Fram Ultra Bypass Valve Spring Life
by Digital2k2
05/29/16 11:32 AM
CARQUEST Filters are now made by Purolator (pics)
by sir1900
05/29/16 11:03 AM
Small 4 Cycle Engines, longevity tips
by henni
05/29/16 10:05 AM
Car won't star after new serpentine belt
by AlaninPA
05/29/16 09:06 AM
Was this sold by Costco?
by Vikas
05/29/16 09:03 AM
Gas or lithium-ion powered string trimmer?
by skyactiv
05/29/16 08:41 AM
Tire pressure question
by Tlhfirelion
05/29/16 07:18 AM
So I did an oil change but didn't change the filte
by Tlhfirelion
05/29/16 07:05 AM
Mixing Mobil 1 0w20 with 5w30
by doublebase
05/29/16 06:49 AM
Max Life @ Menards
by scusemez28
05/29/16 06:24 AM
Cut Super Tech ST3980 2500miles
by jhellwig
05/29/16 12:25 AM
Smoked my first brisket today
by MrHorspwer
05/28/16 11:00 PM
Moutainman31282, AlaninPA, z0bug33, smitty31, jimshep
58013 Registered Users
75 registered (2015_PSD, aquariuscsm, AirgunSavant, AlaninPA, Al, AandPDan, 7 invisible), 1758 Guests and 121 Spiders online.
58013 Members
66 Forums
249555 Topics
#2299361 - 06/27/11 12:39 PM Low coolant/antifreeze in F150?
renegade_987 Offline
Loc: Ankeny, IA
So my coolant in my F150 is quite low, well below the cold fill range. Is there a reason that it would go down so much? Also, is Prestone 50/50 Antifreeze/Coolant a good one to add? Thanks
2004 F150 186K Valvoline WB/Motorcraft FL-820S
2005 Ford 500 Limited 128K Motorcraft/Motorcraft
2011 Baja MB200 Royal Purple 10w30
#2299387 - 06/27/11 12:59 PM Re: Low coolant/antifreeze in F150? [Re: renegade_987]
440Magnum Offline
Loc: Texas
No idea if you have a problem without also knowing HOW LONG it took to lose that amount of coolant. If its been months or years, then its perfectly normal. If it's been since last week... that's a problem.
I wouldn't put Prestone 50/50 "all makes/all models" in my worst enemy's car, let alone mine. Use the original type coolant Ford recommends (probably G-05).
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 Cherokee 4.0, '11 Grand Cherokee 3.6
#2299423 - 06/27/11 01:23 PM Re: Low coolant/antifreeze in F150? [Re: renegade_987]
Loc: Ankeny, IA
It has been at least 6 months, so it is probably OK. It has never been changed out, either. Are you supposed to change your coolant/antifreeze?
#2299446 - 06/27/11 01:35 PM Re: Low coolant/antifreeze in F150? [Re: renegade_987]
bdcardinal Offline
Loc: Santa Barbara, CA
You are supposed to change it, the service interval will be in the owners manual.
That Prestone 50/50 is a DexClone based coolant, and factory fill was G-05. I wouldn't mix them personally.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
#2302259 - 06/30/11 07:47 AM Re: Low coolant/antifreeze in F150? [Re: renegade_987]
The_Eric Online   content
Loc: Iowa
Agreed with the above. Go to NAPA or Arnold's and pick up a gallon of Zerex GO5. That is the exact same formula that FomMoCo uses.
FWIW, your coolant should likely be changed on a 5year 100k (or 150k) mile schedule. Also just because you might not have reached the mileage, you should changed it due to age. Drain the radiator, and pull the block plugs (if equipped) and refill with GO5 at 50% mix.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
#2305251 - 07/03/11 06:21 PM Re: Low coolant/antifreeze in F150? [Re: renegade_987]
wiswind Offline
Loc: Wisconsin
I would also recommend the G-05.
Around here, CarQuest sells the Zerex G-05.
It is usually up to the individual store as to what products they carry, so 1 may have it.....and another not have it.
I think that initial change interval is 5 years......but read your owner's manual, or look it up online.
G-05 is a bit more expensive than some other coolants out there, but it is worth it.....good stuff.
Pay attention to the indication on the jug......if it is concentrate (which you would mix 50/50 with distilled water) or premix (which you would NOT add anything to).
I have had auto part store clerks try to sell me something else....telling me that is IS G-05......if it does NOT say that it IS G-05 on the label.....it is NOT.
If you have an issue locating it.....sometimes the Motorcraft brand at your local FORD dealership will be around the same price...maybe even cheaper...depending upon what the dealership is charging.
If wondering if you have a leak into the oil, you can send in a sample of your used oil to have it tested, and they will let you know.
I have used blackstone labs....visit their website for instructions and a free sample / mailing kit.
