Stapled down carpets ???
by Oldtom
07/29/16 01:51 AM
MicroGard (Wix) 57047 ~7k miles
by MrQuackers
07/29/16 01:24 AM
Ford 4.6 with Supercharger, 2,000 mi. / yr.
by milkboy
07/29/16 12:50 AM
Only secure content is displayed?
by Eddie
07/28/16 11:35 PM
2008 Honda Element oil question
by fujirio
07/28/16 09:50 PM
TIRE QUESTION
by renegade_987
07/28/16 09:46 PM
What's your favorite outboard and why ??
by BrocLuno
07/28/16 09:30 PM
Briggs 'Quantum 6.0' Flathead top no load 2600RPM
by Colt45ws
07/28/16 09:15 PM
EPA efficiency testing may not work, at all
by wemay
07/28/16 09:11 PM
Mobil 1 0w40 for 2013 4.8 V8
by CapitalTruck
07/28/16 09:04 PM
2013 Passat service
by powersmo
07/28/16 08:24 PM
A/C troubleshoot
by Leo99
07/28/16 07:50 PM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
23 registered (Black_Thunder, car51, CLOVER, brslds, 3 invisible), 855 Guests and 10 Spiders online.
58632 Members
66 Forums
252385 Topics
Page 1 of 4 1 2 3 4 >
#2311018 - 07/09/11 10:26 PM Oil / filter suggestions for 2012 Hyundai Elantra
schuylkill Offline
Loc: Pennsylvania
I am planning ahead for oil and filter to use on my 2012 Elantra. Currently have 3100 miles and changed oil and filter at 2K to PYB 5w-20 and PureOne. Reading here that was not necessary but that's where I'm at. The car is used mostly for an 80 mile each way daily commute to and from work. I'm an old, slow driver looking for max mpg, hence I bought the 6 speed MT Elantra. Manual suggests to use Quakerstate Energy Conserving Oil, API Service SM, ILSAC GF-4 or above and 5w-20 for best fuel economy. Range is 5w-20 to 10w-30 depending on temperature. Change interval for normal conditions is 7500 miles. I drive abut 70% highway miles and the rest stop and go. I live in a hilly section of Pennsylvania. The filter is located on the front bottom of the engine and there is no shield protecting it like on the last model Elantra so I am thinking of staying with the Hyundai filter now that I've compared the stock filter to the PureOne. The casing is much heavier and would likely better withstand a stone shot. I am also thinking I should install a light weight aluminum sheetmetal shield, in which case the outer durability of the filter would not be an issue. Any thoughts on the filter, any data on Hyundai filters? I am thinking that if I use synthetic oil 7500 miles would be ok. I would prefer Pennzoil to Q-State, but that's mostly because my Dad didn't like the looks of his lower end when he tore his 70 Malibu engine down and he used Q-state and then switched to Pennzoil. But that was long ago. I have a 98 Civic with 600K on it and I used mostly PYB in it, now 350K on current engine. Thoughts on Qstate vs. Pennzoil and dino vs. synthetic? Also what about a bypass if I want to get max miles on the engine? I don't know how that would fly with the warranty, but if I'm going to do it I should do it now, right? Thanks for any thoughts.
91 Civic LX 170K Maxlife Hyundai OE
98 Civic CX, EX tranny 630K Maxlife P1
09 Elantra 26K Pennzoil Plat OE
12 Elantra GLS manual 131K Toyota bulk?
#2311034 - 07/09/11 10:48 PM Re: Oil / filter suggestions for 2012 Hyundai Elantra [Re: schuylkill]
wallyuwl Offline
Loc: Lexington, KY
Don't do anything to void your warranty. That is the first thing. If the Hyundai filter is more heavy duty, and you are concerned about stones hitting it, then use the OEM. With your type of driving you should get more than 7500 miles out of a synthetic. I'd use your preferred synthetic for that interval, drain a small amount and get a UOA (used oil analysis - spelling it out because you are new here so not assuming you know what that means), and go from there regarding how long you can go.
