No injector pulse, '92 Prelude, F20B, GSR ECM
by redhat
06/29/16 12:02 AM
Finding #1 Cylinder
by motorguy222
06/28/16 11:31 PM
Sure Filter 2821A C&P
by funflyer
06/28/16 11:27 PM
Can Kies save multiple phone info?
by daves66nova
06/28/16 11:25 PM
Tie-Rod Brands? AcDelco, B&A, Mevotech, MOOG
by Mr_Accord
06/28/16 10:23 PM
Engineer and Frog
by Koop
06/28/16 09:05 PM
Chevy 6.2 Silverado, Shaffer's or Mobile 1
by Crobinson16
06/28/16 08:32 PM
Am I crazy? Type of tire chain
by horse123
06/28/16 08:21 PM
Sedan or SUV?
by HTSS_TR
06/28/16 07:54 PM
GF5 and HTHS
by Gene K
06/28/16 07:53 PM
BITOG image uploader!
by wwillson
06/28/16 07:49 PM
Carquest Red filter question
by pbm
06/28/16 07:07 PM
dougsangster, CrazyCalvinW, mal86, smw, Crobinson16
58311 Registered Users
42 registered (Darris, carlprop, bubbatime, B320i, CKN, 3 invisible), 1062 Guests and 11 Spiders online.
58311 Members
66 Forums
250960 Topics
#2270021 - 05/24/11 06:54 PM All Valvoline oils: from thier data sheets
Loobed Offline
Loc: Northern California, USA
Here is a list of additive ppm for Valvoline oils.
This was taken from their product data sheet.
Effective 12-15-2010
TBN and Calcium is higher in Max Life; which also has moly.
No other type has Moly, not even the racing oil.
Synpower 5w-40 HST has the highest amount of Calcium.
VALVOLINE PREMIUM CONVENTIONAL MOTOR OIL
SAE 5W-20; SAE 5W-30; SAE 10W-30; SAE 10W-40;
SAE 20W-50; SAE 30; SAE 40; SAE 50
Zinc 830
Phosphorus 760
Calcium 1670
Sodium 490
TBN 7.3
VALVOLINE NextGen™ CONVENTIONAL MOTOR OIL
Zinc 830
Phosphorus 760
Calcium 1670
Sodium 490
TBN 7.3
VALVOLINE MaxLife™ Motor Oil
SAE 5W-20; SAE 5W-30; SAE 10W-30; SAE 10W-40; SAE 20W-50; SAE 30
Zinc 830
Phosphorus 760
Calcium 2110
Moly 140
Sodium 490
TBN 8.7
VALVOLINE NextGen MaxLife™ Motor Oil
Zinc 830
Phosphorus 760
Calcium 2110
Moly 140
Sodium 490
TBN 8.7
VALVOLINE SYNPOWER MOTOR OIL: ILSAC Grades
0W-20; 5W-20; 5W-30; 10W-30
Zinc 830
Phosphorus 760
Calcium 2110
Sodium 490
TBN 8.7
VALVOLINE SYNPOWER MOTOR OIL: non-ILSAC Grades
5W-30 MST; 5W-40 MST; 5W-40 HST; 20W-50
Zinc 840 (5w-40 has 990)
Phosphorus 770 (5w-40 has 900)
Calcium 1930 (5w-40 has 3260)
Sodium (none listed)
TBN 7.0
VALVOLINE VR-1 RACING MOTOR OIL
20W-50; 10w-30; SAE 30; SAE 40; SAE 50
Zinc 1400
Phosphorus 1300
Calcium 2100
Sodium 490
TBN 8.5
No Data for VALVOLINE VR-1 RACING (SYNTHETIC) MOTOR OIL
10w-30; 20w-50
Engine: 2001 GM 5.3L LM7
Current Fill: Valvoline Synpower 5w-30 w/Pure-One PL25288 filter
I.M.N Oil Enthusiast
#2270026 - 05/24/11 06:58 PM Re: All Valvoline oils: from thier data sheets [Re: Loobed]
Loobed Offline
Compare those numbers with Blackstone's numbers. They are off.
