ACDelco 5W-30 dexos1
WA
Looks like a very good motor oil. I like the add pack and I assume it is a XOM product by the looks of the bottle?
This looks almost identical to the Motorcraft syn-blend made by Conoco Phillps
Code:
ALUMINUM 1
CHROMIUM 0
IRON 1
COPPER 1
LEAD 0
TIN 0
MOLYBDENUM 79
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 1
POTASSIUM 5
BORON 234
SILICON 5
SODIUM 1
CALCIUM 2135
MAGNESIUM 10
PHOSPHORUS 740
ZINC 858
BARIUM 0
TBN TOTAL BASE 7.32
VIS 100C CS 8.5
OX 7
NIT 9
Interesting how close it looks to Motorcraft. I guess it's a Mobil syn-blend base oil, with whatever add-pack that is, blended in.
Looks like a good oil.
Yep. the bottle surely looks XOM to me. Maybe it is the same add pack bought from the same company like Lubrizol or Infineum and blended, just a different company basestock? Perhaps there is no connection at all but never know.
Well considering XOM owns half of Infineum......
and Shell the other half if I remember correctly
Correct. So that would be my bet on the origin of the add pack
The add-pack here, coincidentally, is very close that in M1 0W-40.
It must work well in high-stress situations.........
Dexos-1 oils seem to all be around 11cst. I'm assuming they need to be a bit thicker to deal with turbo/high heat conditions that are part of the equation......
You would think with all the hype and spec discussion this would have been a full synthetic.
If I were to buy a blend I think the Motorcraft would be my choice.
Why build a better product than you need to?