#2311100 - 07/10/11 01:22 AM Re: Oil / filter suggestions for 2012 Hyundai Elantra [Re: schuylkill]
Trajan Offline
Loc: SE PA
Use what the mfg wants you to use while under warranty.
No muss. No fuss.
Edited by Trajan (07/10/11 01:23 AM)
Lack of harm is not proof of benefit.
There are in fact two things, science and opinion; the former begets knowledge, the later ignorance. Hippocrates
#2311101 - 07/10/11 01:23 AM Re: Oil / filter suggestions for 2012 Hyundai Elantra [Re: schuylkill]
Gene K Offline
Loc: Decatur AL USA
Factory Hyundai Filter is very good and priced well. As for oil I think the oil you have in it would be an excellent choice. No need to go to synthetic. I would get a UOA simply because some of the Direct Injection Engines (Not Hyundai specifically) are having issues with fuel dilution. If that occurs you may want to shorten the drain interval to 5000 or 3750 miles depending on how severe it is.
Gene
2014 Mustang GT 5.0 SC - 675 bhp
PP 10W30 / FL500S
2015 F150 4x4 2.7 EB
PSB Gold 5W30 / FL2062
2015 Enclave 3.6
GM Dexos 5W30 / PF63
#2311106 - 07/10/11 01:42 AM Re: Oil / filter suggestions for 2012 Hyundai Elantra [Re: Gene K]
cmf Offline
Loc: Florida
The 2012 Elantra that is sold in North America is a MPI engine, not DI. I think people assume it's DI because the gas mileage is amazing for a compact (beats the sub-compacts). I test drove an Elantra and I really liked it, it was peppy for a compact (even with the AC on).
The Hyundai filter is a good filter, there will be no issue using it.
I wouldn't use QS just because the manual recommends it, those recommendations are.. silly. I personally would use a synthetic for 7,500, that's what I do with my Sonata. That's just my opinion though, I'm sure you could use a conventional for 7,500 with similar results.
My opinion on the bypass is that if you can uninstall it without the dealer knowing it was ever there, go for it. If not, I would wait until the warranty was over. While I would not expect you to have any issues during the warranty period, it would be awful if you did have an issue and could not get it taken care of. Plus that 100k warranty is a huge selling point for a lot of people, it'd be a shame to waste it!
#2311110 - 07/10/11 01:50 AM Re: Oil / filter suggestions for 2012 Hyundai Elantra [Re: schuylkill]
Gene K Offline
Loc: Decatur AL USA
Thanks CMF. Brain Fade, I was thinking the new Elantra was GDI like the Sonata and Accent.
Gene
PP 10W30 / FL500S
2015 Enclave 3.6
#2311161 - 07/10/11 07:23 AM Re: Oil / filter suggestions for 2012 Hyundai Elantra [Re: schuylkill]
sopususer Offline
Loc: High Country of Western NC
You're certainly not going to have any problem with PYB, but if you do want to go synthetic, just about any direction you go, you'll get a great quality oil. I know Hyundai recommends QS, and as posted, I wouldn't use it just because my manual mentioned it, but price point wise the Quaker State Ultimate Durability would be an excellent synthetic choice and would save a few $$ over most other name brands. However Pennzoil Platinum/Ultra currently has some coupons as well. Either would be a great choice. Since Shell owns both Pennzoil and Q State, I wouldn't worry too much about the way things used to be back in the 70's. Either brand will be a great choice.
2012 Chevy Cruze 1.4T
QSUD 5W30/AC PF2257G
2014 Chevy Silverado 5.3
NAPA Syn 0W20/AC PF63
2015 Subaru Legacy 2.5
PPP 0W-20/Wix 57055
#2311344 - 07/10/11 11:18 AM Re: Oil / filter suggestions for 2012 Hyundai Elantra [Re: schuylkill]
Boss302fan Offline
Loc: Oconomowoc Wi
My Hyundai dealer recommends and uses Mobil 1 5W20 if you request a syn oil. I use it in my 3K mile 2011 Santa Fe and it runs quiet and smooth.
