Avoiding short trips like the plague
by FordCapriDriver
06/25/16 03:11 AM
API CK-4
by JustPlainFolks
06/25/16 02:37 AM
Rotella T
by momo
06/25/16 01:51 AM
3,000 mile OCI/severe service/newspaper delivery?
by Aurora09
06/24/16 11:46 PM
move over esters...time for alkylated napthenes
by Shannow
06/24/16 10:46 PM
ear wax and ear plugs
by motor_oil_madman
06/24/16 09:26 PM
Discount Tire Direct 4th of July Sale
by sopususer
06/24/16 08:37 PM
What kind of oil drain plug gasket is this?
by Chris B.
06/24/16 07:36 PM
by Chris B.
06/24/16 07:34 PM
First time changing oil what to use ?
by sshazam
06/24/16 07:13 PM
toshiba 720p 28" TV hdmi to thinkpad vga cable?
by bmwjohn
06/24/16 06:48 PM
1988 Brougham
by momo
06/24/16 06:38 PM
accobra66, Diehl, Hotrodls1, Koloa, codeman021
58257 Registered Users
18 registered (bbhero, 285south, asand1, ChristianReske, 2 invisible), 527 Guests and 13 Spiders online.
58257 Members
66 Forums
250769 Topics
Page 1 of 2 1 2 >
#2256177 - 05/09/11 06:47 PM Worn Out Plastic Chain Tensioners on 2007 Frontier
Boomer Offline
Loc: Pennsylvania
Had the Fronty at the dealer to replace the two secondary timing chain tensioners (warranty) at 36,000 miles! They are almost completely eaten through by the secondary timing chains, a problem that Nissan Frontiers with the VQ40 engine have been having. It manifests itself as a siren like noise as the chains eats through the plastic and hits the metal underneath. Looking at the old part, it appears to my eye to be a nylon part but I cannot swear to that.
I have used only Mobil 1 in the engine and there was no visible varnish or color on any of the metal parts. But I am curious...does anyone here know of a relationship between oil type and this kind of sliding wear? I know from Frontier boards that all types of oil has been used where this failure is found so I don't think there is but I would likie to hear your thoughts, please.
Thanks in advance.
2003 Saturn L 300 128,200 miles
2013 VW Passat TDI SE, 31,600 miles
2014 VW Jetta TDI SportWagen 17,300 miles
#2256180 - 05/09/11 06:49 PM Re: Worn Out Plastic Chain Tensioners on 2007 Frontier [Re: Boomer]
Bluestream Offline
Loc: Waterloo, ON
The oil has nothing to do with it; its a design flaw.
Same as Ford 4.0 SOHC engines from 1997 to 2002
2000 Cavalier 2.2 A4
2000 VW Beetle 1.8T M5
2000 Ford Explorer 4.0 4X4
1991 BMW 735iL
"A fool and his money are soon parted" - Thomas Tusser
#2256198 - 05/09/11 07:18 PM Re: Worn Out Plastic Chain Tensioners on 2007 Frontier [Re: Bluestream]
MNgopher Offline
Loc: Lakeville, MN
Ditto bluestreams comment. The type of oil used has little or no bearing on that failure, particularly in that timeframe. I say that as an owner of a 97 Ford Explorer with the 4.0 SOHC engine. That engine has the same issue for the earlier years (97-01 ish) that manifests itself as a terrible rattling noise.
#2256210 - 05/09/11 07:27 PM Re: Worn Out Plastic Chain Tensioners on 2007 Frontier [Re: Boomer]
caprice_2nv Offline
Loc: Ontario Canada
I had an 04 Nissan Quest with 3.5L in for an oil change and check a noise out. Sounded like timing chain tensioners were coming right apart and I found a tsb for the problem. This one was actually knocking though. Oil was sludgy and appeared very under maintained though.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
79 Honda CX500
#2256225 - 05/09/11 07:41 PM Re: Worn Out Plastic Chain Tensioners on 2007 Frontier [Re: Boomer]
dparm Offline
Loc: Chicago, IL
36k is pretty nuts. There's a very slim number of guys with Audi's 4.2L 40V V8 that have this problem. No real pattern to it yet. Even guys who ran VW-approved oils at the proper change intervals and babied the cars had it happen, but it's only a handful of cases out of thousands of motors made.
2011 BMW M3 sedan ZCP
#2256241 - 05/09/11 08:11 PM Re: Worn Out Plastic Chain Tensioners on 2007 Frontier [Re: dparm]
motor_oil_madman Offline
Loc: Houston, Texas
I have an 05 frontier. Does it have the same problem? 38,000 miles. Doesn't make any noise. How common is this?
