I'm sure these have been posted before but...
by Yup
05/30/16 01:24 PM
Weedeater nylon cutter cartridge doesn't feed out
by 69GTX
05/30/16 01:23 PM
Larger Oil Filter for 2006 Highlander 2.4 Four Cyl
by Samzone
05/30/16 01:01 PM
I bought a Stihl weed trimmer, but...
by skyactiv
05/30/16 01:01 PM
2010 Tacoma oil selection help
by bchannell
05/30/16 12:52 PM
Will this "Universal" coolant work on my Car?
by Miller88
05/30/16 11:37 AM
Repelling heat
by mjoekingz28
05/30/16 11:27 AM
Wrong Dipstick? Honda Accord 2.4 Reading Low
by ThirdeYe
05/30/16 09:09 AM
radiator hose install, 08 Matrix.
by JustinH
05/30/16 08:56 AM
Bendix CT-3 Brake Pads
by RevelationLion
05/30/16 08:38 AM
Ever Have A Funniest Home Video Moment?
by coopns
05/30/16 08:20 AM
Parties
by AirgunSavant
05/30/16 08:02 AM
hokieag07, Welder_Repairman, saredX, Corraun, kevinstoyhauler
58023 Registered Users
80 registered (andyd, 04SE, 69GTX, Astro14, AirgunSavant, 5 invisible), 1934 Guests and 337 Spiders online.
58023 Members
66 Forums
249596 Topics
#2270294 - 05/25/11 05:14 AM Best grease for lawnmower spindles?
96 Cherokee Offline
Loc: Indiana
The local Co-op stores says high temp grease is better. How about synthetic? Is the higher priced grease worth it? Have been using Lucas Red & Tacky, but I am about out and it's time to buy another case. Thanks.
#2270323 - 05/25/11 06:56 AM Re: Best grease for lawnmower spindles? [Re: 96 Cherokee]
deeter16317 Offline
Loc: SE, PA
I'm pleased with Schaeffer #274, I haven't found a single thing it doesn't work well at...I use it in my spindles, drive shafts, and other bearings in my Grasshopper.
2004.5 Dodge 2500 Cummins
#2270324 - 05/25/11 06:59 AM Re: Best grease for lawnmower spindles? [Re: 96 Cherokee]
chad8 Offline
Loc: michigan
I use white lithium on almost everything because it is not messy , doesn't stain , works great, and inexpensive . Door hinges , boat steering cables etc... .
Hi-temp is just so 60's.
Synthetic marine grease on everything else like wheel bearings. I find it off season for pennies. High temp and stays put.
#2270327 - 05/25/11 07:04 AM Re: Best grease for lawnmower spindles? [Re: 96 Cherokee]
Bluestream Offline
Loc: Waterloo, ON
ANy grease is better than no grease at all...
2000 Cavalier 2.2 A4
2000 VW Beetle 1.8T M5
2000 Ford Explorer 4.0 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
#2270328 - 05/25/11 07:07 AM Re: Best grease for lawnmower spindles? [Re: 96 Cherokee]
Dieseldoctor Offline
Loc: tn usa
I would say you have about the right product fit for a spindle.. I dont think u need a high temp grease if it gets over 250 degrees i would suspect they'res a problem it's likely tho cheap insurance since it will less likely to seperate. I personally dont see a huge need for synthetic greases other than if you dont plan on lubricating it very often or use in automotive wheel bearing or sealed for life products.
I personally use Mystik JT-6 and they're tacky multipurpose grease.. another good selections i really like and use are pennzoil ultra and lubriplates 1200-2.
#2270375 - 05/25/11 08:23 AM Re: Best grease for lawnmower spindles? [Re: Bluestream]
bigdreama Offline
Loc: Fl & Vt
+1
'02 Honda Civic MT 241k
'14 Subaru Crosstrek MT 31k
'15 Toyota Tacoma 4x4 MT 4k
'07 BMW R1200GSA 58k
'98 Electra Glide 50k
'06 Kawi KLR650 33k
#2272664 - 05/27/11 07:32 PM Re: Best grease for lawnmower spindles? [Re: 96 Cherokee]
96 Cherokee Offline
Loc: Indiana
Thanks for the replies. After reading a bunch of other threads in the "Grease" forum, I think I would like to try Schaeffers. According to Schaeffers website, there is an auto parts store about 25 miles from here that carries it. smile
