Deep tranny pan worth it?
by rsylvstr
06/26/16 07:20 PM
Which oil for my old BMW and why?
by fdcg27
06/26/16 06:20 PM
Synthetic blend for a Elantra
by car51
06/26/16 05:48 PM
Camshaft Adjuster Bolts - Replacement ?
by Ndx
06/26/16 05:45 PM
STP Synthetic
by travlnman
06/26/16 04:37 PM
Myliftstand alternative jack stand
by momo
06/26/16 03:33 PM
Kmart sale on Smitty's oil and ATF
by slacktide_bitog
06/26/16 02:53 PM
Napa master pack oil filter price
by Electromotive
06/26/16 02:39 PM
Local Big Lots still has Valvoline next gen 10w30
by Electromotive
06/26/16 01:25 PM
Best Value Differential Oil 75W-90
by KevinP
06/26/16 01:02 PM
kohler 17hp . changed oil , now will not run
by chad8
06/26/16 12:32 PM
Oil change recomendations for '11 Ranger 2.3 Liter
by ryan2022
06/26/16 11:49 AM
Ruturaj, derfderfgoose, ssnead, mtrev, redtacoma
58277 Registered Users
101 registered (bchannell, abycat, bbhero, 55hambone, 2015_PSD, bdcardinal, 11 invisible), 1753 Guests and 11 Spiders online.
58277 Members
66 Forums
250845 Topics
Page 1 of 2 1 2 >
#2303877 - 07/02/11 06:23 AM Best lubricant for key lock
MetalSlug Offline
Loc: vicksburg ms
what is best lubricant for key lock and ingnition lock. that last a long time in cold and freezing and hot weather. I dont like graphite lubricant since I have to clean my key every time i take off the key lock. It work great for me many year, just that cleaning part that I dont like about it. Any opinion is welcome.
2016 Nissan Titan XD Dealer oil + Nissan 15208-9E01A Oil Filter. Love this truck.
#2303888 - 07/02/11 06:42 AM Re: Best lubricant for key lock [Re: MetalSlug]
toyota62 Offline
Loc: Australia
I found silicone spray lube moving parts effectively..
Bob.
AIAME
2012 Rav4 Mobil1 EP 0w-20
2016 c250 diesel Mobil1 0w-40
#2303947 - 07/02/11 08:26 AM Re: Best lubricant for key lock [Re: MetalSlug]
hate2work Offline
Loc: Western Washington
Graphite is still your best bet. The key ( pun intended ) is to not put very much on and to insert and remove the key several times, wiping it off each time until the residual is mostly gone.
#2310084 - 07/08/11 08:46 PM Re: Best lubricant for key lock [Re: Kestas]
JoeWGauss Offline
Loc: Peachtree, GA
I'd stay away from graphite. I'd choose a dry lube with teflon. Sprays in liquid then dries on contact with parts.
#2310956 - 07/09/11 09:08 PM Re: Best lubricant for key lock [Re: MetalSlug]
boxcartommie22 Offline
Loc: moutain country
i use motorcrafts penetrating and lock lubricant..i spray it into the ignition switch..sometimes when new these things are stiff as with my 07 grand marq..works well!!
2001 Lincoln Conti,RL,K&N,Hotshots,Lubegard,Archoil
2007 Grand Marquis,RL,K&N,Hotshots,Lubegard,Archoil
2010 Raptor,RL,Hotshots,Lubegard,Archoil
#2312941 - 07/11/11 05:15 PM Re: Best lubricant for key lock [Re: MetalSlug]
kasedian Offline
Loc: Kansas
2010 BMW 328i Coupe
2008 Chevy Silverado 1500 4x4
1993 Chevy Silverado 1500
2005 Harley-Davidson FXDWGI
2011 Harley-Davidson FHLX
1980 Ford 1900 Tractor
#2566305 - 03/13/12 01:20 PM Re: Best lubricant for key lock [Re: MetalSlug]
zeke1985 Offline
Loc: Kenutcky
I had my lock on my car door jam up due to the use of graphite over the years. Took it to a lock shop and they told me never to use graphite due to the very problem I had..they use WD40
#2567176 - 03/14/12 10:10 AM Re: Best lubricant for key lock [Re: MetalSlug]
Vikas Offline
Loc: NorthEast
From what I know, the shop is wrong. Using WD40 on the lock means it will be more business for them. WD40 attracts dust. What you really want is the graphite either straight or in carrier liquid which evaporates away.
