Snowdog
by CourierDriver
29 minutes 59 seconds ago
Kendall GT-1 synthetic oils
by SR5
Today at 02:43 AM
2015 F 150
by BISCUT
Today at 01:19 AM
Ever have an "old guy" day?
by daves87rs
Yesterday at 10:25 PM
Fram Ultra C$11.87 (Ontario)
by dgunay
Yesterday at 10:16 PM
dodge 4.7 fram problem?
by joel95ex
Yesterday at 09:45 PM
ok until oil change 4.7 dodge
by joel95ex
Yesterday at 09:41 PM
0w20 vs 5w20 running on a Mazda 3 2014
by Stewie
Yesterday at 09:37 PM
5w20/30 4.4L Castrol Edge WM Canada $24.88
by Stewie
Yesterday at 09:31 PM
Back to greasing stuff...
by JHZR2
Yesterday at 09:04 PM
Castrol Import Multi question
by Carguy21
Yesterday at 08:20 PM
2005 F150 steering rack
by Colt45ws
Yesterday at 08:12 PM
paulp, ATLjunkcars, jqgz, ukpdxwrx, TerrenceRocks
56865 Registered Users
76 registered (BlueOvalFitter, b1amgm47, Boomer, Brad_C, 05LGTLtd, 901Memphis, 10 invisible), 942 Guests and 200 Spiders online.
56865 Members
66 Forums
244433 Topics
#2271892 - 05/26/11 09:59 PM Cylinder not firing? 2002 Honda Shadow 750
kevinf Offline
Loc: Virginia
I'm trying to get a motorcycle back in service. I've cleaned the carb jets once already. The front cylinder appears to not be firing based on the amount of heat I feel in the exhaust pipe(hmmmm),compared to what's coming out the rear exhaust pipe (yeeeouch!). I switched the coils, front to back, and it ran the same way. I checked the float bowl in the front carb, and it had fuel in it. What are the next steps I should take to diagnose the problem?
'07 Toyota Sienna - Castrol GTX 5W30
'01 Toyota Sienna - PP 5W30
'98 Acura CL 3.0 - G-Oil 5W30
#2271896 - 05/26/11 10:12 PM Re: Cylinder not firing? 2002 Honda Shadow 750 [Re: kevinf]
Chris142 Online   content
Loc: apple valley, ca
Did you actully ck for spark?
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#2271950 - 05/26/11 11:26 PM Re: Cylinder not firing? 2002 Honda Shadow 750 [Re: Chris142]
kevinf Offline
Loc: Virginia
No, how do I do that safely? I was going to buy an extra plug and tape it to the cylinder head so that it's grounded.
#2272047 - 05/27/11 07:07 AM Re: Cylinder not firing? 2002 Honda Shadow 750 [Re: kevinf]
Trav Offline
Loc: MA, Mittelfranken.de
Did you try a new plug?
#2272095 - 05/27/11 08:22 AM Re: Cylinder not firing? 2002 Honda Shadow 750 [Re: kevinf]
meep Offline
Loc: Southeast
you need, spark, fuel, and compression.
pull the plug, tape, lay, tie, it to something and crank. look for spark.
sniff the tailpipe for fuel. don't stick your nose in it, use your hand to waft the fumes towards you. you can also try a squirt of starter fluid.
I love the older shadows. first bike I ever rode was a 500 shaft drive, a wonderful, wonderful machine.
2006 Tundra 2wd
2002 MDX (wifey!)
2005 s60 2.4L
#2272183 - 05/27/11 09:55 AM Re: Cylinder not firing? 2002 Honda Shadow 750 [Re: kevinf]
Bladecutter Offline
Loc: Dacono, CO
Did you pull the pilot jets, and run a copper strand through it to make sure they weren't plugged?
Have you pulled the non-firing spark plugs to see if they are fouled or dry? Switch the plugs between the two cylinders. Should be a 2 plug per cylinder setup for the Honda 52 degree V-Twin.
