45912 Members
64 Forums
195370 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#2264721 - 05/18/11 12:11 PM
MOBILFLUID 62
Loc: Tehran, Tehran, Iran
Hello to all
If anyone can tell me what is the best substitute for Mobilfluid 62. It has a viscosity of 1.5 Engler in 50 degree celsius and is used for power transmission in a Wulfel-Kopp speed variator.
Thanks
#2264747 - 05/18/11 12:38 PM
Re: MOBILFLUID 62
[Re: Northman]
Loc: SF Bay Area (formerly WI)
Hi and welcome to BITOG. This question might be better in the "hydraulic fluids" forum.
I searched that fluid and found a couple ideas. It looks like it's a SAE 80 GL-4 rated tractor fluid formulated for metal-on-metal clutches. It occurred to me our typical US brands might not be available in your location. What suppliers do you have available?
#2265357 - 05/19/11 01:18 AM
Re: MOBILFLUID 62
[Re: Northman]
Stu_Rock Thanks for your Welcome.
Would you give me what you found about Mobilfluid 62, please? My main problem is I can not find anything about it.
I must admit that it is an oil which transfers power by friction between metal-to-metal contacts (driver metal cone-sphere and sphere-driven metal cone) and as I told before it has a low viscosity (about 6.5 cSt at 50 degree celsius.
If u give me the typical US brand names I would be grateful.
#2265689 - 05/19/11 01:05 PM
Re: MOBILFLUID 62
[Re: Northman]
Just by looking at the documents that Google found, one vendor recommends the following fluids for Kopp variators: BP Energol CS 10 Esso Spin Way 10 Shell Vitrea Oil 10 Another vendor ( http://www.allspeeds.co.uk/kopp/oil.htm) strongly states that only the following should be used: Shell Morlina S2 BL Shell Tellus R10 I heard that Shell has pulled out of your country, but your local suppliers might have some ideas for substitutes. Good luck!
#2266216 - 05/20/11 03:03 AM
Re: MOBILFLUID 62
[Re: Northman]
Thank you very much Stu_Rock. The second group seems to fit my need.
But as you said this is just the beginning, now i should seek a way to find the equivalents in Iran (Down with Islamic Government).
