Pennz Ultra Euro 5W40, 7848 mi, 2002 Volvo V70XC
Astro14
$100 Site Donor
Staff member
Virginia Beach
Html:
LAB NUMBER: E59291 UNIT ID: 2002 V70XC
REPORT DATE: 6/13/2011
REPORT
Volvo 2.4L Turbo 5-cylMAKE/MODEL:
OIL TYPE & GRADE: Pennzoil Ultra Euro 5W/40
Gasoline (Unleaded)FUEL TYPE:
OIL USE INTERVAL: 7,848 Miles
COMMENTS: Amended report. This first sample from the 2.4L
turbo in your V70XC looks pretty good. Universal averages
show typical wear levels for this type of engine after about
4,800 miles on the oil. Iron was just a little higher than
average, but this oil was in use 7,848 miles, so this level
really isn't cautionary. No fuel or coolant was found and
the viscosity was normal for 5W/40. Low insolubles and
silicon show good oil and air filtration. The TBN was 1.2
showing a little active additive left; less than 1.0 is too
low for extended use. Try going 9,500 miles on the oil run.
MI/HR on Oil 7,848
MI/HR on Unit 141,974
Sample Date 06/06/11
Make Up Oil Added 1 qt
ALUMINUM 2
CHROMIUM 0
IRON 25
COPPER 3
LEAD 5
TIN 4
MOLYBDENUM 2
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 1
BORON 40
SILICON 6
SODIUM 4
CALCIUM 1929
MAGNESIUM 116
PHOSPHORUS 832
ZINC 929
BARIUM 0
PROPERTIES
SUS Viscosity @ 210°F 74.3 65-78
cSt Viscosity @ 100°C 14.08 11.6-15.3
Flashpoint in °F 380 >375
Fuel %
Antifreeze % 0.0 0.0
Water % 0.0
Insolubles % 0.2
TBN 1.2
TAN
ISO Code
Relatively happy with this report, viscosity held up well, but slightly higher wear metals were a surprise. Car is a Daily Driver, so sees lots of city miles and idling in the heat...with the TBN at 1.2, I will stick with the factory OCI of 7,500 miles/12 months.
It certainly looks good to me. With TBN of 1.2 (with a qt of makeup oil), a recommendation to extend the OCI to >9K seems, well, odd...
I'm curious though, why this stuff in the XC70 if you're using M10W40 in the T5? I know the M1 is readily available (on sale!). Isn't this stuff really hard to get--and expensive? Not judging, mind you--just wondering?
Curiosity is my only answer - I've managed to get the M1 0W40 on sale (and, in fact, got a GREAT deal on some M1 5W40 TDT). You're right, this stuff is hard to find and relatively expensive...I just wanted to try it out...the XC has PU 5W40 in it again...and I will do another UOA after this run.
But clearly, I can't run this oil any farther than M1...the car with the M1 had a long (3K) highway trip...so perhaps the M1 would have had the lower TBN of the PU had it been subjected to the same use...
Curious what you paid for the Pennz Ultra Euro 5W40.
I found it in one place in Ottawa and was quoted $17.00/liter and almost fell off my chair!
It was about $50/6 Qts including shipping...pretty steep, but I got a really cool Ferrari hat with each order ...It may have been that hat that really drew me in...
http://www.buypennzoilultra.com/index.cfm
I will also say that I got a peek into the crankcase during the last oil change (I had to replace the oil cooler o-rings). That crankcase looks new - not even any varnish. Now, I have never seen it before, so I can't tell you if it's the PU or previous synthetics I have used. I have owned the car for 3 years and 50K miles, so PO maintenance and previous engine condition are unknown. Volvos have a screen on the oil fill that blocks the view of the cam galleries...
Clean as a whistle at 142,000 miles - very happy about that.
Cheers,
Astro
The report looks good. It thicken up from 13.1 to 14.1 @ 100c at the end of the OCI.
