Taurus question
by Lubener
6 minutes 29 seconds ago
Lucas Extreme Duty CLP?
by Ws6
23 minutes 25 seconds ago
Pennzoil Ultra 5w20 / 7500mi / '08 Ford Fusion 3.0
by sdude2k2000
Today at 12:59 AM
Hairline Cracks in Radiator
by Merkava_4
Today at 12:05 AM
Super Tech Syn 5/30
by RevRider
Yesterday at 11:31 PM
Installing a dish washer.
by ram_man
Yesterday at 10:37 PM
Strangest Three Wheel Car Ever
by Fsharp
Yesterday at 09:57 PM
Remove Gasoilne and other Blowby Gasses
by landtoy80
Yesterday at 09:48 PM
Trans Am said goodbye to his battery today.
by ls1mike
Yesterday at 09:39 PM
Lil Big Rig - I want one
by montero1
Yesterday at 09:01 PM
[Cut Open] Champ PH2808 - Torn Pleat
by Bud_One
Yesterday at 08:41 PM
2015 silverado dealer oil change
by Realtech214
Yesterday at 08:27 PM
robco, TrogDorInjection, wytenow, maxud, OrchardAuto
56875 Registered Users
27 registered (dlundblad, Char Baby, B320i, an3_bolt, 5 invisible), 511 Guests and 206 Spiders online.
56875 Members
66 Forums
244480 Topics
#2301372 - 06/29/11 10:52 AM Replacement for Dexron IIE
anguscls Offline
Loc: KS
The manual for my Isuzu Rodeo says to use Dexron IIE for the power steering fluid. Apparently Dexron IIE is no longer available so I called my Isuzu dealer and asked them what to use. They told me to just go to O'Reilly and buy PS fluid. I pointed out there are a lot of differences between PS & ATF fluid. He told me they can no longer get Isuzu PS fluid so when they service one they just call O'Reilly and ask them to bring them some PS fluid. They don't specify anything.
Aside from quality of dealer issues I think I'm not getting adequate information.
I've seen a lot of discussion about Dexron IIE being surpassed by III which is also no longer available to GM specs.
My question is can I just use Dexron VI? Is there a better choice?
Thanks
#2301377 - 06/29/11 10:55 AM Re: Replacement for Dexron IIE [Re: anguscls]
eljefino Offline
Loc: ME
Yes you can use Dex VI. You can also use generic dex 3 "appropriate for". The PS system is less hard on fluid than the insides of an auto tranny so even generic stuff will do.
#2301391 - 06/29/11 11:12 AM Re: Replacement for Dexron IIE [Re: anguscls]
WishIhadatruck Offline
Loc: Grand Rapids, MI
If you just want something inexpensive that works I'd probably just use a Dex/Merc fluid if I were you. Dex VI would probably be better. I'm pretty sure Redline PSF is approved (by Redline) for use in vehicles calling for Dex fluids as well.
Quote:
RED LINE POWER STEERING FLUID satisfies the service fill requirements of most auto manufacturers and can be used where the manufacturer calls for any automatic transmission fluid such as DexronŽ, Dexron II-DŽ, II-EŽ, or Dexron IIIŽ, Ford Type-F, Mercon, or M2C138-CJ such as required by Ford, AMC, Toyota, Nissan, Lexus, Infiniti, Jaguar, VW, Mercedes-Benz, BMW, SAAB, Subaru, Volvo, Porsche, Mitsubishi, Mazda, and many others.
This fluid also satisfies power steering units requiring GM PN 1050017 or 1052884 (Spec Number 9985010), Chrysler Spec Number 5931, and Ford Spec Number M2C33-F. It also satisfies the hydraulic specifications of Denison HF-O, Vickers vane pumps, and Sundstrand piston pumps.
1996 Buick Roadmaster Wagon
2014 Cruze Eco Manual
2003 2500 Suburban, 8.1L
#2301429 - 06/29/11 11:44 AM Re: Replacement for Dexron IIE [Re: anguscls]
JHZR2 Offline
Loc: New Jersey
I've always had best experience using M1 ATF, makes for better cold weather performance.
#2301454 - 06/29/11 12:07 PM Re: Replacement for Dexron IIE [Re: anguscls]
ET16 Offline
Loc: MD
Merc V would be okay, too.
#2301653 - 06/29/11 03:57 PM Re: Replacement for Dexron IIE [Re: anguscls]
Ursae_Majoris Offline
Loc: South
I use M1 Multivehicle ATF (DexIII/MercV) in my Axiom. Turkey-basted a quart 2 summers ago. Steering is much easier/lighter in winter.
2011 Chrysler T&C, Dealer bulk fill/, OEM filter
2002 Isuzu Axiom, PureOne, 5w-30 G-Oil
#2301928 - 06/29/11 08:47 PM Re: Replacement for Dexron IIE [Re: anguscls]
[RT] ProjUltraZ Offline
Loc: Honolulu, HI
i'd use MaxLife PS fluid
#2302212 - 06/30/11 06:55 AM Re: Replacement for Dexron IIE [Re: anguscls]
ahoier Offline
Loc: Cocoa, FL
I've heard most PS fluid is simply light naptha/petroleum...
So I wouldn't worry too much about the fluid specifics.....I'd just use the PS fluid as the dealer specified....how much are you low? Even Marvel Mystery Oil can be used for light "top offs" of the Power Steering, no more than 16 oz. though...
#2302235 - 06/30/11 07:20 AM Re: Replacement for Dexron IIE [Re: anguscls]
deeter16317 Offline
Loc: SE, PA
Some of the later Dodge transfercases call for Dexron II, and Dexron III works just fine. I want to say that on the older bottles of Dexron III, they stated it would work in Dexron II applications?
2004.5 Dodge 2500 Cummins
#2302269 - 06/30/11 07:57 AM Re: Replacement for Dexron IIE [Re: anguscls]
Eddie Offline
Loc: Florida, Cape Coral
I to would go for Dex 3 as a better choice then Dex IV for this applicatin.
CX5 Touring 2.5L :-)
#2303955 - 07/02/11 08:41 AM Re: Replacement for Dexron IIE [Re: anguscls]
artificialist Offline
Loc: Florida
DexIII was made with replacement of DexIIE in mind. That will work fine for you. DexVI is intended to replace both of them.
Buy a synthetic ATF that meets DexIII or DexVI, and you will get more life out of your PS system and fluid, and possibly reduced steering effort.
2010 Lancer Ralliart Sportback
#2304733 - 07/03/11 07:40 AM Re: Replacement for Dexron IIE [Re: anguscls]
Ramblin Fever Offline
Loc: Timberline
I own an Isuzu rodeo too; use any dex 3 or dex 6, works just fine.
Do NOT use regular pwer steering fluid