Here's what I would do if it were my bike, in order:
Pull carbs, and recheck the pilot jets for clogs, and reset the mixture screws to 2.5 turns out. Might be worth the $20 to replace both pilot jets with new ones.
Check the spark plugs for fouled or dry condition.
Replace if fouled.
Check valve clearances (too tight valves lead to idle issues).
I work on lots of motorcycles, and see your symptoms on a regular basis every spring. Chances are your bike sat over the winter. New (or properly cleaned) pilot jets should get you up and running right quick.
BC.
2014 Mazda CX-5 Touring (Soul Red)
2015 Porsche Cayman
2007 Ducati 848
1988 Honda Hawk GT
#2272229 - 05/27/11 10:37 AM Re: Cylinder not firing? 2002 Honda Shadow 750 [Re: kevinf]
mechtech2 Offline
Loc: Chicago Area
I'm with Blade.
It's probably fuel related. There are all sorts of jets and passages besides the main jet. Amateurs concentrate on the main only.
Fresh plugs Are always smart in a scooter, esp after misfiring for whatever reason.
#2272347 - 05/27/11 12:02 PM Re: Cylinder not firing? 2002 Honda Shadow 750 [Re: kevinf]
dwendt44 Offline
Loc: Central Wisconsin
Ya, the carb is still plugged.
Resurrected an old Suzuki twin. First time I cleaned the carbs, it would only run on one cylinder. Cleaned them again(they are bracketed together) with a stronger carb cleaner. Then it ran fine.
There's no such thing as:
Too big of a battery,
Too large of a gas tank,
or too loud of a horn,
or too bright headlights.
#2272372 - 05/27/11 12:37 PM Re: Cylinder not firing? 2002 Honda Shadow 750 [Re: dwendt44]
kevinf Offline
Loc: Virginia
Thanks for the input so far. I bought two new plugs for that cylinder, now I'll check spark to rule that problem out definitively.
Based on the response posts, now I'm thinking that I didn't get that front carb clean enough. It was the first one I worked on and I may have been too careful with it and not clean agressively enough. It is a real pita to get those joined carbs off and on in that teeny space. I think I'll video record how I remove them this time so I can get them back on easier.
I have a compression tester for my car. Do they sell adapters for it to work on a motorcycle, the spark plug is narrower, no?
#2272585 - 05/27/11 05:25 PM Re: Cylinder not firing? 2002 Honda Shadow 750 [Re: kevinf]
Bladecutter Offline
Loc: Dacono, CO
Yes, compression testers have adapters to work on the smaller spark plug holes. The kit I bought many years ago came with several fittings, one of which works with just about every motorcycle I've ever used it on.
A tip for narrow angle v engines is to remove one intake boot with the carbs, while leaving the second one still attached with the engine. Makes life much, much easier. Just be grateful you aren't doing the carbs on a Honda Interceptor with the V-4 engine. That's a royal pain in the bum getting them on and off.
Make sure when you remove the carbs from the bike, and are working on cleaning them, that you unscrew the pilot jets (#40 size for your bike), and hold them up to the light to see through them. If you can't see through it, its clogged. You should see light coming through.
BC.
2015 Porsche Cayman
2007 Ducati 848
1988 Honda Hawk GT
#2272686 - 05/27/11 08:12 PM Re: Cylinder not firing? 2002 Honda Shadow 750 [Re: Bladecutter]
kevinf Offline
Loc: Virginia
Thanks everyone - update
OK, it has spark, and now it has two new plugs in the front cylinder.
I'll pull the carbs again when I get time.
Here's something I thought was bizarre, I called Actron and they were out of 12mm adapters for their compression testers. Part is 0180-000-0894. How does a manufacturer run out of a simple component they sell on a regular basis? I may buy a cheap compression tester kit from Harbor Freight just to get the adapters.
#2273226 - 05/28/11 01:33 PM Re: Cylinder not firing? 2002 Honda Shadow 750 [Re: kevinf]
mechtech2 Offline
Loc: Chicago Area
If it ran OK before it was stored, the engine probably is did not break mechanically when sitting.
It's the carb[s].
