Electrical shock at the grocery store
by Merkava_4
05/30/16 11:42 PM
Another should I change my oil thread
by dan_erickson
05/30/16 10:53 PM
new HDM part number for lacrosse headlamp recall
by lucerne06
05/30/16 08:48 PM
snapper blade control is stiff
by edwardh1
05/30/16 08:44 PM
is my extension cord bad?
by motor_oil_madman
05/30/16 08:33 PM
Done with Sandisk USB Sticks
by JHZR2
05/30/16 08:20 PM
Pineapple Margaritas
by sleddriver
05/30/16 08:12 PM
Replacing Drywall In The Bathroom (Insulation)
by Warstud
05/30/16 07:56 PM
351W build with a flat tappet
by ssregal39
05/30/16 07:30 PM
Fuel injector cleaner that will run the engine?
by Red00Jetta
05/30/16 07:12 PM
Car's models of 1990 and now
by HTSS_TR
05/30/16 07:02 PM
Another dealer oil change story
by mclasser
05/30/16 06:36 PM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
40 registered (CKN, andrewp1998, chrisri, clinebarger, bdcardinal, Abakev, 9 invisible), 751 Guests and 314 Spiders online.
58031 Members
66 Forums
249616 Topics
Page 1 of 2 1 2 >
#2249995 - 05/03/11 07:39 AM 2 cycle oil mix ratio help
coopns Offline
Loc: Scituate MA
I have a two cycle trimmer. I had some Super TECH Universal 2-cycle oil (blue bottle). The trimmer was a 40:1 ratio. I filled my gas can with 1 gallon. I am not sure what the mix ratio is...I can't figure it out. Isn't that awful.
Coop
#2250001 - 05/03/11 07:50 AM Re: 2 cycle oil mix ratio help [Re: coopns]
Astro14 Offline
Loc: Virginia Beach
A US Gallon is 128 ounces. 40:1 in a gallon is 3.2 oz...
32 Packard 15W40
90 4Runner 10W40 Edge
92 300E 0W40 Edge
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 5W40 PU
05 MB S600 0W40 M1
06 Corolla 5W30 Edge
#2250005 - 05/03/11 07:54 AM Re: 2 cycle oil mix ratio help [Re: coopns]
FowVay Offline
Loc: Southeastern USA
You divide the number of ounces of gasoline by the mix ratio that you wish to achieve and it will give you the amount of oil in ounces of two-cycle oil to use.
Example:
for one gallon (128 ounces)
128 40 (desired mix ratio) = 3.2 ounces of oil
(ounces of gas) (desired mix ratio) = (amount of oil to use)
#2250006 - 05/03/11 07:55 AM Re: 2 cycle oil mix ratio help [Re: Astro14]
coopns Offline
Loc: Scituate MA
Thanks for that. Funny (or not), I google that and came up with the Website that does that calculations. Hard to fathom all the info on the net. I usually do a google search on most stuff but enjoy the "comfort" of Bob's.
Coop
#2250007 - 05/03/11 07:56 AM Re: 2 cycle oil mix ratio help [Re: coopns]
FowVay Offline
It's good (best) to know how even if it is available on the net.
#2250012 - 05/03/11 08:04 AM Re: 2 cycle oil mix ratio help [Re: coopns]
The_Eric Offline
Loc: Iowa
Using 1 gallon as the total volume (128 ounces), divide that by your known amount of 40 parts of gas and you'll get the amount of oil needed. You can check it by multiplying the answer by the ratio (40)
Or, you can just start simple and work up to it:
2:1 (128:64) ounces gas/ounces oil
4:1 (128:32)
8:1 (128:16)
16:1 (128:8)
32:1 (128:4)
Using this method, (for the math impaired), you know that you'll at least need LESS than 4 ounces of oil. But really, just do it like I showed you above...
edit: Ooops, looks like I'm late to the party....
Edited by The_Eric (05/03/11 08:06 AM)
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
#2250034 - 05/03/11 08:32 AM Re: 2 cycle oil mix ratio help [Re: coopns]
Astro14 Offline
Loc: Virginia Beach
When I had an RM-125, I spent a lot of time mixing racing gas and oil. I am a physics major, pretty good at math...
But for the bike, I bought a specially-made jug that had a main compartment for gas that was graduated in liters and another compartment for oil that was graduated with multiple scales based on desired mix ratio.
So, you would fill the gas portion of the jug to...say "6". Then you look at the oil portion, pick your scale...say, "40:1"...and fill the oil up to the "6" on that scale. Invert the jug and mix 'em up.
It was great for mixing different ratios, in small quantities...and the best part? No math errors!
But, now you know why all the major OPE manufacturers sell little 3.2 OZ bottles of oil...