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2194500#Post2194500
#2270098 - 05/24/11 08:23 PM Re: All Valvoline oils: from thier data sheets [Re: Loobed]
daves87rs Offline
Loc: Michigan
That simply can't be right.....only 8.7 TBN on synpower?
Where's durablend??
Whatever you are, be a good one.
#2270127 - 05/24/11 08:55 PM Re: All Valvoline oils: from thier data sheets [Re: daves87rs]
bodeh6 Offline
Loc: Metro Detroit, MI
Synpower never started with a high TBN. So it is correct.
06' Subaru Legacy 2.5i 88K+ Miles
M1 HM 5W-30/OEM Filter
#2270128 - 05/24/11 08:56 PM Re: All Valvoline oils: from thier data sheets [Re: daves87rs]
tinmanSC Offline
Loc: Oswego, IL
This is true. Synpower has a low starting TBN as do most Valvoline oils.
Thank you for putting this together.
Cost of Hobby=2L
(Where L=Cost of Lubricant)
95 Lexus SC300 [email protected], 2000 [email protected] both VML Full Syn+Purolator PSL20195(soon to be Wix)
#2270190 - 05/24/11 10:22 PM Re: All Valvoline oils: from thier data sheets [Re: Loobed]
renegade_987 Offline
Loc: Ankeny, IA
too low of a tbn for my oci's, lol
2004 F150 189K Valvoline WB/Motorcraft FL-820S
2005 Ford 500 Limited 129K Motorcraft/Motorcraft
1994 Mustang GT Castrol/FRAM
#2270217 - 05/24/11 10:56 PM Re: All Valvoline oils: from thier data sheets [Re: Loobed]
motorguy222 Online   content
Loc: Ky
Super Tech in the SN version looks better than these.Here are the latest SN PDS's for ST SN in 10W-30 and 10W-40.
10W-30
Physical Specifications
Procedure Test Min Max Typical Results
ASTM D4052 Specific Gravity at 60°F NA NA 0.8717
ASTM D287 API Gravity NA NA 30.83
ASTM D445 Viscosity at 100°C, cSt 9.3 <12.5 10.29
ASTM D445 Viscosity at 40°C, cSt NA NA 67.73
ASTM D2270 Viscosity Index NA NA 138
ASTM D1500 ASTM Color NA NA 2.5
ASTM D5293 Cold Cranking Simulator, cP NA 7000 6249
ASTM D5185 Zinc, % mass NA NA 0.085
ASTM D4951 Phosphorus, % mass 0.06 0.08 0.077
ASTM D5185 Calcium, % mass NA NA 0.214
ASTM D5185 Molybdenum, % mass NA NA 0.0079
ASTM D5185 Boron, % mass NA NA 0.023
ASTM D4951 Sulfur, % mass NA 0.5 0.309
ASTM D5762 Nitrogen, % mass NA NA 0.102
ASTM D874 Sulfated Ash, % mass NA NA 0.92
TM
Conventional 10W-30 API Performance SN/GF-5
• Super Tech ConventionalMotor Oil contains only the highest quality, hydro-treated lubricating oils and a technologically advanced additive
system, which includes detergents, dispersants, viscosity improver, anti-wear and anti-friction agents as well as oxidation and corrosion
inhibitors.
• Reduced friction for excellent protection against wear and improved fuel economy
• High resistance to viscosity and thermal breakdown
• Meets or exceeds the latest North American vehicle warranty requirements API SN and previous API engines classifications SM, SL, SJ, SH
and ILSAC GF-3, GF-4 and GF-5.
12/9/2010
10W-40
ASTM D4052 Specific Gravity at 60°F NA NA 0.8710
ASTM D287 API Gravity NA NA 30.96
ASTM D445 Viscosity at 100°C, cSt N/A N/A 15.33
ASTM D445 Viscosity at 40°C, cSt NA NA 106.5
ASTM D2270 Viscosity Index NA NA 152
ASTM D5293 Cold Cranking Simulator, cP NA N/A 6771
ASTM D5185 Zinc, % mass NA NA 0.091
ASTM D4951 Phosphorus, % mass 0.06 0.08 0.079
ASTM D5185 Calcium, % mass NA NA 0.169
ASTM D4951 Sulfur, % mass NA 0.5 0.315
TM
#2270529 - 05/25/11 11:14 AM Re: All Valvoline oils: from thier data sheets [Re: daves87rs]
Loobed Offline
Where's durablend??
