valve adjustment...yes/no? [Re: 1999nick]
Loc: Cincinnati
No idea on the very latest but my generation certainly doesn't. I would like to hear why they don't, yet my 1989 Mazda did. What is the advantage of non-hydraulic lifters?
#2318885 - 07/17/11 06:54 PM Re: 2005 Honda 2.4L (CR-V) valve adjustment...yes/no? [Re: 229]
The_Eric Offline
Loc: Iowa
Did you mean to say "Twice your mileage"? Because not needing adjustment at 55k isn't too terribly impressive and really doesn't speak to the o/p's valve clearance condition.
Now if you'd have said "most of them, even at 220k don't need adjustment", that would definitely inspire confidence.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
#2318898 - 07/17/11 07:06 PM Re: 2005 Honda 2.4L (CR-V) valve adjustment...yes/no? [Re: Chris Meutsch]
JOD Offline
Loc: PNW/WA
You absolutely at a minimum should pull the valve cover to inspect them. You can only hear them if they're loose; a tight one is just going to burn out.
On a friend's CRV 2003 @ 60K, all of the rears were too tight (though they did all have some clearance) and one or two intake valves were slightly loose. This is too easy/cheap of a job not to do it.
#2318914 - 07/17/11 07:23 PM Re: 2005 Honda 2.4L (CR-V) valve adjustment...yes/no? [Re: The_Eric]
229 Offline
Loc: Mid Atlantic
I have seen them tight at 55K miles. By tight I do not mean in spec. I consider tight to be worse than loose because it will burn the valves. You will not hear valvetrain noise with tight clearances, at least until the seats recede or the valvestems break and drop a valve.
Eneos Dealer
#2318918 - 07/17/11 07:27 PM Re: 2005 Honda 2.4L (CR-V) valve adjustment...yes/no? [Re: Chris Meutsch]
Artem Offline
Loc: Florida
My 07 Si with the K20 engine (smaller brother of the K24 the OP has in his CR-V) has 100k on it and i'm also about to pull the valve cover to inspect the valve clearance. I doubt anything is off by much since the engine runs smooth as can be.
2015 Lexus ES300H with all the goodies - Factory Fill
2014 Mazda 3 Hatch i Touring 2.0L & 6spd - Mazda 0w20
#2318919 - 07/17/11 07:27 PM Re: 2005 Honda 2.4L (CR-V) valve adjustment...yes/no? [Re: The_Eric]
fdcg27 Offline
Loc: OH
What 229 was saying, I think, is that he found the valve adjustment too tight at half the OP's mileage.
Too tight is not good for the exhaust valves, since if they are too tight they may not seat fully, and may not be able to transfer heat to their seats and may burn.
The valve clearances on a Honda are not difficult to check or to adjust.
You will have to turn the engine over with a wrench a few times, but it is an entertaining Saturday afternoon project.
If I were the OP, I'd check mine, or have it done.
12 Accord LX 53K HGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 159K Delvac 15W-40
#2318924 - 07/17/11 07:28 PM Re: 2005 Honda 2.4L (CR-V) valve adjustment...yes/no? [Re: Chris Meutsch]
Viggen Offline
Loc: Bath, ME
@229....
As the cars age (Honda specifically the 2.2L I have )is it more imporant or less important to check the valves at a certain mileage? I do OC every 5k miles. Car is generally gently driven (engine not revved a lot. )
I assume you work or worked for a Honda dealer how much is reasonable for a valve adjustment job on my 2.2L 4?
Edited by Viggen (07/17/11 07:29 PM)
#2318928 - 07/17/11 07:31 PM Re: 2005 Honda 2.4L (CR-V) valve adjustment...yes/no? [Re: Chris Meutsch]
229 Offline
Loc: Mid Atlantic
The valves have been tight on every one I have checked.
I am seriously thinking about checking it on mine even though it only has 11,000 miles.
Eneos Dealer
#2318930 - 07/17/11 07:33 PM Re: 2005 Honda 2.4L (CR-V) valve adjustment...yes/no? [Re: Viggen]
229 Offline
Loc: Mid Atlantic
@229....
Yes, worked. Now I have a tougher boss. @$75
Eneos Dealer
Page 1 of 3 1 2 3 >
