Questions about manual transmission sounds
by Why_Anything
07/01/16 11:09 PM
HOW to learn PINSTRIPING & lettering ??
by SumpChump
07/01/16 11:08 PM
'96 Nissan Maxima - Intake R&R - EGR tube bent
by 92saturnsl2
07/01/16 11:00 PM
Anybody want a lot of 6 Carquest Blue 84060?
by CapitalTruck
07/01/16 10:38 PM
new Tundra color
by lawnman
07/01/16 10:36 PM
Bought A Yamaha XSR900 today!
by donnyj08
07/01/16 10:21 PM
Akebono ProACT vs EBC Ultimax "Blackstuff" pads
by slacktide_bitog
07/01/16 10:08 PM
Replace oxygen sensor by mileage ?
by Merkava_4
07/01/16 10:02 PM
I was slightly wrong on the Purolator transition
by slacktide_bitog
07/01/16 09:57 PM
Things your dogs have eaten.....
by OVERKILL
07/01/16 09:45 PM
What Happened To Johnny ??
by crazyoildude
07/01/16 09:39 PM
Home Depot--Formula Shell--Buy 4 qt. get one free.
by BigD1
07/01/16 09:34 PM
Aidil, dandandan, dbertheau, Jennyp, dcdodge
58341 Registered Users
50 registered (addyguy, anonobomber, AZjeff, Buzzsaw, bvance554, 01_celica_gt, 3 invisible), 1040 Guests and 9 Spiders online.
58341 Members
66 Forums
251129 Topics
#2274089 - 05/29/11 06:12 PM Can i sub reg. tranny fluid for Nissan tranny fl.
kevlee1973 Offline
Loc: North Georgia
I got a 2005 Nissan Altima with 122000 miles and just had the tranny flush and 600 miles later the car shutters when ya come to a stop, and the fluid looks burn? When they flushed the tranny fluid it wasn't with Nissan fluid, should it matter?
#2274100 - 05/29/11 06:21 PM Re: Can i sub reg. tranny fluid for Nissan tranny fl. [Re: kevlee1973]
HTSS_TR Online   content
Loc: Lake Forest, CA
You had the transmission fluid (the old fluid looked/smelled like it was burnt) replaced at a garage with aftermarket ATF at 122k miles, 600 miles later you felt the car shutters at idle ? Which aftermarket ATF did the garage use ?
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
"Throwing food away is like stealing it from the poor and hungry" Pope Francis
#2274105 - 05/29/11 06:34 PM Re: Can i sub reg. tranny fluid for Nissan tranny fl. [Re: HTSS_TR]
kevlee1973 Offline
Loc: North Georgia
I believe dex 3 but not toally sure, with the fluid all ready burnt again after 600 miles does that mean the tranny is going out or the replace with the wrong fluid? What should I replace the tranny fluid with that I can get from a local auto parts store?
#2274113 - 05/29/11 06:51 PM Re: Can i sub reg. tranny fluid for Nissan tranny fl. [Re: kevlee1973]
chad8 Offline
Loc: michigan
Yes it matters. Some idiot at your shop used generic mercon 3 fluid probably with an additive. Those trans are very sensitive . you should use only nissan matic-k or something like amsoil full synthetic. You got screwed. Get that [censored] out of there quick before you do more damage . I hate to be overly dramatic ,but in this case it is necessary. You might get away with valvoline synthetic maxlife mercon v, or mobil 1 full synthetic from advance. Do a full flush or make the idiot that changed your fluid do it right. Here is a link or 2 to others in your situation.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=512980
http://www.nissanclub.com/forums/2002-20...uid-change.html
Edited by chad8 (05/29/11 07:04 PM)
#2274120 - 05/29/11 07:05 PM Re: Can i sub reg. tranny fluid for Nissan tranny fl. [Re: kevlee1973]
It's very possible that the shop used cheap ATF that why it smelled burnt after only 600 miles. I would change the fluid out as soon as possible with Nissan ATF.
'00 MB E430
'04 Honda S2000
'06 Volvo V70
'14 Honda Accord LX
#2274139 - 05/29/11 07:39 PM Re: Can i sub reg. tranny fluid for Nissan tranny fl. [Re: HTSS_TR]
barlowc Offline
Loc: Southeast Michigan
Does your 2005 Altima have a 4-speed or 5-speed automatic transmission in it?
