FYI, At&t Implements data caps today
by badtlc
29 minutes 46 seconds ago
Top Tier Gasoline = only 5 miles more per tank?
by Hyde244
57 minutes 25 seconds ago
Thoughts on buying a car with a rebuilt title?
by 7055
Today at 09:54 AM
bought used honda prelude sh, which motor oil
by h22rider
Today at 09:38 AM
REVIVE a 3 YEAR stored/maltreated battery?
by SumpChump
Today at 09:35 AM
5.0 Mustang & Napa Synthetic
by Camprunner
Today at 09:24 AM
Castrol Magnatec 5w-20 Observation
by AirgunSavant
Today at 09:11 AM
What trans fluid for a modded 700R4?
by redhat
Today at 09:10 AM
Streaks left after using leather seat wipes.
by jigen
Today at 07:57 AM
Poulan Pro 5020AV carburetor adjustment
by jstutz
Today at 07:57 AM
Winchester firearms - 15% rebate until May 30
by mjk
Today at 07:29 AM
Redskins name offensive
by grampi
Today at 07:20 AM
WeekendWarrior, emily, lex73, showstopr30, any_user
57966 Registered Users
96 registered (AandPDan, 2002 Maxima SE, 2015_PSD, Alfred_B, A_Harman, Andrei, 11 invisible), 1893 Guests and 141 Spiders online.
57966 Members
66 Forums
249342 Topics
Page 1 of 2 1 2 >
#2295422 - 06/22/11 11:41 PM CLOGGED transmission filter
RegDunlop Offline
Loc: NYC NY USA
Has anybody ever seen a clogged transmission filter?
It is my understanding that the tran filter only prevents LARGE materials from getting into the transmission, so wondering if anybody has seen a clogged at filter?
#2295423 - 06/22/11 11:46 PM Re: CLOGGED transmission filter [Re: RegDunlop]
Scorch Offline
Loc: Charlevoix, MI
I've only ever seen dirty transmission filters, typically the media has started out yellow and turned the brown/red tint of ATF. Completely disassembled the filter from my stratus after 110,000 mile run and only found small specs, almost everything that could possibly cause any kind of clog was on the magnet.
2012 Ford Fusion Sport 3.5L V6 41,600 Miles
Oil: 5.5Qts Pennzoil Platinum 5w-20 w/ Motorcraft Filter
#2295425 - 06/22/11 11:50 PM Re: CLOGGED transmission filter [Re: RegDunlop]
ahoier Offline
Loc: Cocoa, FL
Don't think it would be possible, being that the magnet simply sits at the bottom of the pan. I don't know exactly how the atf gets "filtered" but for example, in an engine, ALL oil within the engine must pass through the filter, that may not be the case with the ATF?
Granted, it's still something you want to "maintain" on a schedule...but I can't see it completely clogging. If anything it will just keep making a bigger, taller, and wider "pile" of shavings.....
But could depend how deep the pan is, where the filter is located, etc....too probably.
#2295428 - 06/22/11 11:57 PM Re: CLOGGED transmission filter [Re: RegDunlop]
dwendt44 Offline
Loc: Central Wisconsin
I've seen one, but that was over 30 years ago.
Powerglide trans with over 100,000 on it.
Every once in a while the trans. would lock up and car not move.
Changed the fluid and filter and it never happened again.
GM uses an actual filter media. Some just have a screen that catches the big chunks.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
#2295434 - 06/23/11 12:05 AM Re: CLOGGED transmission filter [Re: RegDunlop]
SEMI_287 Offline
Loc: Up State NY
It will never happen unless water gets in the tranny. The glue holding the clutch material together is water soluble. The 45RFE and 545RFE have a normal flat filter plus a spin on cooler return line filter. It's an actual filter sans the ADBV.
2007 Chrysler 300C- M1 5w20 Wix filter
2014 Dodge Avenger- Gulftec 0w20 Wix filter
2008 Mitsubishi Galant- PU SM 10w30 Wix filter
#2295442 - 06/23/11 12:59 AM Re: CLOGGED transmission filter [Re: SEMI_287]
SwampDweller Offline
Loc: Gonzales, La.
Seen MANY clogged trans filters. Did trans work at dealers for a long time. If you truly have a clogged trans filter, a "service" will do you no good. By the time there is enough clutch material/metal to CLOG a filter, the unit is toast.
For years we had torque converter lock up clutches that would fail, flooding the unit with material and metal. Result was clogged filter, low fluid pressure to the other clutches and bands, resulting in more clutch material.
From the Swamp, Lenny
16 F150 XLT 5.0 Super Crew
16 Ford Fusion SE 1.5 Turbo
14 Hustler ZTR 54 Super Duty 23/Kawasaki
#2295518 - 06/23/11 06:39 AM Re: CLOGGED transmission filter [Re: RegDunlop]
Jakegday Offline
Loc: fremont nebraska
the tranny filter on my fairmont is, i believe, completely useless. i bought the new one, and saw its nothing more then a piece of window screen mounted in a little metal housing. the "media" part was literally as wide open as a window screen. i took the old one out and it looked as good as new.
2001 Pontiac Grand Prix GT
1981 Ford Fairmont
1978 Ford Ranchero GT
#2295531 - 06/23/11 07:05 AM Re: CLOGGED transmission filter [Re: Jakegday]
Radman Offline
Loc: Detroit, Michigan
If there is enough clutch material to clog a filter a rebuild is in order. It takes a whole lot to clog a tranny filter and I have only seen that in complete fails.