Edited by motor_oil_madman (05/09/11 08:15 PM)
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
#2256257 - 05/09/11 08:26 PM Re: Worn Out Plastic Chain Tensioners on 2007 Frontier [Re: Boomer]
zyxelenator Offline
Loc: Louisville,KY
Try adding can of moly, maybe it will slow down eating tensioner.
99 Camry V6, 5 speed M/T
148k miles.Current fill:5w-30 G-oil,OVERSIZE P1, some Kreen and Ceratec added.
Lubro Moly 75w90 synthetic hypoid oil,with Moly
#2256269 - 05/09/11 08:42 PM Re: Worn Out Plastic Chain Tensioners on 2007 Frontier [Re: Boomer]
FL_Rob Offline
Loc: gulf coast FL.U.S.
Nissan engineers screwed it on this one,using plastic(of some variety)is just cheaping out,Ford did it too,Amongst others.How about this brainiak engineers ,A roller sprocket.. spring loaded, and torque adjustable.TA-DA. duh
#2256284 - 05/09/11 09:01 PM Re: Worn Out Plastic Chain Tensioners on 2007 Frontier [Re: Boomer]
Boomer Offline
Loc: Pennsylvania
Madman, all Frontiers can have this problem as can any Nissan with the VQ40 engine. On some, it never happens. On others like mine, kaboom. It is covered by the power train warranty (5 years, 60,000 miles???). After that, on your own.
Also, some Frontiers have the auto trans cooler inside the radiator fail and put coolant in the trans. Requires a new trans in many cases. They have extended the warranty on this for 8 years, 80,000 miles, I think.
#2256329 - 05/09/11 09:41 PM Re: Worn Out Plastic Chain Tensioners on 2007 Frontier [Re: Boomer]
Spazdog Offline
Loc: Arlington
shrug It happens:
VR6 Volkswagens are notorious for this. The tensioner guide is plastic. Usually lasts 100-120k mi. Not much better than a timing belt.
Early ecotecs had similar problems (Saturn L-Series)
Mercedes Benz 380s puked out timing chains....though I think they just underengineered the timing chain. Not because of plastic guides. the warranty replacement chain was a double row chain
It's unfortunate at 38,000 miles. I only hope the replacement parts are of better quality than the originals
2013 Chevrolet Cruze Eco - dealer Dexos
2014 Chrysler 200S - Whatever the dealer put in it.
1987 Honda CN250 Helix - Penn Platinum Euro5W40
#2256351 - 05/09/11 10:10 PM Re: Worn Out Plastic Chain Tensioners on 2007 Frontier [Re: Boomer]
morris Offline
Loc: ks, wichita
non American cars with a design flaw , na i cant beleave that.
#2256511 - 05/10/11 02:50 AM Re: Worn Out Plastic Chain Tensioners on 2007 Frontier [Re: Boomer]
mechtech2 Offline
Loc: Chicago Area
There might be some oil or moly additive which would have allowed you 5-10,000 more miles before failure.
But be glad it failed early enough for a warranty repair!
#2256573 - 05/10/11 06:35 AM Re: Worn Out Plastic Chain Tensioners on 2007 Frontier [Re: Boomer]
rg200amp Offline
Loc: Phila,PA
If the chain ate through the plastic down to the metal base of the tensioners, I would want a new chain aswell. . .
// 2013 Subaru WRX //
SOLD:
-11 Volkswagen Jetta
-04 Lincoln LS
-01 Ford F250
-04 Mazda Rx-8
-97 Jeep Wrangler
-97 BMW M3
-97 Nissan Maxima
#2256621 - 05/10/11 07:54 AM Re: Worn Out Plastic Chain Tensioners on 2007 Frontier [Re: Boomer]
Hokiefyd Offline
Loc: Virginia
Nissan's KA-series engines also experienced this issue. I took the valve cover off my KA24E with 175,000 miles on it just to inspect the chain guides. They were pristine; they had to have been replaced before. The engine still rattled when it started, but was otherwise as tight as a drum.
I think all VQ-series engines (not just VQ40s) are prone to this.
Cheers,
Jason
2009 Honda Ridgeline RTL
2005 Acura MDX Touring
#2256662 - 05/10/11 08:49 AM Re: Worn Out Plastic Chain Tensioners on 2007 Frontier [Re: Hokiefyd]
Spazdog Offline
Loc: Arlington
The cause of the start-up timing chain noise on KA-series Nissans is often the tensioner itself. Seems like it takes awhile to receive oil pressure like the oil port is sludged but it happens on well maintained engines too. shrug
Page 1 of 2 1 2 >