32 Packard 15W40
92 300E 0W40 Edge
05 MB S600 0W40 M1
#2250043 - 05/03/11 08:44 AM Re: 2 cycle oil mix ratio help [Re: coopns]
Quattro Pete Offline
Loc: Great Lakes
Just to be clear, the ratio is determined by the particular 2-cycle oil that you're using and not by the trimmer itself. So, you should refer to the instructions on the bottle.
'02 530i (Edge HM 10W-40)
'15 Q5 3.0T (Edge 5W-40)
#2250059 - 05/03/11 09:01 AM Re: 2 cycle oil mix ratio help [Re: coopns]
ARCOgraphite Offline
Loc: N.H, U.S.A.
When you encounter a math problem with ratios and you only have two numbers to calculate, you typ divide or multiply. Obviously its not 128 * 40 so, it's either = 12.8/4 or 4/12.8. You might assume the mix would be require at least 1 oz of oil, so v = 12.8 / 4 would be the best guess. You do have to know how many oz per gallon, but recalling 2 pints per 1-Qt, then, 4-Qts per 1-Gallon will get you there.
Now if you had 3/4th a gallon of gas previously mixed at 100:1 and you wanted to add TCW3 to get you to 40:1 - that solution requires heavier lifting wink
2014 Nissan Rogue S CVT, OC#4 13740mi-Castrol Magnetec 5W30+Nissan 15208-9E01A Filter
2015 Forester 6MT 5Door, OC#6 41243mi-M1EP 0W20+Subaru Filter
#2250063 - 05/03/11 09:04 AM Re: 2 cycle oil mix ratio help [Re: coopns]
NateDN10 Offline
Loc: Rochester, NY
You can also do this sort of thing in Google automatically.
For example, type in the Google box:
2005 Chevrolet Cobalt - 95,000 mi.
2012 Mazda5 - 80,000 mi.
#2250070 - 05/03/11 09:12 AM Re: 2 cycle oil mix ratio help [Re: Quattro Pete]
propuckstopper Offline
Loc: MB, Canada
With all due respect, I disagree. The guy who builds the particular equipment should be the guy you listen to regarding mix ratios. In others words, if Stihl says to mix their trimmers at 50:1, then you should follow that advice in lieu of what is printed on the side of an oil bottle.
Having said that, I do have Stihl OPE that recommends 50:1 ratios. Yet, I use Amsoil Sabre 100:1 in all of them. But as per my comment above, I always mix the Sabre at the Stihl recommended ratio of 50:1.
If Amsoil figures their Sabre is good enough to run at 100:1, then I know it will definitely be good enough (better) at the Stihl recommended ratio of 50:1.
I know there are lots of folks who ignore OPE manufacturer's recommended ratios, but I really don't know why. I'd save very little money running my OPE at 100:1, for instance, and the brain damage it would give me would not be worth it.
1965 Pontiac GTO Tri-Power 4-Speed Hardtop (Montero Red)
1968 Pontiac GTO Covertible 400 H.O./Auto (Solar Red)
2000 Lexus ES300
2003 Honda Element AWD
#2250093 - 05/03/11 09:29 AM Re: 2 cycle oil mix ratio help [Re: propuckstopper]
Loc: Great Lakes
You have the right to do so. This subject was discussed at length here in the past if you do a search.
You may want to pay more attention to the wording in your Stihl owner's manual. I've got two pieces of Stihl equipment, and both of them just say that if you're using Stihl 2-cycle oil (which they obviously recommend), then you should mix it at 50:1 ratio. They don't say what ratio should be used if you're using someone else's oil.
Another example is fuel additives/system cleaners for your car. Have you noticed that different ones should be added into your tank in different proportions? Wonder why?
My guess is that Sabre is more concentrated, so you need to use less of it. Why do you assume that more oil is better? By the same logic, if 50:1 is better than 100:1, then surely 5:1 should be even better than 50:1, right?
Too much oil can foul your plugs and possibly cause other issues.
#2250108 - 05/03/11 09:45 AM Re: 2 cycle oil mix ratio help [Re: Quattro Pete]
beanoil Offline
Loc: Midwest, Illinois
NO NO NO! Mix at what the equipment requires, and recommends.
beanoil: Tough under heat, real dirty afterwards.
#2250110 - 05/03/11 09:49 AM Re: 2 cycle oil mix ratio help [Re: beanoil]
Loc: Great Lakes
Sigh...
Read my response above.
#2250111 - 05/03/11 09:49 AM Re: 2 cycle oil mix ratio help [Re: coopns]
boraticus Offline
Loc: Canada
I can't believe how often this discussion comes up and the varied, unsupported opinions that participants offer.
Mix the fuel at the manufacturers recommended ratio. Plain and simple. If you're going to flog the equipment, mix it with a bit more oil. You will get better lubrication and more power.
From my experience, (and I have plenty of it), if you're using any decent two cycle oil and the equipment is being run hard, there will be no issues with plug or exhaust fouling.
Don't get much easier than that.
Page 1 of 2 1 2 >