A 4-speed calls for Genuine NISSAN Matic D ATF. The owner's manual notes DEXRON™ III/MERCON™ or equivalent may also be used.
A 5-speed calls for Genuine NISSAN Matic K ATF. The owner's manual notes, "Using automatic transmission fluid other than Genuine NISSAN Matic K ATF will cause deterioration in driveability and automatic transmission durability, and may damage the automatic transmission."
2013 BMW 335i xDrive Sport Line (34K Miles)
#2274179 - 05/29/11 08:43 PM Re: Can i sub reg. tranny fluid for Nissan tranny fl. [Re: kevlee1973]
WMSmotorhead Offline
Loc: Cleveland OH USA
Dex/Merc isn't good for every application...... There's some full synths like Amsoil, Amalie, or Wolfshead that profess universality, and usually perform well. Make sure the bottle says compatible with (Nissan fluid number)
#2274246 - 05/29/11 11:19 PM Re: Can i sub reg. tranny fluid for Nissan tranny fl. [Re: kevlee1973]
wiswind Offline
Loc: Wisconsin
A lookup of the 2005 Nissan Altima on the Amsoil website shows their Multi Vehicle Synthetic ATF to be their recommended fluid for both the 4 and 5 speed transmissions.
It further states Nissan Matic D, J and K in the recommended application list.
The Redline Website recommends their D4 ATF for the 4 and 5 speed transmissions in the 2005 Altima.
It also lists the Nissan Matic D, J and K in their recommended application list.
There may be other fluid brands, but these are 2 that I looked up.
I did not see the Nissan Matic D or K listed in the Mobil 1 ATF specifications on the Mobil website, but I could have missed it.
#2274248 - 05/29/11 11:24 PM Re: Can i sub reg. tranny fluid for Nissan tranny fl. [Re: kevlee1973]
EricF Offline
Loc: SF Bay Area
in an 03 Altima 4spd auto I've used the Castrol import ATF and have no problems at all.
the 03 I believe is spec'd for Matic J.
I used Dex 3 in a 99 Ranger that req'd Mercon V.. I did use a Lubegard converter additive and well.. no problems reported either. then again.. the ford tranny isn't as picky as a nissan one is.
1993 Ford Ranger XLT 4.0L 4x4 (240k) 5W-30 Synpower
2006 Saturn Relay-3 3.5L (85k) 5W-30 Synpower
2012 Ford Fusion SE 2.5L (39k) 5W20 M/C Semi Syn
#2274250 - 05/29/11 11:32 PM Re: Can i sub reg. tranny fluid for Nissan tranny fl. [Re: kevlee1973]
Towncivilian Offline
Loc: Florida, USA
My Pathfinder's RE4R01A transmission is spec'd for Matic D and I've been slowly replacing Matic D with Valvoline Maxlife through drain & fills and I've had no issues. Maxlife meets Matic D, J, and K.
2001.5 Pathfinder SE 3.5L A/T 2WD - ML NG 5W-30/PL14610
2007 Altima S - PU 5W-30/M1-110
2009 G5 - PU 5W-30/XG9018
2012 G37 S - ST 5W-30/PL14612
#2274871 - 05/30/11 08:10 PM Re: Can i sub reg. tranny fluid for Nissan tranny fl. [Re: kevlee1973]
coachditka Offline
Loc: Texas
Castrol Import, Royal Purple Max ATF, Amsoil, BG synthetic, and Mobil 1.
Any one will work. I am running Royal Purple instead of Matic J.
Just get all the old fluid out and put in fresh!
Edited by coachditka (05/30/11 08:11 PM)
2005 Nissan Titan 280k
Pennzoil Ultra 5w30
Royal Purple Oil Filter
Amsoil ATF
Amsoil 75w140 diff oil
2007 Volvo XC90 V8 AWD 140k
Mobil 1 0w40
Mobil 3309 ATF
#2275670 - 05/31/11 05:14 PM Re: Can i sub reg. tranny fluid for Nissan tranny fl. [Re: chad8]
Ken2 Offline
Loc: Washington St.
Errr...no such thing as Mercon 3.
In any case, yes, do flush again and use a fluid with the label that lists it as suitable for your transmission.
Lubegard claims that Dexron-VI fluid plus their Platinum supplement is suitable in transmissions that require Nissan Matic-K. I doubt your transmission shop used that, maybe a Dexron-III fluid plus Lubegard (or other) black bottle highly friction modified supplement, the wrong stuff.
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
