45551 Members
64 Forums
193898 Topics
Max Online: 2449 @ 05/13/13 01:57 PM
#2257523 - 05/11/11 03:09 AM
Best lube for door hinges?
Loc: Colorado
What is a good lube to protect and reduce wear on car door hinges and hood latches? Also what is a good lube for the door locks and the best way to apply the lube? Many thanks!
#2257530 - 05/11/11 04:35 AM
Re: Best lube for door hinges?
[Re: Chris B.]
Loc: Southeastern, PA
Nothing fancy here. I just use my little oil can with some SAE30 and put a few drops on the door / hatch / hood hinges every oil change. The hood latch gets a little oil too. Sometimes I'll squirt a little CRC Power-Lube in the door and hatch latches. Once a year, in the fall, I lube the locks with a little special graphited lock lube on a key. They don't freeze-up and nothings failed yet, and we keep our cars a long time.
"Heat is your friend."
#2257562 - 05/11/11 07:15 AM
[Re: Chris B.]
Loc: north carolina
I use spray lithium grease, in the locks on my cars and my travel trailer.
Bryan 13 elantra 9k m1 5w 20 03 suzuki gz250 amsoil 01 saturn sc1 145k mobil hm 93 olds ciera 53k 5w30 mc5k 03 chevy avalanche 60k QSUD
#2257566 - 05/11/11 07:18 AM
[Re: Chris B.]
Loc: New Jersey
Mercedes recommends oil for hinges, ATF for throttle linkages. Others may differ in suggestions. I see a lot of talk about white grease. Maybe that's OK too...
#2257582 - 05/11/11 07:46 AM
[Re: Chris B.]
Loc: Charlotte, NC
I use DuPont Silicone/Teflon spray (using the included straw when necessary). Seems to work well, even after it dries. I get it at Lowe's. Their Teflon White Lithium Grease spray seems like it would be great (and better) for hinges however.
Wish I could say it's been nice, BITOG.
#2257633 - 05/11/11 09:06 AM
[Re: Chris B.]
Loc: Florida
The best advice I've heard on here has been to use motorcycle chain lube. I haven't had a chance to try it yet.
Take care, -Mike
2006 Chevy Silverado LT 4.8 - QS 5w30, Napa Gold 2009 Honda Accord LX-P 2.4 - QS UD 0w20, P1 14610
#2257639 - 05/11/11 09:13 AM
[Re: Chris B.]
Loc: Toronto, Canada
+1 for chain lube, works great for me.
2006 Mazda3 2.0 - 165,000 Km 2003 Ford Focus ZX5 2.0 Zetec - 136,000Km
#2257642 - 05/11/11 09:17 AM
[Re: Chris B.]
Loc: CA
Wurth HHS-2000. Sprays thin so it can creep into tight spaces, then gets very thick as the solvent evaporates. Works for suspension bushing noises too. (Looks like the Wurthusa site has HHS-K instead, probably changed the solvent.)
Edited by spackard (05/11/11 09:23 AM)
#2257665 - 05/11/11 09:57 AM
[Re: Chris B.]
Loc: Henderson, Nevada
SAE 70 wt. applied with a syringe. Chain lube is effective. John--Las Vegas
#2257689 - 05/11/11 10:25 AM
[Re: Chris B.]
Loc: By Detroit
They have that garage door lube, stuff is supposed to go on and be dry so as not to attract dust and stuff. I think that is the lube to use on door hinges, hood latch, anything that will clog with gunk if regular lube is used.
Just say NO to automatic transmissions, front drive, IRS, electric windows, power locks, power seats, and touch screens!
#2257695 - 05/11/11 10:34 AM
[Re: TallPaul]
Loc: Charlotte, NC
And I would think that pretty much anything automotive that is exposed or semi-exposed falls under "will clog with gunk if regular lube is used". So basically use any decent lube that goes on thin and wet, then drives and leaves a protective, lubricating film. Like Royal Purple Chain Lubricant or DuPont Teflon Multi-Use Lubricant. Wurth HHS-K (the successor of HHS-2000) mentions "dirt-free lubricating points", so I don't think I'd use that. It's also breathtakingly expensive. I'm glad this topic was raised; I'll switch.
#2257823 - 05/11/11 12:50 PM
[Re: Chris B.]
Loc: western Wisconsin
I use a can of GM Superlube that I bought from a dealer, since it was recommended in the manual of a previous car I owned. It seems to work well, sprays on thin, but supposedly dries to a more grease-like viscosity.
'05 Saab 9-5 arc 2.3T auto, 96k, M1 0-40 + pure 1 '07 Yamaha C3, 900 mi, Rotella T 10-30
#2257851 - 05/11/11 01:24 PM
[Re: spackard]
Loc: washington
Wurth HHS-2000. Sprays thin so it can creep into tight spaces, then gets very thick as the solvent evaporates. Works for suspension bushing noises too. (Looks like the Wurthusa site has HHS-K instead, probably changed the solvent.) That's what we use at the shop. Seems to work well. The excess does collect dirt, but that's just about enything you use, excepting the dry lubes. (teflon spray and such)
Information is power. Factual data is ammunition.
#2258249 - 05/11/11 08:19 PM
[Re: Rix]
Loc: Central Coast, Calif.
Wurth HHS-2000. Sprays thin so it can creep into tight spaces, then gets very thick as the solvent evaporates. Works for suspension bushing noises too. (Looks like the Wurthusa site has HHS-K instead, probably changed the solvent.) That's what we use at the shop. Seems to work well. The excess does collect dirt, but that's just about enything you use, excepting the dry lubes. (teflon spray and such) HHS2000 is great for hinge type applications.
You get what you pay for... So keep in mind how much you paid for this advice.
#2258365 - 05/11/11 09:49 PM
[Re: Chris B.]
Loc: Charlotte, NC
Just seems to me like hood and door hinges would be a bit too exposed to dirt to use any lube that would make it stick around.
