Need Fuel Pump Assembly for Camry
by Nick1994
06/25/16 11:36 PM
2015 Accord V6 VCM engine UOA 36,680 mi / 9812 OCI
by TNM1982
06/25/16 10:55 PM
Why did Toyota recommend a winter and summer oil?
by BrianApp
06/25/16 10:00 PM
Fram TG 7317 6k miles
by bbhero
06/25/16 09:57 PM
Sta-Lube Moly-Graph Grease
by JHZR2
06/25/16 09:20 PM
Dead battery locks me out of Altima!
by Tom NJ
06/25/16 08:56 PM
Second lawn mower blade
by greasegunn
06/25/16 08:11 PM
Echo weed trimmer - carb issue?
by ryan2022
06/25/16 07:13 PM
Reviving Old Hard Rubber Experiment
by sleddriver
06/25/16 04:47 PM
Where do pets go?
by Whitewolf
06/25/16 04:47 PM
Help reading Bosch 3330 date code
by beavis87
06/25/16 04:11 PM
Castrol magnatec
by ChadW
06/25/16 04:07 PM
paul2005tb, Martyaus, carmelo, Shellman, SSO
58272 Registered Users
68 registered (abycat, 67lemans, austinlunsford, AntsinmyEyes, 901Memphis, 8 invisible), 1266 Guests and 8 Spiders online.
58272 Members
66 Forums
250816 Topics
Page 1 of 2 1 2 >
#2268755 - 05/23/11 10:54 AM Neat trick for seating a tire bead
dla Offline
Loc: MD
I had a tire that was flat on my tractor. I didn't see it at first (it was the tire against the garage wall) and pulled out of the garage and worked the bead loose from the rim.
Despite having an air compressor I couldn't get the tire bead to set properly against the rim. Air just kept leaking out the side of the tire.
Totally frustrated I called my dad looking for some words of wisdom and asked if he had any ideas on how to get the bead set on the tire. Without missing a beat he said "I sure do. Go get an old leather belt that you don't wear anymore. Wrap it around the tire, staying in the center of the tread pattern. Pull down on the belt like you are trying to tighten it and add air at the same time. The belt squeezing on the center of the tire will bulge the sidewalls out and seat the bead for you".
I went and did exactly as he said and immediately the bead set and was holding air. Hopefully this trick will help you guys out if you should have the same misfortune of a flat tire that is off the bead.
Cars currently in the garage: 01 Z28 heavily modified, 2013 Buick Enclave AWD, 06 SAAB 9-3 Aero, 2011 Chevrolet Avalanche LTZ 4WD,
#2268760 - 05/23/11 11:06 AM Re: Neat trick for seating a tire bead [Re: dla]
tmorris1 Offline
Loc: MN
Been using that one for years.
#2268768 - 05/23/11 11:12 AM Re: Neat trick for seating a tire bead [Re: dla]
eljefino Offline
Loc: ME
That is a good trick. You can also use a 1 inch tie down strap and then twist a stick in it round and round.
#2268770 - 05/23/11 11:13 AM Re: Neat trick for seating a tire bead [Re: dla]
Astro14 Offline
Loc: Virginia Beach
Nice...beats the heck out of the flammable gas "Red Neck" method...
32 Packard 15W40
90 4Runner 10W40 Edge
92 300E 0W40 Edge
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 5W40 PU
05 MB S600 0W40 M1
06 Corolla 5W30 Edge
#2268817 - 05/23/11 12:10 PM Re: Neat trick for seating a tire bead [Re: Astro14]
engineerscott Offline
Loc: Southeast USA
Yeah, I do the same thing with a rope and a bar of some sort. I tie the rope around the middle of the tire, then I use something like a combination wrench to go under the rope then I twist it to take up slack and increase the pressure along the center of the tire while adding air. This usually does the trick. As the other guys say, better than using a can of ether and a match.
#2268826 - 05/23/11 12:19 PM Re: Neat trick for seating a tire bead [Re: Astro14]
Stanley Rockafeller Offline
Loc: Van, B.C.
