cstoremotoroil.com
by AirgunSavant
08/27/16 09:37 AM
What's good/bad about a 2006 Mazda 5?
by 55Test
08/27/16 09:30 AM
My 1st air impact - go with 3/8" or 1/2" drive ?
by Cressida
08/27/16 08:55 AM
Silly me
by jay929
08/27/16 08:41 AM
15K oil & filter
by marine65
08/27/16 08:36 AM
Battery or starter
by Dallas69
08/27/16 07:56 AM
Napa Syn 15w50 to replace BradPenn 20w50 in 454bbc
by FlyNavyP3
08/27/16 07:51 AM
Real Main Seal Leak ? ? ?
by larryinnewyork
08/27/16 07:35 AM
Gov't wants to lower speed limits for trucks
by JetStar
08/27/16 07:11 AM
GM 55560202 longlife cut open - 10782km
by turboseize
08/27/16 04:54 AM
Coolant Question.
by Farmer
08/27/16 04:20 AM
Stocking up for the Eco
by buck91
08/27/16 12:25 AM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
80 registered (55Test, 4WD, 2015_PSD, a1mfw, 2004tdigls, A310, 8 invisible), 1658 Guests and 36 Spiders online.
58935 Members
66 Forums
253619 Topics
#2258279 - 05/11/11 08:38 PM Clark 2420 Transmission Oil?
6v53 Offline
Loc: Florida
Hi, I recently purchased a Clark Michigan 85 IIIA articulating wheel loader. Iím slowly going over the entire machine and changing all the oil and filters.
My next job is the transmission and torque converter which share the same oil reservoir. I own a maintenance and operators manual but oil requirements are confusing. It appears as if the manual recommends straight 30 weight engine oil for temperatures above 30 degrees. This is fine for me in Florida but it just doesnít sound right putting engine oil in a transmission. I do see that you can use dexron or dexron 2 for temps down to -30 but arenít dexron and 30 weight engine oil completely different. How could either one work in this transmission?
I attached a copy of the manual page for both the torque converter and the transmission. They are both basically the same but do have some differences. I just want to make sure I am supposed to use regular straight 30 weight engine oil before I mess something up. If anyone has a recommendation for a specific brand let me know.
Thanks for the help.
Dan
Edited by 6v53 (05/11/11 08:31 PM)
#2258291 - 05/11/11 08:44 PM Re: Clark 2420 Transmission Oil? [Re: 6v53]
JRed Offline
Loc: Virginia
If it recommends 30-weight engine oil, use it. Go get some SAE30 HDEO (Delo, Rotella, etc.) and you'll be fine. 30-wt engine oil is somewhere in the neighborhood of an 80W or 85W gear oil.
06 Subaru Impreza WRX - Sold. The only mechanical thing I'll ever love.
07 Toyota Prius - Cheap synthetic and PureOne filters.
#2258302 - 05/11/11 08:54 PM Re: Clark 2420 Transmission Oil? [Re: 6v53]
tom slick Offline
Loc: Central Coast, Calif.
It's pretty specific about engine oil, it even states it in capital letters. I'd use SAE30 engine oil.
You get what you pay for...
So keep in mind how much you paid for this advice.
#2258323 - 05/11/11 09:10 PM Re: Clark 2420 Transmission Oil? [Re: tom slick]
6v53 Offline
Loc: Florida
Well Iím using Delo 100 in the engine right now. Would It matter if I used the Delo 100 or 400. Delo 400 seems much easier to find.
Dan
#2258484 - 05/12/11 12:51 AM Re: Clark 2420 Transmission Oil? [Re: 6v53]
onion Offline
Loc: kansastan
A recommendation for engine oil, atf, and/or hydraulic oil depending on temperature range is not uncommon at all for heavy equipment transmissions. This is the norm.
If that was my machine, I'd probably fill the transmission with the cheapest 10W30 that money can buy... so long as it meets a fairly recent API rating. But really you could probably fill it with hydraulic oil, universal tractor fluid, 30wr, 15w40, or ATF... I doubt it would make any differnce at all.
The invisible and the imaginary look exactly the same.
#2263522 - 05/17/11 10:51 AM Re: Clark 2420 Transmission Oil? [Re: onion]
6v53 Offline
Loc: Florida
Iíve decided to go with Chevron Delo 400 SAE 30W. Thanks for the help. Iím sure I will be posting more questions as I go over this machine.
Thanks, Dan
#2274320 - 05/30/11 06:23 AM Re: Clark 2420 Transmission Oil? [Re: 6v53]
ac_tc Offline
Loc: sweden
THF
-98 Dodge Durango 5.9 4*4 HDEO 10w- 40 ci4
-04 PT Cruser GT 10w- 40 HDEO ci4
-Everything else HDEO 10w- 40 ci4/STOU 10w-30/THF
#2279032 - 06/04/11 01:16 PM Re: Clark 2420 Transmission Oil? [Re: 6v53]
onion Offline
Loc: kansastan
Thanks, Dan
For the climate you're in, that choice would be hard to beat.
#2285032 - 06/10/11 09:18 PM Re: Clark 2420 Transmission Oil? [Re: 6v53]
Steve S Offline
Loc: East of IGO
I worked at a material handling dealership and there many trannies run 30wt or 15W-40 "HDEOS" they are great oils.
Why do people post I want the best for my car,,, When there isn't anything that is the best on the car to begin with.
#2288995 - 06/15/11 06:54 PM Re: Clark 2420 Transmission Oil? [Re: 6v53]
widman Offline
Loc: Bolivia
Normally you don't want to put multigrade oils in those transmissions. You need to be very careful not to put sulfur/phos oils in there. SAE 30 is normal, although I normally see SAE 30 meeting a TO-4 spec for friction modification to eliminate disc slipping.
Richard's Car Restorations
#2291708 - 06/18/11 11:58 PM Re: Clark 2420 Transmission Oil? [Re: 6v53]
onion Offline
Loc: kansastan
Why aren't multi-grade oils suited for that transmission?
I'm not saying that this is correct practice- I don't have ANYTHING in writing to prove that it is. But I do know from experience that lots of heavy equipment shops would simply fill that transmission with 10W30 or 15W40 and call it a day. And it would operate just fine on either oil.
Other than a little more resistance to shear, what advantage is there to a single grade oil?
