Are Cooper CS5 LRR?
by Stewart Fan
08/31/16 03:14 PM
Camry battery tested bad.
by chiefsfan1
08/31/16 03:08 PM
Electricly conductive grease for Samsung Galaxy???
by Drew99GT
08/31/16 01:40 PM
Right Oil and OCI for my Application?
by lancerplayer
08/31/16 01:06 PM
AZ card 20% off, AAP card 13% off
by gojoneeded
08/31/16 12:44 PM
NAPA (Flowers) Gold oil filter sale 9/5 to 9/10
by BigD1
08/31/16 12:38 PM
Japanese companies aren't as good !
by HTSS_TR
08/31/16 11:41 AM
Oil Viscosity Recomendation
by T_Bortz
08/31/16 11:35 AM
Clay, Polish, Wax OR Clay, Cleaner Wax
by SavagePatch
08/31/16 11:28 AM
VAICO Oil Filters
by tnt31
08/31/16 11:18 AM
Good oil and filter for hm 5.3
by Chevy538487
08/31/16 10:14 AM
At what timdo you consider your brake fluid "wet?"
by Bster13
08/31/16 09:34 AM
JoeI, binarycache, MarkieB, albertson, Chevy538487
58973 Registered Users
93 registered (2015_PSD, 2009Edge, 2010Civic, 97f150, alarmguy, 09_GXP, 5 invisible), 1612 Guests and 11 Spiders online.
58973 Members
66 Forums
253815 Topics
Page 1 of 4 1 2 3 4 >
#2288931 - 06/15/11 05:53 PM Stihl Motomix vs Trufuel 50:1
car54 Offline
Loc: Wdbg, VA
I visited my local Stihl dealer today. I called and asked if they had Motomix, and they said they had one bottle left but had plenty of Trufuel 50:1. They also informed me they were identical products and both were made by trufuel, and I should buy trufuel because it's cheaper.
So I bought both. While I have no doubt in my mind that Motomix is produced for Stihl by Trufuel, They aren't close to being identical. Motomix is green, from the HP ultra oil. Trufuel is pink, from whatever oil they use.
Motomix was $9.95. Trufuel was $7.95.
I haven't used either yet, but I will put each one in different saws and see how it smells/smokes/runs.
#2288943 - 06/15/11 06:06 PM Re: Stihl Motomix vs Trufuel 50:1 [Re: car54]
Johnny Offline
Loc: Retired | Wausau, WI
They are defiantly different products. I use the MotoMix and my local dealer sells it for $7.99 per can.
Nice pics.
#2288953 - 06/15/11 06:17 PM Re: Stihl Motomix vs Trufuel 50:1 [Re: car54]
car54 Offline
Loc: Wdbg, VA
I need to convince my dealer they aren't the same, and to drop the price a bit!
#2288955 - 06/15/11 06:21 PM Re: Stihl Motomix vs Trufuel 50:1 [Re: car54]
Johnny Offline
I would think someone at Stihl headquarters could set your dealer straight.
#2288957 - 06/15/11 06:24 PM Re: Stihl Motomix vs Trufuel 50:1 [Re: car54]
FNFAL308 Offline
Loc: Florida, Treasure Coast
I spoke to the owner of the Shop today about Moto-mix, we should be getting some in soon..
They are definitely NOT the same product and as to the cost there is a significant diff in dealer cost/pricing as well..
That big diff in dealer cost is the reason for the diff in Retail.. I'm not saying I like it just noting the reason is all..
Edited by FNFAL308 (06/15/11 06:25 PM)
#2289040 - 06/15/11 07:55 PM Re: Stihl Motomix vs Trufuel 50:1 [Re: car54]
dakota99 Offline
Loc: indiana
I've been using TruFuel 40:1 in my ryobi trimmer with no problems yet. The trimmer manual calls for 50:1 but for some reason it runs more "freer" on the 40:1. Exhaust is clean and not oily.
I get mine for $3.95 at walmart. $7.95 is a little steep. It's also green colored.
#2289455 - 06/16/11 09:16 AM Re: Stihl Motomix vs Trufuel 50:1 [Re: dakota99]
660mag Offline
Loc: TEXAS
I worked on an fs80r yesterday that has been run on trufuel most of it's life. The engine did have good sealing numbers, but was fouling plugs by bridging the gap with little round balls of gray carbon. I found nothing else suspect about the trimmer but the red fuel.
