Subaru Oil Filter Installed in Dodge Ram Trans?
by dan0928
38 minutes 3 seconds ago
Mobil 5w30 Super 5,000 OCI, bought on clearance...
by FlyNavyP3
Today at 08:42 AM
Android 7 Nougat out.(nexus devices)
by Rand
Today at 07:58 AM
Australia to lose its ute?
by supton
Today at 07:42 AM
Should I continue using HM Oil after gaskets?
by Fahrenheit
Today at 07:03 AM
John Deere 400 garden tractor oil
by Bighorn2500
Today at 06:58 AM
Safety violation? who knows...
by CourierDriver
Today at 06:14 AM
82 Yamaha Virago 750 engine oil
by Trigger
Today at 06:02 AM
Supercheap Auto Father's Day Version 2 sale
by KL31
Today at 05:39 AM
$4 Off Fram Oil and Air Filter Combo
by Tony_Mack
Today at 05:37 AM
U joints
by dlundblad
Today at 04:41 AM
Yamaha Bolt XV950
by FWR132
Today at 02:12 AM
dan0928, basher, Bandita, DaveyJones, OldEuroCarLover
58904 Registered Users
93 registered (Alfred_B, AIRJAC3, 1foxracing, acbent, 2015_PSD, 4WD, 4 invisible), 1522 Guests and 7 Spiders online.
58904 Members
66 Forums
253485 Topics
Page 1 of 4 1 2 3 4 >
#2307456 - 07/06/11 04:18 AM Transynd Fluid?
disturban Offline
Loc: michigan
A lot of people on the Diesel forums are switching their Allison transmissions from Dexron VI to Transynd with fantastic results. They say the Transynd is a superior fluid even when compared to the almighty DEX VI, I was wondering if this is a fluid that would work well in other GM transmissions like the 4L60E or 4L80E?
#2307465 - 07/06/11 06:13 AM Re: Transynd Fluid? [Re: disturban]
Doug Hillary Offline
Loc: Airlie Beach Australia
Hi,
disturban - You must use a fluid with the correct specification - Dexron V1 may or not be part of the specification. As for Castrol Transynd it is an excellent product when used in the correct application and according to its specification
Regards
Doug
#2307478 - 07/06/11 06:40 AM Re: Transynd Fluid? [Re: disturban]
pbm Online   content
Loc: New York
I believe that fellow BITOGer Onion runs Transynd in his 4T65Es with great results. Look at some of his old posts.
#2307826 - 07/06/11 01:40 PM Re: Transynd Fluid? [Re: disturban]
Ken2 Offline
Loc: Washington St.
Transynd is the trade name for BP/Castrol's synthetic ATF that is licensed under Allison's TES-295 spec and formerly under the Dexron-III spec. Putting Transynd into a transmission made for Dex-VI is putting a syn Dex-III fluid into it. If the transmission was made for Dex-III, great, use any fluid that meets Dex-III specs or is licensed as TES-389, the same as Dex-III with a new name. If the transmission was made for Dex-VI and you put in a Dex-III fluid, the risk is yours.
By the way, there are other TES-295 ATFs licensed by Allison other than Castrol's Transynd, and there is also Amsoil's unlicensed TES-295 copy. And many syn fluids that either meet the Dex-III spec or are "recommended" where Dex-III was spec'ed.
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
#2308010 - 07/06/11 06:01 PM Re: Transynd Fluid? [Re: disturban]
onion Offline
Loc: kansastan
I've had Transynd in my '01 Lumina's 4T65e for the past 30K or so. This particular transmission didn't shift well when I 'upgraded' to DexVI (the 1-2 up-shift started a nasty slip & grab behavior at full throttle). Did a complete flush with Transynd and it solved the problem.
Transynd is a synthetic atf that meets DexIIIG specs, along with a laundry-list of industrial specs... and should work fine in any application calling for that.
As for whether Transynd or DexVI is 'better' in the Allison transmissions in those GM trucks- I dunno. From what I've read, there's very little in the way of 'proof' or solid info that's readily available to us mere consumers (lots of claims, lots of anecdotal evidence... very little in the way of data). The choice of OEM fluids in that particular transmission is based more on corporate politics than any distinct advantage. Personally I doubt you'd notice any real difference between the two.
In non-Allison applications calling for DexVI, I have no doubt that Transynd would work. But for how long? And under what conditions? And would it cause warranty issues? Transynd is a weird looking ATF once it gets some miles on it- turns a strange yellow color with a reddish tint... it would DEFINITELY be noticed by the tech if there was a warranty issue. IMO it would be analogous to putting a fluid like Amsoil, Maxlife, etc. into an application that wasn't designed for it (although one would assume that Amsoil and Valvoline have done some testing for automotive applications... I dunno if we can assume that with Transynd, with the exception of GM pickups. It would work- but you'd be taking your chances.
I've seen no reason to believe that Transynd is a "better" fluid than DexVI in any way. My own results tell me that the friction properties of Transynd are somewhat different than those of DexVI- and said friction properties of Transynd work better in my 230,000-mile 4T65e. But I wouldn't bet that everybody else would have the same experience. If a transmission was designed with DexVI in mind, the friction properties of DexVI would probably be more suitable than those of Transynd.