#2567219 - 03/14/12 11:16 AM Re: Best lubricant for key lock [Re: Vikas]
zeke1985 Offline
Loc: Kenutcky
Interesting. What about something like moly lube that dries to a slick surface?
#2575313 - 03/21/12 07:32 PM Re: Best lubricant for key lock [Re: zeke1985]
antiqueshell Offline
Loc: chicago, Illinois
I'd use DuPont Silicone spray with teflon, I use this for lock cylinders and while the silicone does wear away after a time the teflon coating seems to bond nicely to the metal surfaces and usually I don't have to reapply for years.
#2576837 - 03/23/12 12:46 AM Re: Best lubricant for key lock [Re: MetalSlug]
Tros Offline
Loc: Kansas
I've used WD-40 without any issue. Does it attract dust? Possibly! All I know is I've never had a single issue with any locking mechanism in all of my years of using the product. It sounds like this is one of those, "darn near anything will work well," moments. smile
Edited by Tros (03/23/12 12:46 AM)
2001 Mercury Sable 3.0L Duratec 45k
Current Fill: Castrol Edge Titanium 5w-20
#2578797 - 03/25/12 08:36 AM Re: Best lubricant for key lock [Re: MetalSlug]
AMC Offline
Loc: South Eastern, CT
I use Birchwood Casey's Barricade as my go to rust preventer for tools and guns. It is also a very light cleaner and dry lube. It will spray on wet and then drys to a slick, smooth, lightly lubricating finish which is perfect for locks too. It drives out moisture and dust and then dries quickly leaving perfectly smooth operatings tumlers inside the lock. It is the best thing for locks I have found, check it out.
http://sport.birchwoodcasey.com/Maintena...c5-621cf7a4425b
11 Chevy Silverado - PP 5w-30
10 Ford Focus - WH 5w-20
14 Yamaha Super Tenere - Delo 15w-40
1oz TCW-3 Per 5 Gallons of Fuel.
#2584452 - 03/30/12 10:09 PM Re: Best lubricant for key lock [Re: MetalSlug]
earlyre Online   sleepy
Loc: Lima, Ohio, USA
service writer @ our local ford dealer told my folks they use wd-40, esp in the late fall, to prevent the locks from freezing.
why? From Wikipedia:
"WD-40 stands for "Water Displacement – 40th Attempt". Larsen was attempting to create a formula to prevent corrosion in nuclear missiles, by displacing the standing water that causes it. He claims he arrived at a successful formula on his 40th attempt."
WD-40 - Wikipedia
so probably a small dose of WD-40, with a small chaser of graphite.
Mine:
09 Mercury Sable : 6qts QSAD 5w20,WIX 51516
Mine to Maintain:
03 Pontiac Vibe : 4.5qts QSAD 5w30,WIX 51394
#2587843 - 04/03/12 01:39 AM Re: Best lubricant for key lock [Re: MetalSlug]
tommygunn Offline
Loc: usa
WD-40 and graphite sounds like a good mix to get a graphite slurry that will permanently gum everything up.
i am a [censored] who hides behind bugmenot.
i also like applying negative pressure to a certain male appendage.
#2588408 - 04/03/12 02:52 PM Re: Best lubricant for key lock [Re: MetalSlug]
Tempest Offline
Loc: Las Vegas NV
I use Corrosion X Aviation with very good results.
“Never underestimate the difficulty of changing false beliefs by facts.” --- Henry Rosovsky
Page 1 of 2 1 2 >