These two fuel are both bottled by the same co.(TrueSouth in Shreveport LA), but nothing about there formulas are the same but the ratio.
#2289848 - 06/16/11 05:25 PM Re: Stihl Motomix vs Trufuel 50:1 [Re: car54]
car54 Offline
Loc: Wdbg, VA
I spent the day switching my equipment from gas to motomix. I used the entire bottle of trufuel in my Echo backpack blower, it's at least 10 years old and the 32oz bottle only filled it halfway.
My MS310 saw and HT70 pole pruner both have carb problems. I bought them both in 2003 and have seen only a few hours a year of use. I added a little bit of gumout regane to the motomix in hopes that it will clean out whatever is causing the carb problems.
I have four other Stihls, a two stroke string trimmer, a fourmix trimmer, and two 046 saws. I will need some more motomix to convert all of them.
#2289916 - 06/16/11 06:47 PM Re: Stihl Motomix vs Trufuel 50:1 [Re: car54]
boraticus Offline
Loc: Canada
I find all of this discussion about "designer" fuels to be somewhat confusing.
I have over thirty years of hands on mechanical experience and was formally educated in diesel mechanics. I own and operate numerous small engine machines (probably forty or more) from motorcycles, ATVs, snowmobiles, outboard engines, two and four stroke OPE of several types. I have always done my own work and have rebuilt numerous engines both two and four stroke. My preferred engine is two cycles and I have many of them. In all of my years of experience, I've used nothing but regular pump fuel with conventional two cycle oil. I've never had an issue with either performance or reliability using normal fuel mixed at required ratios.
So, the confusion that I'm experiencing is trying to get my head around why anyone would pay such a ridiculous price for fuel that appears to offer nothing in return for the cost.
Maybe someone can enlighten me regarding the perceived advantages of using these high priced fuels?
#2289928 - 06/16/11 07:04 PM Re: Stihl Motomix vs Trufuel 50:1 [Re: car54]
car54 Offline
Loc: Wdbg, VA
I'm only using it in equipment that sits more than it is used to prevent fuel from going bad in the carb. The leaf blower will sit for 3-4 months before I use it again in the fall. The trimmers sit all winter. ethanol is a mean substance and if paying out the rear is the only way to avoid it, so be it.
You mention rebuilding two and four stroke engines, but then state you have never had an issue with performance or reliability using conventional two stroke oil?
Ive never rebuilt an engine, period. I use boutique oils and high end fuels. Stuff lasts much longer and runs better.
#2289969 - 06/16/11 07:48 PM Re: Stihl Motomix vs Trufuel 50:1 [Re: car54]
boraticus Offline
Loc: Canada
"You mention rebuilding two and four stroke engines, but then state you have never had an issue with performance or reliability using conventional two stroke oil?"
That is correct.
You see, when a person buys old, used and sometimes abused machines as I do (vintage motorcycles for instance), often the engine(s) will need work. Lots of work. That's where the "rebuilding" happens. I also do free work for friends and family who have mechanical problems. Accordingly, there will be a variety of issues that may require intense mechanical work.
I've never had an engine that I purchased new, fail. Some are thirty plus years old and all start quickly and run steady and strong.
I leave equipment at my cottage for six months at a time with regular pump fuel in them. I drain the carbs on machines that have float carbs. Diaphragm carbs are left as is. I've got a 1984 Jonsereds chainsaw and an '84 Stihl brush cutter that are left out there every year since new. Five pulls or so and they
both fire right up every spring. Same with everything else I leave out there all winter. I've yet to have any problems that would be related to fuel or oil.
Maybe I'm just lucky. If I am, I've been very lucky for a very long time.
#2289988 - 06/16/11 08:05 PM Re: Stihl Motomix vs Trufuel 50:1 [Re: boraticus]
doitmyself Offline
Loc: MI
Knock on wood, but I too have had no apparent problems from ethanol fuel in dozens of outdoor power equipment at my workplace using reasonable fuel management practices. Some equipment sits for six months without problems, but I get nervous around that point.
