Html:
OIL Factory Fill
OIL KLMS 1415
MACHINE KLMS 1415
SAMPLE TAKEN 15/5/2011
SAMPLE VISCOSITY
@40c cSt 50
PARTICLE COUNT(1-100) 30
PARTICLE SIZE %:10um 99%
PARTICLE SIZE %:10-20um 1%
PARTICLE SIZE %:>20um 0%
RUBBING High to 10um
CUTTING High to 10um
FATIGUE High to 10um
PARTICLE CONTAMINATION High
METALS
ALUMINUM 7
CHROMIUM 3
IRON 16
COPPER 27
LEAD 1
TIN
NICKEL
CONTAMINANTS
SODIUM 2
SILICON 44
ADDITIVES
BORON 11
MOLYBDENUM 4
CALCIUM 2551
MAGNESIUM 9
PHOSPHORUS 784
ZINC 920
SULPHUR 3185
WATER pre>
Comments on report:
Wear metals are at high levels in spectrographic results and high in microscopic report although particle size is small.
Silicon is high which may be due to sealant contamination. Viscosity appears low for an engine oil. Elevated levels of
wear metals and silicon levels are consistent with run in period. Expect levels to drop with oil changes which is
recommended. Please check intake ducting system as a precaution against dust entry. Resample at 1500 klms as wear
particles may be abnormally high in numbers.
Driving Conditions:
All city driving
Fuel economy: Approx 10L/100km
Refilled with: Fuchs GT1 0w20
Filter: MC AFL4
Next change will be made in Feb 2012.
OIL Factory Fill
OIL KLMS 1415
MACHINE KLMS 1415
SAMPLE VISCOSITY
@40c cSt 50
METALS
ALUMINUM 7
CHROMIUM 3
IRON 16
COPPER 27
LEAD 1
TIN
NICKEL
CONTAMINANTS
SODIUM 2
SILICON 44
ADDITIVES
BORON 11
MOLYBDENUM 4
CALCIUM 2551
MAGNESIUM 9
PHOSPHORUS 784
ZINC 920
SULPHUR 3185
WATER pre>
Comments on report:
Driving Conditions:
All city driving
Filter: MC AFL4
