2002 Dodge Dakota QC 4x4
EQUIPMENT MAKE: Dodge
EQUIPMENT MODEL: Dakota QC 4.7L V-8
FUEL TYPE: Gasoline (Unleaded)
OIL LAB: Oil Analyzers
Lab comments were that no corrective action is needed.
I realize I overkilled with analysis, but that was before I found this site. Even though the engine was new, the 1200 mile oil change appears as though it was a waste. I don't fully understand VIS, but the factory fill appears pretty thin. Could that have been due to the fuel present?
I plan to do the next change at 7500 miles on the oil and probably stick with that if the next analysis looks good. Once the wear metals stabilize, I may eventually switch to AMSoil for a comparison.
If I do oil changes every 7500 miles per manual, it seems as though I won't be using the synthetic oil to its fullest. However, I haven't seen any dino or blended oils that appear to hold up that long. Any thoughts?
What do you look for in an analysis report that would indicate sludge is building up? I'm just curious due to my experience with a previous vehicle.
Your comments would be appreciated.
Probably 80 percent of the miles are highway.code:
Oil Brand Mopar Mobil1 Mobil1
Oil Weight 5w30 5w30 5w30
Oil Filter Mopar Mobil 1 Mobil 1
Sample Date 10/4/02 2/15/03 6/26/03
Miles Oil 1201 4140 5300
Miles Eng 1201 5509 10800
Iron 18 22 22
Chromium 0 4 3
Lead 0 2 1
Copper 10 6 7
Tin 1 0 0
Aluminum 3 8 6
Nickel 0 0 0
Silver 0 0 0
Silicon 16 21 20
Boron 34 138 234
Sodium 1 19 15
Magnesium 0 40 44
Calcium 1124 3038 2859
Barium 0 0 0
Phosph. 887 1055 1022
Zinc 1098 1108 1156
Moly. 0 73 107
Titanium 0 0 0
Vanadium 0 0 0
Potassium 0 0 0
Fuel 1.1
VIS@100C 8.9 10.13 10.41
Water 0.05 0 0
Soot N/A N/A N/A
Oxid 6.7 4.0 8.0
Nitr 5.7 3.0 5.0
TBN 6.9 7.37 7.89
