5w-40 synthetic vs 15w-40 synthetic
by mbacfp
06/27/16 01:27 PM
SCAM!Anyone renting their water heater tank?
by KrisZ
06/27/16 01:16 PM
Donaldson PowerCore as HEPA filter?
by PeterPolyol
06/27/16 01:13 PM
Clearance oversized filters for M20x1.5 w/bypass
by PeterPolyol
06/27/16 01:05 PM
Prestone vs. DEX-COOL Concentrate
by Ramblejam
06/27/16 12:54 PM
Severe service and OEM oil Filters
by Tech819
06/27/16 12:46 PM
ContiTech Pro Series timing belt kit 2009 Galant
by Ruturaj
06/27/16 12:25 PM
Bogus Coolant Test! - did Pat Goss make a mistake?
by i_hate_autofraud
06/27/16 11:57 AM
The "zero posters"
by OVERKILL
06/27/16 11:57 AM
Removing "Holder?" From Dash
by coopns
06/27/16 11:53 AM
Concrete Cleaners
by dkryan
06/27/16 11:45 AM
What makes CVTF?
by horse123
06/27/16 10:40 AM
karpouzi, Tapan, shindery, Josh_Westwood, Brogan
58283 Registered Users
90 registered (69GTX, 4WD, 901Memphis, Al, AlaskaMike, 360kid, 7 invisible), 2134 Guests and 11 Spiders online.
58283 Members
66 Forums
250883 Topics
Page 1 of 2 1 2 >
#2300700 - 06/28/11 05:34 PM Best bypass filter for an air-cooled VW?
BSouza Offline
Loc: Arizona
Hello, my name is Brian.
I have a newly built performance air-cooled VW engine. It is only equipped with the factory screen at the moment. I like the idea of adding a bypass filter, and I've heard it was a VW factory option, as well as a standard item on early Porsche engines.
I plan on doing oil and filter changes every 3000 miles, regardless of the visual condition of the oil.
That stated, what do you think the best product for my VW would be? I'm looking at the Frantz, and I like the idea of the Amsoil spin-on filter, but at $40.00 its a lot of money every oil change. Yeah, I know they say you don't have to change it every time, but I need convincing.
Thanks for the help!
Brian
Edited by BSouza (06/28/11 05:35 PM)
#2300715 - 06/28/11 05:47 PM Re: Best bypass filter for an air-cooled VW? [Re: BSouza]
chubbs1 Offline
Loc: Merritt Island FL, USA
The convincing you need is if you are doing 3K OCI's you DON'T need a bypass filter.
'12 Charger SXT
QSUD 5w30 OEM filter
'12 Charger SXT
Edge FST EP 5w30 OEM (Mine;)
'11 Hyundai Sonata GLS
QSUD 5w20 OEM Filter
#2300716 - 06/28/11 05:48 PM Re: Best bypass filter for an air-cooled VW? [Re: BSouza]
EricF Offline
Loc: SF Bay Area
why not just plumb in a remote oil filter? There's room for the standard FL-1A sized filter.
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
#2300719 - 06/28/11 05:49 PM Re: Best bypass filter for an air-cooled VW? [Re: chubbs1]
BSouza Offline
Loc: Arizona
Does OCI stand for Oil Change Interval? I'm new here. I wouldn't be adding the filter because I HAVE to, but because I WANT to.
#2300726 - 06/28/11 05:52 PM Re: Best bypass filter for an air-cooled VW? [Re: EricF]
BSouza Offline
Loc: Arizona
I like the idea behind super cleaning the oil with a bypass. I am already aware of a multitude of options if I want to run a conventional full-flow filter/oil pump combination.
#2300730 - 06/28/11 05:55 PM Re: Best bypass filter for an air-cooled VW? [Re: BSouza]
Steve S Offline
Loc: East of IGO
You do not change the Amsoil filter at every oil change, by design it lasts a lots of miles. What makes you think the amsoil filter doesn't stand up to the long intervals. I am wondering? Go with the Frantz if you want to change filters often. Another choice would be to get a wix or Baldwin bypass filter setup. which is what engines used before full fluw filters were in use . The mounts and hoses and spin on element can be purchased at a decent car parts store ,Napa should have them I worked on forklifts for 23.5 years and all the old ones had then installed . There are some posts of people installing them on their cars to try to get a low cost bypass filter but the elements usually filter the same as a full flow filter .
