Ford 4.6 with Supercharger, 2,000 mi. / yr.
by milkboy
4 minutes 35 seconds ago
Only secure content is displayed?
by Eddie
Yesterday at 11:35 PM
2008 Honda Element oil question
by fujirio
Yesterday at 09:50 PM
TIRE QUESTION
by renegade_987
Yesterday at 09:46 PM
What's your favorite outboard and why ??
by BrocLuno
Yesterday at 09:30 PM
Briggs 'Quantum 6.0' Flathead top no load 2600RPM
by Colt45ws
Yesterday at 09:15 PM
EPA efficiency testing may not work, at all
by wemay
Yesterday at 09:11 PM
Mobil 1 0w40 for 2013 4.8 V8
by CapitalTruck
Yesterday at 09:04 PM
2013 Passat service
by powersmo
Yesterday at 08:24 PM
A/C troubleshoot
by Leo99
Yesterday at 07:50 PM
Chevy Cavalier ATF Change - What fluid is best?
by rowebil
Yesterday at 07:45 PM
RIP, Sam Wheeler
by 02SE
Yesterday at 07:43 PM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
38 registered (artificialist, carlprop, Chewie, bdcardinal, bvance554, c502cid, 3 invisible), 1131 Guests and 15 Spiders online.
58632 Members
66 Forums
252382 Topics
Page 1 of 2 1 2 >
#2270885 - 05/25/11 06:26 PM What problems using kerosene in a diesel?
Shaman Offline
Loc: Frankfort, Kentucky
Considering that diesel is cheaper here, for academic's sake, what problems will a little, or a lot of kerosene in a diesel engine cause?
Flame temp?
Lubricity?
VIscosity?
#2270910 - 05/25/11 07:11 PM Re: What problems using kerosene in a diesel? [Re: Shaman]
bullwinkle Offline
Loc: Cincinnati, OH, USA
Lubricity is definitely lower, as is energy value (especially in summer). Here in the USA there is no road usage tax on kerosene, but it will work fine in diesel, especially if 2-stroke oil is added to get the lubricity up.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(CQ Blue)
#2270917 - 05/25/11 07:24 PM Re: What problems using kerosene in a diesel? [Re: Shaman]
Shaman Offline
Bullwinkle, I am seeing
1 gallon kerosene = 135,000 BTU
1 gallon diesel = 139,200 BTU
and I just got this from Lube Control
Bigger concern with running kerosene in a diesel engine is the higher combustion temperature. Everything in the combustion area will start wearing much faster (rings, gaskets, valves, etc.). This is seen in mines where they use kerosene to reduce the emissions because diesel would kill all the mine workers. Kerosene burns very clean, but also very hot.
Edited by Shaman (05/25/11 07:28 PM)
#2273136 - 05/28/11 11:23 AM Re: What problems using kerosene in a diesel? [Re: Shaman]
JHZR2 Offline
Loc: New Jersey
Kerosine ha a different viscosity characteristic - not necessarily good for moving parts. Believe the aromatics may have been all removed too.
Kerosine is often used to cut diesel in cold weather. Besides being more pricey, Id not really see a huge benefit if cold fow isnt required.
#2273440 - 05/28/11 07:27 PM Re: What problems using kerosene in a diesel? [Re: Shaman]
Shaman Offline
Kerosene here runs about 2/3 the price of diesel.
#2290973 - 06/17/11 10:31 PM Re: What problems using kerosene in a diesel? [Re: Shaman]
Gene K Offline
Loc: Decatur AL USA
Pretty close to #1 Diesel.
Gene
2014 Mustang GT 5.0 SC - 675 bhp
PP 10W30 / FL500S
2015 F150 4x4 2.7 EB
PSB Gold 5W30 / FL2062
2015 Enclave 3.6
GM Dexos 5W30 / PF63
#2472341 - 12/25/11 03:27 AM Re: What problems using kerosene in a diesel? [Re: Shaman]
Exhaustgases Offline
Loc: wa
Kerosene should be pretty cheap. Well if it wasn't the airlines could not afford it.
#2472342 - 12/25/11 03:29 AM Re: What problems using kerosene in a diesel? [Re: Shaman]
Loc: wa
Can't be higher temps. Why kerosene has a lower heat value than diesel.
I have run diesel engines on it many times in the past.
I was trying to quote the fellow that said it would run hotter.
Edited by Exhaustgases (12/25/11 03:30 AM)
#2472362 - 12/25/11 06:22 AM Re: What problems using kerosene in a diesel? [Re: Shaman]
Shaman Offline
Wife mentioned that co2 output would increase using k1. She said that is how they "dip" here in Japan.
#2472636 - 12/25/11 03:43 PM Re: What problems using kerosene in a diesel? [Re: Exhaustgases]
Shannow Offline
Loc: Oz
Because it's a "heating" product, there's no road taxes on it. As to airlines, there's an international "treaty" that transport taxes don't apply to aviation kerosene.
It's still hideously expensive downunder 'though.
#2473773 - 12/27/11 06:27 AM Re: What problems using kerosene in a diesel? [Re: Shaman]
Cujet Offline
Loc: Jupiter, Florida
I run my diesels on kero (jet A1). I sent off samples for testing. The HFRR wear testing was quite informative.
1) straight kero did not have enough lubricity, with a wear scar number around 650.
2) Adding Stanadyne lubricity additive, as directed, brought the number down to a more reasonable level, around the maximum value allowed for diesel (around 450). Safe? Not really.
3) Adding a double dose of Stanadyne lubricity additive and 100 to 1 Penzoil outboard engine oil brought the wear scar number down to 255, a very good number. This is the mix I use. It's clean running, it lubricates pumps and injectors very well and there are no internal engine wear issues.
I've been doing this for many years now. It works in any conventional diesel. However, I'd never do this in a modern, emission controlled engine. Mostly due to high sulfur content.
Edited by Cujet (12/27/11 06:28 AM)
Turbo's rule.
#2473794 - 12/27/11 07:29 AM Re: What problems using kerosene in a diesel? [Re: Shaman]
Shaman Offline
YOu didn't happen to test your emissions did you? Great info on the scar numbers, thanks for posting.
#2504048 - 01/24/12 08:34 AM Re: What problems using kerosene in a diesel? [Re: bullwinkle]
TiredTrucker Offline
Loc: Central Iowa
Really? 2-cycle oil will up the lubricity considerably? Not according to this study...
http://www.natbiogroup.com/docs/education/lubricity%20additive%20study%20results.pdf
In order to know what is bad, you have to know what is good. The question them becomes, what is the source of knowing what is good?
#2524923 - 02/04/12 05:04 AM Re: What problems using kerosene in a diesel? [Re: Shaman]
CDX825 Offline
Loc: Litchfield, Ohio
I find that test a bit off. Most people who run 2 cycle oil run it stronger than 200:1
All the people Ive ever talked to about it run 128:1
1984 Ford F250 6.9 Diesel C6 2WD Rotella T 15W40 NTZ Bypass Filter
1992 Ford F150 5.8 4x4 Rotella T5 10W30
#2553398 - 03/01/12 12:40 PM Re: What problems using kerosene in a diesel? [Re: Shaman]
HerrStig Offline
Loc: Boston, MA
Interesting lack of performance from MMO and Lucas mouse milk in the study.
Several years ago the Brit Top Gear guys raced a diesel BMW in an endurance race in the UK. Half way through they blew up a fuel pump. THEN they admitted they were using a "fuel mix" which contained a fair amount of methonal. Alcohol apparently does little good for TDI fuel pumps.
Edited by HerrStig (03/01/12 12:41 PM)
Page 1 of 2 1 2 >
