Getting hurt at work
by ram_man
08/28/16 04:46 AM
Brake Pad Shims a MUST?
by SavagePatch
08/28/16 01:34 AM
Bean Counters vs Swedish Engineering
by Y_K
08/28/16 12:04 AM
Interesting website for comparing guns
by 901Memphis
08/27/16 11:45 PM
Android clear cached data
by expat
08/27/16 11:07 PM
Worm gear vs spring type hose clamps?
by TheLoneRanger
08/27/16 10:35 PM
Factory fog lights...common wiring and wattage?
by ryan2022
08/27/16 10:32 PM
2 Hyundai/Kia OEM Filters cut open
by KD0AXS
08/27/16 10:30 PM
Preferred SUV for snow: Large FWD or smaller AWD?
by Carbon12
08/27/16 09:55 PM
Chevron 5W-20 $10/5-quart at WM
by wgtoys
08/27/16 09:15 PM
Best alternative to FL500S
by buck91
08/27/16 09:11 PM
New router?
by Quattro Pete
08/27/16 08:44 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
28 registered (1foxracing, BrianF, BobsArmory, Bottom_Feeder, bmod305, 2004tdigls, 3 invisible), 669 Guests and 33 Spiders online.
58943 Members
66 Forums
253658 Topics
#2317765 - 07/16/11 02:28 PM Kawasaki FR/FS/FX V-twin initial oil change
GeneralEclectic Offline
Loc: Lehigh Valley, PA
New tractor with Kawasaki FR691 726cc "24 hp" V-twin. Nice motor - smooth, instant starting, surprisingly quiet, fuel-efficient, perfect speed regulation v. load, all in all, looks very good so far in the 3 hours it has on it. Not only that, it's laughably easy (5 minutes for everything, tops) to change the oil on this thing. They clearly had easy serviceability in mind when they designed this series of motors.
Last time after 40 minutes of mowing, the temperature on the oil filter was 231F. That seems a little on the high side, given that the ambient was only 81F at the time and it had been running at full speed, 3480 RPM, so air flow should have been adequate.
What's the factory oil in these motors? Some kind of dino oil, presumably. They don't tell you what's in it, only that you need to change it (without filter change) at 8 hours.
I'm kind of thinking that with this relatively high operating temperature, it wouldn't be a bad idea to switch it over to M1 5W-30 and a new filter right now.
Any opinions one way or the other?
#2317775 - 07/16/11 02:55 PM Re: Kawasaki FR/FS/FX V-twin initial oil change [Re: GeneralEclectic]
rainman49 Offline
Loc: Alabama
I'm running Mobil 1 TDT 5w-40 in my Scag Zero-Turn with a 26hp Briggs ELS engine and my Kawasaki Prairie 650 ATV with a V-Twin. I live in Lower Alabama, where it gets HOTTTTT! Consumption is nil on the Kawi and the Briggs sips only a few ounces per cutting season.
'11 BMW 528i - BMW 5w-30
'99 Volvo S70 - QS 5w-40
'01 F250 5.4L - MC 5w-30
'02 Kaw ATV 650 - M1 TDT 5w-40
'06 Scag Fr. Z - M1 5w-40, 15w-50 tran.
#2317790 - 07/16/11 03:06 PM Re: Kawasaki FR/FS/FX V-twin initial oil change [Re: GeneralEclectic]
Freedom-Z. That's a NICE machine. I almost bought one of those (the narrow 36" one) but decided against it because of towing a Cyclone Rake on all the slopes around the house. There's not a single square foot of level ground around here.
Does yours have the ZT-2800 or 3100 hydros in it? What oil are you using in those, the M1 5W-50?
#2317876 - 07/16/11 05:33 PM Re: Kawasaki FR/FS/FX V-twin initial oil change [Re: GeneralEclectic]
rainman49 Offline
Loc: Alabama
I think I've got the ZT-2800s. I think they went to 3100s in either '08 or '09. I used Mobil 1 15w-50. Best money I've ever spent on lawn equipment. My yard is flat as a pancake, so you probably made the right choice with all those hills.
#2318435 - 07/17/11 10:41 AM Re: Kawasaki FR/FS/FX V-twin initial oil change [Re: GeneralEclectic]
Cujet Offline
Loc: Jupiter, Florida
I've switched all my equipment (except for the water pumps and generator) to Mobil 1, 5W-40 TDT. It's a robust oil, well up to the challenges of small engines.
The generator and pump use Mobil 1, 15W-50 with stellar results. (remember that the 11HP aircooled generator may run at 100% for hours, powering the water heater)
Turbo's rule.
#2318451 - 07/17/11 11:07 AM Re: Kawasaki FR/FS/FX V-twin initial oil change [Re: GeneralEclectic]
car54 Offline
Loc: Wdbg, VA
All my aircooled equipment gets an xw-40 or xw-50. It runs too hot, IMO for an xw-30.
I have a Kohler V-twin with thousands of hours at work using cheap 15w-40 Napa all fleet.
All my home equipment is 5w-40 M1 turbo diesel truck or Mobil1 15w-50.
#2318539 - 07/17/11 12:42 PM Re: Kawasaki FR/FS/FX V-twin initial oil change [Re: GeneralEclectic]
Thanks to all for the recommendations. FWIW, Kawasaki recommends a 30wt oil for all ambient temperature conditions.
My question really centered around making a change prior to the 8 hours of use Kawasaki recommends. I think a synthetic, any one, is likely to let that motor run cooler. I doubt that there's a lot of wearing-in that's going to go on after 3-4 hours of operation at full speed, too.
So what's the consensus? Change it after the next mowing, which would be about 3.5 hours, or wait until 8 hours is on it?
BTW, I have a total of 6 four-cycle small engines, all of which use M1 either 10W-30 or 5W-30, and all of which see intermittent/seasonal usage. They all stay pristine clean in the crankcase and none of them (even the ancient, beat-up Tecumseh on the $70 rotary push mower) uses a drop of oil. It's an impressive track record.
(I like that "car54" UID. Hahaha. I haven't thought of that program in years.)
#2319635 - 07/18/11 01:47 PM Re: Kawasaki FR/FS/FX V-twin initial oil change [Re: GeneralEclectic]
deeter16317 Offline
Loc: SE, PA
I have an 08 JD Gator with a Kawi 19HP, I run 5w40 Schaeffers in it...doesn't even seem to change color in the 25+ hours its been in use (some of it in 100* weather).
2004.5 Dodge 2500 Cummins