The one difference I could imagine is that gasoline probably does go bad more quickly in the summer heat of the southern states. And, storing equipment overwinter in unheated garages in the northern states likewise causes the fuel to store longer and better.
Just a hunch.
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#2290168 - 06/17/11 12:18 AM Re: Stihl Motomix vs Trufuel 50:1 [Re: doitmyself]
FNFAL308 Offline
I suspect there is a difference in fuels from state to state, as well as seasonal fuels. I also think that the Southern states may very well have more fuel issues then other places?
I see fuel probs everyday, carb rebuilds in both handheld and other equipment is common place for me. Sometimes I can clean the carb sometimes it needs a kit, sometimes I have to replace it.. Heck, I've done a good number of pcs just this week..
While I have no scientific proof I "suspect" that changes in the fuels (NOT just Ethanol) have made them much less stable and and they go bad faster then years ago. I can't begin to tell you how many pcs of equipment I get with fuel/carb issues from the SNOW BIRDS when they return south for the winter?
I've already posted in another thread the issues I see related to Ethanol and have also stated that there are a number of places that blame every conceivable anomoly on Ethanol which of course is just so much B~S..
Ethanol WILL harden the Diagrams in handheld equipment carbs.. It WILL eat the sealant on some of the Welch plugs in these carbs although most have changed to another sealent to keep this from happening..
Ethanol DOES cause BIG issues in the Marine industry which as one can imagine is pretty big here..
However it is NOT the cause of every run problem on earth just oft blamed when the REAL problem is not known/found.
I have 2 Gens of my own here at the house, working in the field I kinda pride myself on my care/maintenance of these and other pcs of equip I have.. These units had fresh fuel in them along with a healthy dose of SEAFOAM added to the fuel.. They were run for 30 min or so, then I shut the fuel off and run them till they die working the choke at the end to get as much fuel out as possible.. I start them every couple/3 months and repeat the process but even so the other day while doing my Pre-hurricane gen runs my Main gen with a 13 H/P Honda would not run at WOT... NO biggy to me as I had it fixed and running in about 10min but my point is these fuels just don't hold up like they used to.. I "DON'T" think this is an Ethanol issue it was just old fuel blocking a few holes in the emulsion tube running through the center of the carb.. I often see MAIN jets plugged as well but not in my case..
While "some" carbs (like this one in particular) can be drained there are a lot of others that can't be without removing and disassembling the carb first..
My 4-Mix Kombi sees a LOT of use, my MS-260 Pro See's occasional use and BOTH start and run perfectly every time..
While some may call the New fuels a Fad or Boutique fuels I can certainly see the attraction to them especially for a Homeowner and occasional user.. I don't see these fuels being cost effective or practical for a Commercial application but that's pretty much a no brainer..
#2290309 - 06/17/11 08:38 AM Re: Stihl Motomix vs Trufuel 50:1 [Re: car54]
boraticus Offline
Loc: Canada
Every fuel issue I've encountered is contamination. Usually water or a combination of water and debris. Last year I refueled
one of my outboards with freshly purchased fuel. A half mile from shore, the engine began to miss and sputter then stopped. I lifted the cowl and inspected the transparent fuel filter. The contents of the filter was orange, not blue. I drained it into a bailing can. I tilted the fuel tank onto the corner where the fuel pick up is then opened the fuel fitting to allow me to pump the bottom of the fuel tank into the bailing can. I pumped a good half litre of rust coloured water before I got to clean blue fuel. I reconnected the fuel line, loosened the drain plugs on the carbs and pumped clean fuel through.
Every fuel encounter I've had has been similar. Water in the fuel is worse than dirt. Filters can catch the dirt but water will get past.
If people were more vigilant inspecting their fuel before putting it into their machines, they may find that will solve a lot of problems. When your fuel container is getting low, tilt it to move the fuel to one corner and look for two distinct liquid layers. A siphon hose will easily pick up the water. Siphon off the water until you see clean fuel.
#2290410 - 06/17/11 10:56 AM Re: Stihl Motomix vs Trufuel 50:1 [Re: boraticus]
660mag Offline
Loc: TEXAS
boraricus,
sometimes I think your lack of understanding the market for chemical advances stems from not giving yourself enough credit. 98% of boaters would have had to get a toe that day.
Will