2006 Maxima 120K M1-105, M1 0W40
2006 Sentra 90K M1-105, GTX 5W30
2010 Altima 20K M1-105, GTX 5W30
2013 Yamaha FZ1 1K PL1410, SRT5 15W40
#2295541 - 06/23/11 07:19 AM Re: CLOGGED transmission filter [Re: RegDunlop]
Jim Allen Offline
Loc: NW Ohio
Yeah, the only time you see a clogged filter is after a major failure. But the thing is, you don't know what the "chicken" was. If, in the course of normal operation, the filter partly clogs and restricts flow, the trans could begin to slip. Just a little at first but it would then start dropping more debris, which would then get caught in the filter, further restricting flow and... well you see where I'm going here. It would be difficult to discover the root cause.
The thing is.... according to the decades of work Eleftherakis and Khalil did studying AT filtration (which you can get at the SAE store)... the average range of sizes for "normal" wear debris in an automatic is 5-15u. That stuff will pass right thru even the best 60-80u pan filters that are out there now, never mind the 100-150-200u screens of the old days.
I think it might be possible to clog a 60u filter with oxidative byproducts from excessive heat but I suspect the trans would fail in some other way before teh filter would cause it to fail.
Excessive amount of that size contamination will beget more and more debris, more and more wear and it will eventually kill the trans. By the time the big stuff comes along to clog the filter, the trans is already severely enough damaged that its on borrowed time anyway.
So, and y'all can check my logic here because this thought just occurred to me, it seems that it really isn't possible to plug an in-pan trans filter in normal circumstances, without some other major failure taking place first. I can invent some scenarios where it might be remotely possible, but the vast majority of the time, I don't think it would.
From my reading, and a coupla great conversations with Abe Khalil, it seems prudent to change the filter and clean the magnet in the pan short after break-in is achieved, because the trans generates 75 percent of it's lifetime of normal wear materials within the first 5K miles. That comes from break in as well as the contaminants that're built in during manufacturing. After that, it would seem safe to me the let the pan go... at least over a couple of OCIs, if not the remainder of the transmission's lifetime. Without knowing for sure, I would probably change it just for observation and learning reasons but my semi-WAG now would be that it basically can't clog without other things happening first.
Jim Allen
Keepin' the Good Old Days of Four Wheeling Alive
#2295544 - 06/23/11 07:26 AM Re: CLOGGED transmission filter [Re: RegDunlop]
demarpaint Offline
Loc: NY
My father had given me a 66 Ford Falcon which had over 100K on it, and he never serviced the transmission. One day I went out with it, shifted it into D and all it did was rev. I dropped the trans pan and it was covered in junk and some metal filings. I replaced it and it was fine. I started maintaining cars for my father from that point on.
God Bless Our Troops
#2295552 - 06/23/11 07:46 AM Re: CLOGGED transmission filter [Re: Jim Allen]
eljefino Offline
Loc: ME
This. I picked up a 91 cutlass ciera (4t60, 3300) for my BIL. The vacuum modulator may have been malfunctioning, not giving enough pressure to the clutch packs under load, and the higher gears slipped. Anyway I dropped the pan and found an above average collection of gray dust. Stuck an adjustable modulator on there (red stripe, ten bucks!), changed the filter and fluid, and everything came back to life!
This was a shotgun approach and I agree on the voodoo of knowing what went out first, or even if my higher line pressure (I didn't pressure gauge test any ports or anything) is a band aid for a tired box.
#2295582 - 06/23/11 08:27 AM Re: CLOGGED transmission filter [Re: RegDunlop]
Trav Offline
Loc: MA, Mittelfranken.de
The only one i ever saw totally clogged was an 1970 Chevy PU TH350.
The unit didn't work in any gear, before swapping it i changed the filter and it worked like new again.
The unit continued to work fine another 10 yrs when the truck was finally scrapped.
#2295639 - 06/23/11 09:54 AM Re: CLOGGED transmission filter [Re: RegDunlop]
RegDunlop Offline
Loc: NYC NY USA
Thanks for all the great replies
Reason I asked was I have been extracting and replacing the ATF on a GM 4t60e over the course of 3 weeks. I have put in about 8 quarts of new after extracting the old a few. Quarts at a time. This car has 106k. I have no idea if the at was ever serviced. It was owned by an older woman to about 70k. Then my family member took it. I know my family member never serviced the at I do not know what the older woman did but I think she was a bring to dealer on schedule type.
There are no problems with this AT. I was being proactive in changing the fluid. The first couple quarts I took out where very dark-- could not see through it at all after in disposal container. It did not smell burnt in any way just appeared dirty. I didn't expect that as when I would check the dipstick before changing any of the fluid it would still have a pinkish brown color on the cloth.
Anyway I have a new filter ready to go but I'm wondering if I can just drive it the way it is now without changing the filter/ dropping/cleaning the pan. Or. If I have to get a new filter in there very soon.
Since changing ONLY The fluid I haven't noticed any changes at all..... Drives nice and smooth the way a " rolling couch " old man car should
Thanks
#2295663 - 06/23/11 10:21 AM Re: CLOGGED transmission filter [Re: RegDunlop]
Steve S Offline
Loc: East of IGO
When in doubt change it out.
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#2296075 - 06/23/11 06:44 PM Re: CLOGGED transmission filter [Re: RegDunlop]
NYSteve Offline
Loc: Killadelphia
Knew a girl in college who had a tempo or some other POS and she said that after driving for a while the car wouldn't go when she hit the gas. She would turn the car off and let it sit 10 min. She said it got diagnosis as the tranny. Figure the filter was getting clogged.
Page 1 of 2 1 2 >