I dunno, that's a pretty neat trick.
-88 BMW 325ism-the Model 3
#2268849 - 05/23/11 01:12 PM Re: Neat trick for seating a tire bead [Re: dla]
greenaccord02 Offline
Loc: Houston, Tx, USA
Never heard of that, I've been using the redneck method ever since I saw some mexicans pop a tire back on a 4 wheeler using WD40. Used it just the other day on a riding mower, in fact. Yours sounds better, and is actually handier because I don't always have a bottle of flammable stuff on hand.
  1. '95 Dakota 3.9L - M1 0W-40 - MC FL1A
  2. '97 Accord F22-B1 - M1 5W-30 - Bosch 3312
  3. '99 Camry 1MZ-FE - PP 5W-30 - M1-209
#2268876 - 05/23/11 02:02 PM Re: Neat trick for seating a tire bead [Re: dla]
doitmyself Offline
Loc: MI
Are you talking about lawn tractor, compact tractor, or farm tractor here?
Turf tires or ag tires?
Thanks
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#2268962 - 05/23/11 03:55 PM Re: Neat trick for seating a tire bead [Re: dla]
Craig in Canada Offline
Loc: Toronto-ish, Canada
I did OK seating OPE tires by removing the valve from the valve stem and using the blow gun attachment for my shop air instead of an inflator which was too restrictive through the valve. I noticed that tire shops set the bead with the valve removed from the stem too so I thought I'd try it before moving on to more complicated methods.
With the trigger pulled on the blow gun I sort of wobbled the rim in the tires and it seated enough to start to hold pressure. Luck, maybe smile Just remove the blow gun, replace the valve in the stem and overinflate slightly to help make it "permanent".
Edited by Craig in Canada (05/23/11 03:55 PM)
#2268969 - 05/23/11 04:03 PM Re: Neat trick for seating a tire bead [Re: dla]
Panzerman Offline
Loc: Port Orange, Florida
I have used the rachet type tie-downs. You can get the tire to buldge without all the belt/stick/ wind up combinations. Works good though. I actually saw a worker at Walmart useing this method to seat a ATV tire, thats where I stole it from.
2007 Ford F-150 FX-2 73,000
2007 Ford F-150 FX-4 198,000 (Sold to the Son).
2006 Dodge Ram 2500 Sport 4x4 69,000
2002 Lincoln Continental 153,000
#2269202 - 05/23/11 08:35 PM Re: Neat trick for seating a tire bead [Re: dla]
steve20 Offline
Loc: Morris County NJ
Thanks DLA-never thought of that one-AND thank your Dad for me too!
427 Chevy Powered
#2269212 - 05/23/11 08:42 PM Re: Neat trick for seating a tire bead [Re: tmorris1]
JTK Offline
Loc: Buffalo, NY
+1. I've also gotten ATV tires to re-seat this way using a ratchet/strap like panzer suggests above. Lubing up the bead with dish soap helps too.
Joel
Edited by JTK (05/23/11 08:43 PM)
2016 Subaru Forester 2.5, CVT. 2013 Dodge Grand Caravan SE (Babe magnet III)
#2269445 - 05/24/11 06:06 AM Re: Neat trick for seating a tire bead [Re: dla]
Jeepster_nut Offline
Loc: East Coast
I use the WD-40 or hairspray method. Works like a charm.
For every complex problem there is a simple solution...and it is wrong. - H.L. Mencken
#2269534 - 05/24/11 08:43 AM Re: Neat trick for seating a tire bead [Re: dla]
boraticus Offline
Loc: Canada
"I use the WD-40 or hairspray method. Works like a charm."
Fire and noise!! Far more entertaining!
#2269558 - 05/24/11 09:18 AM Re: Neat trick for seating a tire bead [Re: dla]
Nick R Offline
Loc: Albany, NY
I always did like the explosive method of doing it. Much more entertaining.
2013 Ford Focus SE 2.0L/73,000miles/Motorcraft Blend 5W-20/FL-400S
Page 1 of 2 1 2 >