John P
Wisconsin
2006 Lexus LS 430
1990 Jaguar XJS V12
2011 Hyundai Santa Fe V6
Other fun cars
#2311654 - 07/10/11 03:51 PM Re: Oil / filter suggestions for 2012 Hyundai Elantra [Re: schuylkill]
Travis99LS1 Offline
Loc: NC
What kind of real world mpg are you getting with your new elantra?
2015 Ford Fiesta ST..Oxford white..Orange Recaros
#2311675 - 07/10/11 04:15 PM Re: Oil / filter suggestions for 2012 Hyundai Elantra [Re: schuylkill]
rossn2 Offline
Loc: Ft Hood Texas area
I have a 2011 Elantra, automatic with 4 cyl and get 40mpg on highway. Changed oil and filter (OEM) at 5k and put in Motorcraft semi-synthetic 5w-20 oil from Wally World. Can't beat the 5qt jug price..
Edited by rossn2 (07/10/11 04:16 PM)
2015 Ram 1500 Crewcab Laramie, 4x4, 3.21 rear and Hemi
2016 Hyundai Tuscon ECO 4cyl (33mpg)
2015 FLHTK (Stage IV kit, 106 HP) 2013 CVO Ultra,
#2311687 - 07/10/11 04:31 PM Re: Oil / filter suggestions for 2012 Hyundai Elantra [Re: rossn2]
JoeWGauss Offline
Loc: Peachtree, GA
Use any products that meet the specs set by Hyundai.
The brand doesn't matter the specifications and certifications DO!
This will keep your new car warranty intact.
#2311913 - 07/10/11 07:52 PM Re: Oil / filter suggestions for 2012 Hyundai Elantra [Re: JoeWGauss]
schuylkill Offline
Loc: Pennsylvania
I am averaging 45 mpg since new, last tank got 50 mpg. Have used same pump at same Shell station last few fill ups so it is a fairly accurate measure. I also have an ultra-gauge which I have calibrated and the the car's mpg gauge is 2-3 mpg over reporting.
See a good review with measurements here:
http://www.cleanmpg.com/forums/showthread.php?t=39256
Edited by schuylkill (07/10/11 08:01 PM)
#2311946 - 07/10/11 08:32 PM Re: Oil / filter suggestions for 2012 Hyundai Elantra [Re: schuylkill]
ChrisD46 Offline
Loc: GA.
I have a 2010 Elantra SE 2.0L Beta I-4 engine - with 8K miles on the odometer . I am getting 25 MPG in city and about 31 MPG on what limited highway trips I have taken (less than 40 mile stretches). Specs say I should get 26 MPG city / 34 MPG H'Way. So far I have not hit those marks using Tier 1 gas , a dash of TCW-3 (896:1 ratio) and primarily PYB 5W 20 . First oil change was at 1K miles , second oil change was at 4K miles and next oil change will come in the next few hundred miles (I am considering to switch to M1 , QSUD or PP synthetic 5W 20 and run a 6K miles / 6 month OCI ). I have the last model year for the sport suspension model Elantra - she rides a little stiff but handles very well . The Elantra's just seem to get better with each model year - I definately would consider getting one again .
#2312115 - 07/10/11 10:19 PM Re: Oil / filter suggestions for 2012 Hyundai Elantra [Re: schuylkill]
milehigh Offline
formally milehighhyundai
Loc: CO
I have a 2009 Elantra SE w/ 5mt. I average 35-37 mpg routinely and I use whatever synthetic is on sale w/ 5k OCI's. I normally run 5w20, for this summer (because it was on clearance) I am running 5w30 Edge (SM) and my mpg has dropped by 1.5 mpg. I'll be changing next month back to a 20 wt- not sure which one yet.
#2312223 - 07/11/11 12:25 AM Re: Oil / filter suggestions for 2012 Hyundai Elantra [Re: schuylkill]
AdRock Offline
Loc: Texas
Definitely use an OEM filter. I've seen more than a few Hyundai's with a little valvetrain noise when a non OEM filter was used. I also owned a 2003 Tiburon V6 and the one time I didn't use an OEM filter I had valvetrain noise. Put an OEM filtar back on and it was quiet as could be.
2002 Mustang GT
1995 Ford F150
2003 Honda Accord