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#2300736 - 06/28/11 06:01 PM Re: Best bypass filter for an air-cooled VW? [Re: Steve S]
BSouza Offline
Loc: Arizona
>>I'm just anal that way. I can't see inside the filter, and all my life I've been told the dirtiest oil is inside the filter<<
>>Thanks for the help! maybe the resident Amsoil guy will chime in also!<<
#2300742 - 06/28/11 06:04 PM Re: Best bypass filter for an air-cooled VW? [Re: BSouza]
Steve S Offline
Loc: East of IGO
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1347178#Post1347178 This post will give you an idea for the wix/Baldwin filters I mentioned.
#2300800 - 06/28/11 06:57 PM Re: Best bypass filter for an air-cooled VW? [Re: BSouza]
berniedd Offline
Loc: A Warm place to live in
A few years ago, I saw an article in Hot VWs magazine where a bypass oil system was described. It involved cutting a small bit of the fan housing tin in front of the distributor and installing an oil plumbing adaptor that would accept an oil filter. Ask around VW parts suppliers, they would know where to source out a kit for you. Better yet , ask in the forums of Hot VWs or those catering to VW enthusiasts such as thesamba.com.
#2300889 - 06/28/11 08:25 PM Re: Best bypass filter for an air-cooled VW? [Re: berniedd]
BSouza Offline
Loc: Arizona
I've got a 2 page query going on at the VW tech forum on the web, Shoptalkforums. I've also done a search on the Samba and others.
Thanks, though, I appreciate the ideas.
#2301346 - 06/29/11 10:30 AM Re: Best bypass filter for an air-cooled VW? [Re: BSouza]
AlaskaMike Online   content
Loc: Alaska
If it were me it'd be the Frantz, hands down. And the idea that you'd need to change the element frequently is a little silly--it's not like you're putting it on a diesel engine where it would load up with soot.
#2375964 - 09/13/11 10:55 AM Re: Best bypass filter for an air-cooled VW? [Re: BSouza]
VWguy Offline
Loc: Los Angeles, Ca
BSousa, welcome to bitog and vw's. If. You have the time, check out the Gene Berg Ent's web site. The late Gene Berg spent an alful lot of time researching things before he put it to print. Case in point, he has some sound info regarding the use of full flow filters for the hot rodded vw engine. Some of his info is considered outdated (compression ratios for example) but he was pretty conservative with daily driven vw's but had some of the fastest cars running his components (son Gary's 12 second street in the mid '70's). And regarding the full flow they have instructions on how to install without tearing the engine apart.
Hope this helps, Bill.
#2384456 - 09/22/11 12:56 AM Re: Best bypass filter for an air-cooled VW? [Re: VWguy]
VWguy Offline
Hi again Brian. Regarding the previous poster the method of taping into the oil cooler adaptor never hit a sweet spot with anyone out there. You already have your by-pass filter set-up and unless there are issues, leave it be. The addition of a full flow filter raises a couple of issues. The issue of installing a filter/pump arrangement is a clean install but with your merged exhaust, clearance is the issue. Also most are of low quality manufacture. But one is made by VW of Mexico and should be good if it clears your exhaust. John Connelly at Air Cooled dot net I think carries them. You would just have to consider a short filter. The other issue is the oil pumps with the in-and-out fitting on the cover which is too restricted with its small holes and tight bends.
In my opinion, the ultimate, if you really feel the need for a full flow filter, would be to properly full flow the case, and get a full flow oil pump cover, plug the pump outlet, and run hoses to a small OBERG filter mounted somewhere out of sight. This is because it looks as if cosmetics are a concern with your rod.
#2384459 - 09/22/11 01:05 AM Re: Best bypass filter for an air-cooled VW? [Re: BSouza]
VWguy Offline
And want to ask, what oil and viscosity are you using? Different seasonal viscosity changes? If you are using an aftermarket cam/lifters hope your oil choice satisfies this.
With some exceptions, possibly a rule of thumb is 1 qt per 1000 miles for OCI.
Bill
#2399561 - 10/07/11 09:42 PM Re: Best bypass filter for an air-cooled VW? [Re: VWguy]
BSouza Offline
Loc: Arizona
I'm using Mobil 1 5W30 and a little STP for added zinc. Hopefully enough zinc to keep my Engle 120 camshaft bumpy.
Page 1 of 2 1 2 >
