SAE 16. Set at a minimum of 2.3 mPa⋅s at 150°C
by wemay
14 minutes 34 seconds ago
1992 Surburban Big Block - M1 10W-30 - 5 year OCI
by bigt61
15 minutes 53 seconds ago
2007 Civic Wiper Blade Contact Fix
by 4thstpositively
33 minutes 45 seconds ago
Got me a new Stihl FS 56 trimmer today
by daddi
Today at 01:02 PM
Truck cap lights.
by wolfehunter
Today at 12:12 PM
filters and oem specs
by mobilaltima
Today at 11:50 AM
H11 bulb options
by asiancivicmaniac
Today at 11:47 AM
Engine oil accidently added into transmission
by Mazatrol
Today at 09:51 AM
Oil for 1996 Mazda B4000 pickup
by schuylkill
Today at 09:16 AM
Shell gas $80 rewards cars for $52 Deal ends 9-1
by gojoneeded
Today at 09:12 AM
Cleaning a carpet stain....Help!
by mjk
Today at 07:39 AM
Windshield: can it be repaired?
by supton
Today at 07:12 AM
pperras01, Grabberblu, Dave_PPE, davebe, Logos
58964 Registered Users
90 registered (86cutlass307, 4thstpositively, 4WD, 1foxracing, 09_GXP, 10 invisible), 1726 Guests and 8 Spiders online.
58964 Members
66 Forums
253775 Topics
#2300989 - 06/28/11 10:20 PM 97 chevy s10 manual fluid
mikebrown2008 Offline
Loc: texas
i want to change the manual transmission fluid in my 97 s10. Its the 2.2 5 speed. Anyone know what kind of fluid it takes?Also wouldnt hurt to change the rearend fluid. I guess that 80w90 would work there wouldnt it?
Edited by mikebrown2008 (06/28/11 10:20 PM)
#2301006 - 06/28/11 10:43 PM Re: 97 chevy s10 manual fluid [Re: mikebrown2008]
oilboy123 Offline
Loc: Everett, Washington
1997 CHEVROLET TRUCKS S10 PICKUP 2.2L 4-cyl Engine Code [4]
LUBRICANTS & FLUIDS:
Manual Transmission,NV1500......GLS [2]
Synthetic Synchromesh Transmission Fluid (5W-30) (MTFQT)
Manual Transmission,NV3500......GLS [3]
Automatic Transmission,4L60-E......AF6 [4]
Synthetic Multi-Vehicle Automatic Transmission Fluid (ATFQT)
Low Viscosity Synthetic ATF (ATLQT)
Torque-Drive Synthetic Transmission Fluid (ATD1G)
Differential, Rear......GL-5
All TEMPS......80W-90 [5] [6]
SEVERE GEAR 75W-90 Synthetic EP Lubricant (SVGQT)
75W-90 Synthetic Long Life Gear Lube (FGRQT)
SEVERE GEAR 75W-110 Synthetic EP Lubricant (SVTQT)
SAE 80W-90 Synthetic Gear Lube (AGLQT)
Differential, Front......GL-5
All TEMPS......80W-90 [5] [7]
Transfer Case,W/ Manual TRC......GLS [8]
Transfer Case,W/ NV Elec......SLF [9]
No AMSOIL Product Recommendation
Fluids
Power Steering Fluid......PS
Power Steering Fluid (PSFCN)
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN)
Clutch Fluid......HB
[1] SAE 5W-30 is preferred.
[2] GM part no. 12377916 or equivalent
[3] GM part no. 12345349 or equivalent.
[4] This specification has been updated from Dexron II or III to
Dexron VI per a Technical Service Bulletin from the
manufacturer.
[5] Manufacturer recommends GM part no. 1052271 or equivalent
[6] Do not add limited slip additive.
[7] 1988-99 models
Do not use synthetic lubricant in axles using RTV sealant.
Synthetic lubricant will chemically attack RTV sealant.
American Axle has only approved the use of Synthetic
Lubricant 75W-90 GM part no. 12378261, as follows:
a. All 8.6 inch rear axles are compatible.
b. All 9.5 inch rear axles built before mid-February 1998
(RTV sealant used to seal cover pan) are not compatible
c. All 9.5 inch rear axles built after mid-February 1998
(equipped with cover pan & gasket) are compatible.
d. All 10.5 inch rear axles built prior to March 3, 1999 are
compatible if axle shafthub RTV sealer is replaced with GM
gasket part no. 327739.
[8] GM recommends Part No. 88861800 (Canada 88861801)
or equivalent for manual transmission, transfer
case applications.
[9] GM part no. 12378508 (U.S.), 10953626 (CAN)
Edited by oilboy123 (06/28/11 10:46 PM)
“Loyalty to country ALWAYS. Loyalty to government, when it deserves it.”
― Mark Twain
#2301044 - 06/28/11 11:30 PM Re: 97 chevy s10 manual fluid [Re: mikebrown2008]
Loc: texas
Is this something that is available at a parts store or has to be ordered. Just curious would mobil 1 5w30 synthetic work?
#2301048 - 06/28/11 11:36 PM Re: 97 chevy s10 manual fluid [Re: mikebrown2008]
mechtech2 Offline
Loc: Chicago Area
Also Amsoil or Redline in their respective synchromesh viscosities. Both are full synthetic and excellent.
#2301082 - 06/29/11 01:21 AM Re: 97 chevy s10 manual fluid [Re: mikebrown2008]
oilboy123 Offline
I don't know what oil is equal to the Amsoil stuff. Maybe Pablo or someone does. You will probably be able to find something like it at a store. But Maybe not in a synthetic variety.
Don't know for sure though.
― Mark Twain