Sorry, I forgot. Here is more.
VALVOLINE MaxLife™ Synthetic Motor Oil
Zinc 830
Phosphorus 760
Calcium 1910
Moly 300
TBN 8.3
VALVOLINE DURABLEND MOTOR OIL
Zinc 830
Phosphorus 760
Calcium 2110
Sodium 490
TBN 8.7
Valvoline All-Fleet® Plus Engine Oil
15W-40; 10W-30;
Zinc 1270
TBN 10
10W; 20W; 30; 40; 50
Zinc 1260
TBN 7
Valvoline’s Premium Blue® Extreme Engine Oil
SAE 5W-40
TBN 10
Valvoline’s Premium Blue® Engine Oil
15W-40
TBN 10
VALVOLINE 4-STROKE MOTORCYCLE OILS
Zinc 1120
Phosphorus 1030
Calcium 1820
Sodium 520
TBN 8
Valvoline ATV 4 Stroke SAE 10W-40 Oil
Zinc 1020
Phosphorus 930
Calcium 1620
Sodium 470
TBN 7
Edited by Loobed (05/25/11 11:17 AM)
#2287067 - 06/13/11 02:44 PM Re: All Valvoline oils: from thier data sheets [Re: Loobed]
PandaBear Offline
Loc: Silicon Valley
If the data is correct, then the additive level and TBN of ILSAC SynPower is identical to MaxLife. Does that means the only difference is the synthetic vs a blend base stock?
Also MaxLife Syn actually has more moly, less calcium, and lower TBN. That means MaxLife Syn is actually a better oil (if viscosity is right) than SynPower.
"You keep asking questions PandaBear and you'll end up a vegetarian like my wife" - Camu Mahubah
#2287157 - 06/13/11 04:35 PM Re: All Valvoline oils: from thier data sheets [Re: PandaBear]
volk06 Offline
Loc: Iowa
The lower TBN does not mean that it is not a better oil. The base stock on the full syn is better even though it has a lower starting TBN, the TBN retention is/should be better. TBN retention is not linear. The same situation with the new Mobil Super. Mobil super conventional has a TBN of ~7.7 and the new Super Syn has a TBN of ~7.0. The Super Syn is guarenteed to 7500 where as the convention is only guarenteed to 5000 miles. Better base stocks makes up for the TBN.
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
#2885247 - 01/26/13 11:03 PM Re: All Valvoline oils: from thier data sheets [Re: Loobed]
buster Offline
Loc: NJ
I recently saw a 5w20 SN Synpower UOA on another forum and it had no moly, which is a change. Still Na for a detergent.
#2885260 - 01/26/13 11:59 PM Re: All Valvoline oils: from thier data sheets [Re: motorguy222]
Clevy Offline
Loc: Saskatoon canada
10W-30
TM
inhibitors.
12/9/2010
10W-40
TM
So basically their add packs are the same across the board,just be basestock changes?
They must have some organic adds that we can't see mixed in there somewhere. These add packs look weak other than the VR-1 but they seem to put out good uoa,unless you don't need a strong additive package?
2006 Charger RT
Miles x 2 per oil filter
#3114041 - 09/03/13 09:05 PM Re: All Valvoline oils: from thier data sheets [Re: Loobed]
CHARLIEBRONSON21 Offline
Loc: MEMPHIS, TN
looks like valvoline has gotten the "3000 mile interval" literally down to a science. looks like im going to be swinging to PP and motorcraft.
'13 Fusion Hybrid: 5w20 PUP/FU
'15 Civic Si: 0W20 PPPP/FU
'16 Fusion Hybrid: FF
'14 Odyssey: 0w20 PUP/FU
'93 Civic: 5W30 M1/TG
'99 SVT Cobra: 5W30 M1/FU
