Highway conditions in the Midwest
by grampi
07/01/16 08:22 AM
Indian head shellac or something?
by JHZR2
07/01/16 08:15 AM
Need Help! Tombstone
by AirgunSavant
07/01/16 07:38 AM
Truck bedliner - pros and cons and option
by ryan2022
07/01/16 07:33 AM
Delo 400 SD 15w30 From Amazon
by AirgunSavant
07/01/16 07:27 AM
GM LS 6.0 Suggestion
by akcooper9
07/01/16 06:58 AM
Penrite 5W-30 Full Synthetic
by KL31
07/01/16 06:08 AM
PP HM at Walmart
by dlundblad
07/01/16 04:55 AM
74/76mm x 15 Flutes
by Merkava_4
07/01/16 04:33 AM
Autozone - Pennzoil with the PP - Rebates
by Kwuality
07/01/16 03:29 AM
Old Toyota
by artbuc
07/01/16 03:18 AM
Shell Helix Ultra 5W-20 & 0W-20 in Australia
by SR5
07/01/16 03:03 AM
EdandSherry, Shalmaneser, Shipmate29, garytcosta, lifteddiesel90
58332 Registered Users
86 registered (ac_tc, ARCOgraphite, badtlc, AirgunSavant, b1amgm47, AEHaas, 6 invisible), 1582 Guests and 12 Spiders online.
58332 Members
66 Forums
251084 Topics
#2289561 - 06/16/11 11:31 AM what kind of oil to use 10w-30, 10w-40, 5w-40
max45 Offline
Loc: los angeles
hi. i have honda civic lx year 2000 with 233000 miles write now on odometer.i'am using 10w-30 hm mobil 1 synthethic for about 30000 miles, i switch from regular to synthetic.i'am not shure should i stay with 10w-30 or should i switch to 10w-40 or 5w-40, because is thicker than 10w-30 with this mileage.i did a head job on motor at 220000 miles, it was heating, and now everything is fine. i was thinking should i come back to dino oil, because i can't see much difference between synthetic and dino on my car, it's get dirty around 4000 miles synthetic oil. i don't know why some companies say for e.g mobil 1 synthetic extended performance change around 15000 miles, that's balooney for me, i bought that oil ,but before i pour inside engine i did motor flush+ i add 3 liters of some off brand synthetic oil to clean the engine and than i add that oil , and get dirty around 4000-5000 miles. i also try castrol edge full synthetic same thing they last about same 4-5k miles. my car it doesn't burn oil, only if if black completly than burning. if you can give me some advice, thanks.........
#2289564 - 06/16/11 11:35 AM Re: what kind of oil to use 10w-30, 10w-40, 5w-40 [Re: max45]
addyguy Offline
Loc: Canada
10W-30 conventional will be fine in that engine in LA.
Just buy what is on sale, and change it every 4-5k miles.
Seriously, don't over-think oil in Honda Civics - they are genuinely very, very easy on oil.
2010 Kia Soul 2U - 2.0L I-4, auto, 86k miles.
QSGB 5W-20, NAPA select filter(?)
#2289565 - 06/16/11 11:39 AM Re: what kind of oil to use 10w-30, 10w-40, 5w-40 [Re: max45]
mechtech2 Offline
Loc: Chicago Area
Unless it is VERY dirty, don't be too concerned with darkness of the oil.
For 4-5K, I'd use dino. Pennzoil is good, as are others.
Consider a 5-30, it is thiner when cold/cool than 10-30 [an advantage].
#2289583 - 06/16/11 11:51 AM Re: what kind of oil to use 10w-30, 10w-40, 5w-40 [Re: max45]
ahoier Offline
Loc: Cocoa, FL
Yea you can't really trust the darkness of the oil as how dirty it is, some oils are just "darker" than others. PYB for example, is near translucent/transparent on my dipstick lol.....kind of ticks me off, so hard to see where the level is at wink
What's your manual say? I'm guessing for "Normal" service, it's got a schedule of OCI every 7-8k with either an API SL or SM rated oil.....provided you aren't racing the engine, driving through death valley every day (dusty, muddy areas, etc....), you should be OK running any oil 7-8k in that engine.
And [censored], if you wanna get daring, get an used oil analysis at 7k using your "trusted" oil, and if the report comes back, see how the oil held up. Also serves to make sure you aren't losing minute coolant/water or fuel in your oil too......as that could degrade the oil as well, particularly if you're looking at extended drains.
#2289587 - 06/16/11 11:54 AM Re: what kind of oil to use 10w-30, 10w-40, 5w-40 [Re: mechtech2]
Oregoonian Offline
Loc: Bend, Oregon
+1....agree
5w30 would also be my choice for a Civic. You might consider a blended oil.....such as Motorcraft 5w30 (with a 5000 OCI). It has a good reputation here on BITOG....and priced competitively with quality conventionals.
The Purolator Classic filter should work perfectly with the above.
__________________________________________
03' Ford Focus (2.3L Duratec PZEV) / 98K
PP 5w20 / Purolator PureOne / OCI: 7500 +/-
03' Ford Focus SE(2.3L Duratec PZEV)/ 135K +
QSUD 0w20 / Fram 'Ultra'/ OCI: 7500 +/-
ATF: Mercon V w/Lubegard Red