The invisible and the imaginary look exactly the same.
#2309211 - 07/07/11 10:31 PM Re: Transynd Fluid? [Re: disturban]
ledslinger Online   content
Loc: Missouri
My understanding of using tes 295 fluid in Allison transmissions, is there is a cutoff serial number where you can use Dex III before the cutoff, Dex VI after. tes 295 is recommended for heavy use applications and extended drain in Allisons. Allison has an extended warranty program that includes a requirement to use tes 295 fluid. The maintenence schedules show some impressive increase in change intervals. Some of the applications look pretty tough, such as garbage trucks with many starts per mile. The longest change intervals aren't allowed until after a couple of changes ensuring little dilution of the tes 295 fluid with the original fluid.
I changed the fluid in my 2003 Silverado with a 4L60 at 25K with Delvac tes 295. The original fluid spec was Dex III. It shifts very nice, maybe a bit better than the factory fluid. I am confident it is a durable fluid for my transmission.
#2310341 - 07/09/11 02:57 AM Re: Transynd Fluid? [Re: ledslinger]
disturban Offline
Loc: michigan
I have a 2000 4L60E that calls for DexIII, the first 100k on this truck was cushy driving and mostly freeway and at 100k I did a pan drop and filter change as well as flushed all fluid out and replaced with DexVI, I also added a Transgo HD2 Shift kit and billet servos and 4th gear super apply servo. I added a B&M drain plug also.
The truck has a custom tune on it and shift points and line pressure are tweaked. Now with 160k on it I have done two pan drain and refills, I plan on draining just the pan and refilling every 30k because the truck see's a lot of hard driving now, towing, off road, ect.
So far the transmission is holding up great and shifts are fast and firm, I was just curious about the Transynd because all the Allison guys are raving about it but it seems to me I have the superior fluid and it is working great so I am not going to change anything.
Thank you all for the info...this site rocks!
#2310375 - 07/09/11 06:16 AM Re: Transynd Fluid? [Re: disturban]
Whitewolf Offline
Loc: MI, USA
You are correct Transynd used to have a DEXRON-III approval but lost it in the G to H upgrade as it could not pass some of the more demanding requirements. Also compared to DEXRON-VI it is less durable in friction since it utilises a now comparatively old DEXRON-III additive package.
Probably fine for it's intended application but it is not magic.
The DEXRON-VI that you are using is superior for your application.
Edited by Whitewolf (07/09/11 06:16 AM)
My definition of an expert in any field is a person who knows enough about what's really going on to be scared.
~ PJ Plauger
#2310688 - 07/09/11 03:54 PM Re: Transynd Fluid? [Re: disturban]
Loc: Missouri
I found this article about Shell Donax TX. They are using the same approach as Scheaffer and Amsoil and not getting this fluid certified. They claim both Dex III H and TES 295 performance.
http://www.imakenews.com/rotella/e_article000539098.cfm?x=b11,0,w
This link doesn't work so copy and enter it in a google search. Or just google search Shell Donax TX. Shell's product info says it is semi-synthetic.
#2310897 - 07/09/11 07:46 PM Re: Transynd Fluid? [Re: ledslinger]
Whitewolf Offline
Loc: MI, USA
That is very interesting.
My question is how would one provide proof of performance when the given specification has been obsolete for a number of years?
Of course they will say that the formulation has not changed since it was originally approved. What else would you expect?
~ PJ Plauger
#2314756 - 07/13/11 11:38 AM Re: Transynd Fluid? [Re: disturban]
Loc: Missouri
Looking for more info on Transynd, I found an expert posting on several forums. Tom Johnson aka "Mr Transynd" worked for Allison 1990-2008 and wrote the specs for TES 295. If you do a google seach for Tom Johnson Mr Transynd, you will find several threads on RV, Duramax, and diesel forums. He seems willing to answer any questions posed about Allisons and fluids. It would be nice to compel him to join here.
#2315022 - 07/13/11 04:49 PM Re: Transynd Fluid? [Re: disturban]
onion Offline
Loc: kansastan
Now that would make for some fun reading... an oil-nerd fight between WhiteWolf and Mr Transynd. shoot
#2315113 - 07/13/11 06:51 PM Re: Transynd Fluid? [Re: disturban]
Loc: Missouri
Thanks for the "oil nerd alert!"
#2333205 - 07/31/11 12:50 PM Re: Transynd Fluid? [Re: disturban]
ForcedInduction Offline
Loc: Colorado
My shop uses Transynd in all our buses, 1st and 3rd gen ZF Ecomats. After 20k miles the oil is always brown and burnt. I believe its due to the small cooler and heavy retarder use but I honestly wouldn't use Transynd in any serious working vehicle.
1982 Mercedes 300D VNT
GT2356V VNT turbo, A/W intercooler, W/M injection, Mobil1 5W-40 and ATF.
#2334189 - 08/01/11 02:15 PM Re: Transynd Fluid? [Re: ForcedInduction]
Loc: Missouri
What other fluids have surpassed Transynd performance in this application?
